Safe, Single-Pilot IFR generalities
Old July 2nd 05, 04:12 AM
Peter R.
"Peter R." wrote:
Assuming the Bonanza had this fancy, *adequete* lighting system, what are
the odds that the bulb of this system wouldn't burn out the moment you
flicked it on? 1 out of a 100, perhaps?
Whoops, the hypothetical doesn't match the odds. Try again:
What are the odds that the bulb of this system *would* burn out the moment
you flicked it on? 1 out of a 100?
There... that's better.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
  #42
Old July 2nd 05, 09:35 AM
Bob Noel
I'm pretty sure that bulbs have a better MTBF than that. I know I'm probably
(no pun) jinxing my airplane, but I haven't replaced a bulb in my airplane
in over ten years. The one exception is the landing light that I've replaced
once because of a cracked lens - the light still worked.
Bob Noel
no one likes an educated mule
  #43
Old July 2nd 05, 03:24 PM
Greg Farris
Many thanks to those who contributed their experience and opinions to the
discussion.
With regard to the author cited, Larry Bartlett, and his video refresher
course, I would recommend this series.It does not contain in-flight videos,
it's all classroom and blackboard (which the author masters quite well). It
also is not a basic IFR training course, and by no means pretends to cover
all the textbook training for IFR - but as a refresher course, with a
distinct point of view, expressed by a seasoned instructor, I find it
engaging and informative. Recommended, even if somewhat pricey (mine, from
Sporty's was over $100 for three tapes).
G Faris
  #44
Old July 3rd 05, 12:27 AM
Mike Rapoport
"Greg Farris" wrote in message
Here are some "general" tips for safe, single-pilot IFR, gleaned from
Larry Bartlett's refresher course. These tips do not represent the "meat
and potatoes" of the video course, but are thrown in at a couple of
points as generalities. How many agree with these :
1) No Single-Pilot, single engine IFR in IMC at night
Personal choice. The chances of successfully landing at night after an
engine failure are not that different IMC or VMC.
2) No S-P Multi-engine IFR with MEA's higher than the aircraft's SE
performance
This is pretty stupid. It ignores the fact that if the aircraft is at the
MEA and loses an engine (and MEA is above its SE ceiling) that the aircraft
will travel hundreds of miles before reaching the SE ceiling. It will also
reach it absolute SE ceiling which is much higher than the SE service
ceiling in the manual. It also ignores the fact that no piston twin and few
turboprops have enough single engine climb gradient to reach the MEA before
hitting something. In other words, it doesn't make much difference what
the SE service ceiling is.
3) No S-P IFR in IMC without dual vacuum sources, and strong
preference for dual alrternators.
Personal choice.
4) Keep VFR weather within range of the aircraft at all times, and
know where it is
Not practical a lot of times.
5) Avoid S-P circling approaches in IMC, and definitely not at
night or close to minimums
This is pretty stupid too. There are lots of approaches where the MDA is
not much different than pattern altitude.
The reality is that even the simplest airplane with no redundant systems is
far more reliable that the pilot flying it.
Mike
MU-2
  #45
Old July 3rd 05, 09:24 AM
Greg Farris
In article t,
says...
performance
Personal choice.
know where it is
Mike
MU-2
His comments were specifically aimed though at "typical" GA aircraft - singles
and light twins, not twin turboprops. Several of your comments are equally
valid for eaither realm, of course, but things like "keep IFR within range"
could be of less concern to you, because of the comfort you can take in the
performance of your machine.
G Faris
  #46
Old July 3rd 05, 10:12 AM
Julian Scarfe
"Mike Rapoport" wrote in message
k.net...
performance
aircraft will travel hundreds of miles before reaching the SE ceiling. It
will also reach it absolute SE ceiling which is much higher than the SE
service ceiling in the manual. It also ignores the fact that no piston
twin and few turboprops have enough single engine climb gradient to reach
the MEA before hitting something. In other words, it doesn't make much
difference what the SE service ceiling is.
The Single-Pilot bit puzzles me too. Surely this is a performance issue.
Does it really take two pilots to work out whether you're going to hit the
mountain or not?
Julian
  #47
Old July 3rd 05, 04:53 PM
Richard Kaplan
I think a backup electric AI is more important than dual vaccum sources.
I think a battery GPS is a highly desirable item; if you have one, dual
alternators become much less important.
Richard Kaplan
www.flyimc.com
  #48
Old July 3rd 05, 09:40 PM
Jimmy B.
k.net...
performance
mountain or not?
Julian
This reminds me of the "Far Side" cartoon showing two pilots discussing
why there is a mountain goat in the clouds.
  #49
Old July 4th 05, 01:12 AM
Mike Rapoport
In article t,
says...
performance
aircraft
also
few
before
Personal choice.
know where it is
is
Mike
MU-2
singles
range"
G Faris
I look at it from the point of view that if there is a meaningful chance
that I will have to divert to somewhere with VFR weather then I wouldn't
launch into IMC in the first place. Basically he is saying that you won't
be able to fly IMC at some point in the flight but you are going to depend
on flying IMC (to get to the VFR). .That doesn't mean that I don't want a
"real" alternate where I can count on getting in but if that alternate needs
to be VFR then either the pilot or the airplane is not up to flying IMC in
the first place.
The no single pilot, single engine prohibition similiarly doesn't make
sense. What good would having two pilots do if the (single) engine quit?
His comments on multi simply don't make sense either. If you can't control
a multi in the event of an engine loss then it doesn't make any difference
whether it is VMC or IMC, you shouldn't be flying a multi. If you can
control the airplane on one engine then there is no senario where you would
be better off in a single after one engine fails.
Last week I went to McCall for a mountain flying school (which was really
great BTW) and I had to fly the Helio in IMC for the first time. It was
pouring rain to the point that water was coming out the vents. I was
uncomfortable for the IMC duration of the flight (which was 90%) but none of
the "rules" or strategies espoused in this book would have made things any
better although I would probably have been even more uncomfortable at night.
I think that every pilot has to decide for himself and his passengers what
constitutes acceptable risk and that there is no formula or set of rules
that is better than any other.
Mike
MU-2
  #50
Old July 4th 05, 06:17 AM
Robert M. Gary
I agree. Sportys has a new batch of electric back up AIs for an amazing
price.
Richard Kaplan
www.flyimc.com
Can a Private Pilot tow gliders and get paid? BTIZ Soaring 1 October 17th 04 01:35 AM
Pilot deviations and a new FAA reality Chip Jones Piloting 125 October 15th 04 07:42 PM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 03:01 PM
