Luke Scharf wrote:
I think I'm going to go with the ANR headset -- although the Clarity Aloft (and similar) headsets are intriguing. I've been looking at the Clarity Aloft and also the Lightspeed L1 now. The Clarity Aloft doesn't seem to have the cellphone interface. Is that correct? Also, has anyone flown the L1 in a typical GA aircraft? I fly a Cessna 150 most of the time now, although I also ride around in Cherokees and plan to fly some high performance aircraft at the first chance. Is it appropriate for that kind of usage? Thanks, -Luke |
Luke,
I've been looking at the Clarity Aloft and also the Lightspeed L1 now. Aviation Consumer has, too. Don't know if you have access, but the bottom line is to wait at least until Osh. New versions coming out with major improvements, it seems. -- Thomas |
The mic on The LI is positioned only by the friction of the ear bud and the
overall construction is not impressive. Possibly they will have an improved model at OSH. If not, I don't think you would prefer it in a side-by-side comparison. A cellphone interface is, I think, coming from Clarity. I suggest you email them to check. On 7/4/2005 5:00 PM, Luke Scharf wrote the following: Luke Scharf wrote: I think I'm going to go with the ANR headset -- although the Clarity Aloft (and similar) headsets are intriguing. I've been looking at the Clarity Aloft and also the Lightspeed L1 now. The Clarity Aloft doesn't seem to have the cellphone interface. Is that correct? Also, has anyone flown the L1 in a typical GA aircraft? I fly a Cessna 150 most of the time now, although I also ride around in Cherokees and plan to fly some high performance aircraft at the first chance. Is it appropriate for that kind of usage? Thanks, -Luke |
On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf
wrote: Luke Scharf wrote: I think I'm going to go with the ANR headset -- although the Clarity Aloft (and similar) headsets are intriguing. There is no cmparrison between passive and ANRs. I've been using the same old Telex headset from the early days. Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. I went along in the right seat of a twin wearing one of those little headsets. I was supposed to handle the radios and we were going dual pilot IFR. I basically ended up as a passenger as I could not hear a thing ATC said. I had my Telex set in the bag headed for the airplane, but threw them back in the car when told I wouldn't need them. Big mistake. I'd like the new Bose stereo capable head set. I've been looking at the Clarity Aloft and also the Lightspeed L1 now. The Clarity Aloft doesn't seem to have the cellphone interface. Is that correct? I can't imagine wanting a cell phone interface in the head set. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Also, has anyone flown the L1 in a typical GA aircraft? I fly a Cessna 150 most of the time now, although I also ride around in Cherokees and plan to fly some high performance aircraft at the first chance. Is it appropriate for that kind of usage? Thanks, -Luke |
![]() On 7/8/2005 1:46 AM, Roger wrote the following: On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. You like hot & sweaty ears? I went along in the right seat of a twin wearing one of those little headsets. I was supposed to handle the radios and we were going dual pilot IFR. I basically ended up as a passenger as I could not hear a thing ATC said. Roger, you surprise me. You are usually far too logical to leap from one sample to such abroad conclusion. The "little headset" may have been bad, but my Clarity set has better attenuation than the ANRs in almost the whole spectrum. Try one. The audio quality and sound attenuation will amaze you. You may even lose your fondness for sweaty ears and for placing weights on your head while flying. I can't imagine wanting a cell phone interface in the head set. I can. I have the phone numbers for the ATC centers on my clipboard and having a cell phone aboard is on my checklist. If the radios go out, I'll just call in to discuss the situation. I can't legally test this plan, but it seems likely to work. Cell is also nice for clearances from fss at un-towered airports. |
Mitty wrote in
: On 7/8/2005 1:46 AM, Roger wrote the following: On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. You like hot & sweaty ears? I like having hearing protection, especially for high-frequency stuff which ANR doesn't protect against, when (not if) the ANR portion fails. I, too, won't even consider a headset that doesn't have good passive protection. It's your hearing, though, so use what you want. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
![]() On 7/8/2005 5:30 PM, Stan Gosnell wrote the following: Mitty wrote in : On 7/8/2005 1:46 AM, Roger wrote the following: On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. You like hot & sweaty ears? I like having hearing protection, especially for high-frequency stuff which ANR doesn't protect against, when (not if) the ANR portion fails. I, too, won't even consider a headset that doesn't have good passive protection. It's your hearing, though, so use what you want. I'm not quite sure why this has gotten to be such an extended discussion, but I'm also not sure of your point. The Clarity set has exactly what you want -- high attenuation especially in the higher frequencies. Check page 17 of their owner manual: http://clarityaloft.com/6_ClarityAloft_OwnersGd.pdf So if your point is that you need big muffs to get good attenuation, that is incorrect. (In fact, logic would lead me to conclude that a good seal in the ear canal is easier to make than a large one encompassing hair, glasses bows, irregular head shape, etc.) Whether the LightSpeed set also has high attenuation, I don't know. My friend who is the president of Clarity tells me that their performance is due to the unique ear tip design and materials, which are covered by several patents. But then he's the chief salesman, too. :-) What I do know is that the product works far better than the Softcomm ANR sets that I have and that I did not hesitate to write the big check after flying with them on a demo. |
On Fri, 08 Jul 2005 23:20:01 GMT, Mitty wrote:
On 7/8/2005 5:30 PM, Stan Gosnell wrote the following: Mitty wrote in : On 7/8/2005 1:46 AM, Roger wrote the following: On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. You like hot & sweaty ears? I like having hearing protection, especially for high-frequency stuff which ANR doesn't protect against, when (not if) the ANR portion fails. I, too, won't even consider a headset that doesn't have good passive protection. It's your hearing, though, so use what you want. I'm not quite sure why this has gotten to be such an extended discussion, but I'm also not sure of your point. The Clarity set has exactly what you want -- high attenuation especially in the higher frequencies. Check page 17 of their owner manual: http://clarityaloft.com/6_ClarityAloft_OwnersGd.pdf So if your point is that you need big muffs to get good attenuation, that is incorrect. (In fact, logic would lead me to conclude that a good seal in the ear canal is easier to make than a large one encompassing hair, glasses bows, irregular head shape, etc.) Although the seals are a problem the ANR portion should help on that. The reason for the large coverage is to cover the mastioid bone which conducts a lot of sound. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Whether the LightSpeed set also has high attenuation, I don't know. My friend who is the president of Clarity tells me that their performance is due to the unique ear tip design and materials, which are covered by several patents. But then he's the chief salesman, too. :-) What I do know is that the product works far better than the Softcomm ANR sets that I have and that I did not hesitate to write the big check after flying with them on a demo. |
On Fri, 08 Jul 2005 14:25:51 GMT, Mitty wrote:
On 7/8/2005 1:46 AM, Roger wrote the following: On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. You like hot & sweaty ears? It sure beats not being able to hear and going deaf. OTOH the old Telex are "HEAVY"! I went along in the right seat of a twin wearing one of those little headsets. I was supposed to handle the radios and we were going dual pilot IFR. I basically ended up as a passenger as I could not hear a thing ATC said. Roger, you surprise me. You are usually far too logical to leap from one sample to such abroad conclusion. The "little headset" may have been bad, but my They may have been, but they were his spare as an ATP. Clarity set has better attenuation than the ANRs in almost the whole spectrum. Try one. The audio quality and sound attenuation will amaze you. You may even lose your fondness for sweaty ears and for placing weights on your head while flying. I'm not so sure. To really cut the sound you really need to cover the mastoid bone. (I used to do a lot of trap shooting). Adding ear muffs over ear plugs was like the difference between night and day. I can't imagine wanting a cell phone interface in the head set. I can. I have the phone numbers for the ATC centers on my clipboard and having a You don't have the number already in memory? Mine does. cell phone aboard is on my checklist. If the radios go out, I'll just call in to discuss the situation. I can't legally test this plan, but it seems likely to Sure you can as you are on the ground the way it's stated. OTOH, I guess it would be nice in the air if you don't get an "out of coverage" signal. Mine usually shuts down by 2000 feet if I forget to turn it off. It has to be turned off to reset if you want to call anything other than 911. work. Cell is also nice for clearances from fss at un-towered airports. Yah, but that's on the ground and if the radios aren't working I don't need the head set as I haven't fired up by that time. I fly out of an uncontrolled airport (3BS) but we have a Remote outlet on the field. Choose the frequency, follow the directions and it phones the tower. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
People often forget the old Telex "Professional" models that do not have ear
cups but an earplug that has a tube that conducts the radio/ICS sound. It normally comes with a single earpiece that makes you think it only works in quiet cockpits. I ordered the dual ear tips (about 5 dollars). The noise suppression matches the 3 different ANR headsets I have owned, and the headset is significantly lighter and more comfortable. Paul "Roger" wrote in message ... On Mon, 04 Jul 2005 18:00:53 -0400, Luke Scharf wrote: Luke Scharf wrote: I think I'm going to go with the ANR headset -- although the Clarity Aloft (and similar) headsets are intriguing. There is no cmparrison between passive and ANRs. I've been using the same old Telex headset from the early days. Flying small prop planes I would not want anything that did not have full ear coverage like the passive, but with ANR added. I went along in the right seat of a twin wearing one of those little headsets. I was supposed to handle the radios and we were going dual pilot IFR. I basically ended up as a passenger as I could not hear a thing ATC said. I had my Telex set in the bag headed for the airplane, but threw them back in the car when told I wouldn't need them. Big mistake. I'd like the new Bose stereo capable head set. I've been looking at the Clarity Aloft and also the Lightspeed L1 now. The Clarity Aloft doesn't seem to have the cellphone interface. Is that correct? I can't imagine wanting a cell phone interface in the head set. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Also, has anyone flown the L1 in a typical GA aircraft? I fly a Cessna 150 most of the time now, although I also ride around in Cherokees and plan to fly some high performance aircraft at the first chance. Is it appropriate for that kind of usage? Thanks, -Luke |
