On 4-Jul-2005, "Matt Barrow" wrote:
Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. -- -Elliott Drucker |
![]() wrote in message news:OWiye.14793$mr4.13119@trnddc05... On 4-Jul-2005, "Matt Barrow" wrote: Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. -- -Elliott Drucker I'm keeping out of the politics on this one, except to say that two out of every one of us could be schizophrenic. After talking to a Shell Guru at a seminar my understanding is that the vapour pressure issue with mogas can be of real concern and that mogas is best used for low altitude work. His other push was the relative quality of avgas versus mogas - not just in manufacture but in distribution. With what I find in many of the auto fuel filters I change, I'd have to agree. I have had about 15 cases from one local servo in the past 8 to 10 weeks. Now that, in Oz, ethanol is included in much mogas, not to mention the odd toluene shonk, I would be wary about mogas use for long haul or high altitude. Also goes without saying that you don't get as far on a litre of fuel containing ethanol and/or toluene. Brian |
![]() wrote in message news:OWiye.14793$mr4.13119@trnddc05... On 4-Jul-2005, "Matt Barrow" wrote: Well, vapor lock has nothing to do with the type of fuel you're running. On 4-Jul-2005, "Matt Barrow" wrote: While unleaded autogas provides sufficient octane to substitute for 80/87 avgas in low-compression engines, there are other differences that can cause problems when using autogas in some engine installations. The two most significant are lower vapor pressure -- which can lead to vapor lock -- and incompatibility between some of the additives in autogas and some components (particularly seals) in some aircraft fuel systems. Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the later is a distinct possibility. It's called correcting myself. You call it schizophrenia, I call it maturity. Get a ****ing clue, statist prick! |
![]() On 5-Jul-2005, "Matt Barrow" wrote: Hmm.... either there are two Matt Barrows (using the same e-mail address) or else he is schizophrenic. Judging from some of his political views, I'd say the latter is a distinct possibility. It's called correcting myself. You call it schizophrenia, I call it maturity. Get a ****ing clue, statist prick! Yeah, right. For a while I was confused. How could someone as clearly challenged by the English language (and common logic) as Mr. Barrow have composed the lucid and intelligent comments in his second post regarding vapor lock (which completely contradicted his earlier post on THE SAME DAY)? However, I took his advice to heart and "got a clue." A simple Google search on the phrase "incompatibility between some of the additives in autogas" pointed me to the following website: http://www.aviation-indonesia.com/mo...rticle&knid=16 It seems that in addition to his wealth of other shortcomings Mr. Barrow is also a plagiarist. -- -Elliott Drucker |
news:hByye.50$VN3.15@trnddc01... For a while I was confused. How could someone as clearly challenged by the English language (and common logic) as Mr. Barrow have composed the lucid and intelligent comments in his second post regarding vapor lock (which completely contradicted his earlier post on THE SAME DAY)? However, I took his advice to heart and "got a clue." A simple Google search on the phrase "incompatibility between some of the additives in autogas" pointed me to the following website: http://www.aviation-indonesia.com/mo...rticle&knid=16 It seems that in addition to his wealth of other shortcomings Mr. Barrow is also a plagiarist. Actually, he did cite the source of the words in that post, though it may not have been obvious that he was doing so. --Gary |
Does the phrase "fermented grape juice" spring lightly to the tongue?
Jim For a while I was confused. How could someone as clearly challenged by the English language (and common logic) as Mr. Barrow have composed the lucid and intelligent comments in his second post regarding vapor lock (which completely contradicted his earlier post on THE SAME DAY)? |
![]() "RST Engineering" wrote in message ... Does the phrase "fermented grape juice" spring lightly to the tongue? Scotch. Dalwhinnie or Talasker. Jim For a while I was confused. How could someone as clearly challenged by the English language (and common logic) as Mr. Barrow have composed the lucid and intelligent comments in his second post regarding vapor lock (which completely contradicted his earlier post on THE SAME DAY)? Anyone ever heard of correcting a previous mistake? Anyone ever done it without having to be bludgeoned with a crow bar? Nah!! Considering your "normal" person , who will run with a mistake for years, or even generations, I an imagine it is SHOCKING. But then, I fully grasp (despite my being "challenged by the English language") that words really do have objective meaning and I do consider good hard evidence, rather than just my whims. Were it only that others here had such honesty and integrity. |
"Matt Barrow" wrote in message
... But then, I fully grasp (despite my being "challenged by the English language") that words really do have objective meaning and I do consider good hard evidence, rather than just my whims. Were it only that others here had such honesty and integrity. Honesty and integrity? We still await an explanation of your claim to have gotten your July 4th misinformation from a "historical journal", American History Digest--a journal whose existence has gone unnoticed by both the Library of Congress and Google. (Moreover, when you first posted the article, you credited it to "Source Unknown"--a peculiar "author" for a journal piece, though standard for a chain-email.) We're also waiting for you to either substantiate or retract the implausible defamatory quote you attributed to Norman Thomas. When Elliott learned he'd made a mistaken accusation earlier in this thread, he promptly retracted it and apologized. *That's* what honesty and integrity look like. --Gary |
("Matt Barrow" wrote)
Does the phrase "fermented grape juice" spring lightly to the tongue? Scotch. Dalwhinnie or Talasker. Mmm. Two fingers. ....leaves eight for typing, by my count :-) Montblack "No going to the dark side!" - Sideways (2004) |
![]() On 5-Jul-2005, "Gary Drescher" wrote: Actually, he did cite the source of the words in that post, though it may not have been obvious that he was doing so. It appears that the citation was somehow blocked from the viewing window of my news reader, but I see it now upon re-loading the post. My apologies to Mr. Barrow for the comments regarding plagiarism. -Elliott Drucker |
