Great Lakes lake effect snow
Old October 7th 03, 04:03 AM
Tarver Engineering
"Tom S." wrote in message
"Tarver Engineering" wrote in message
"Mike Rapoport" wrote in message
.net...
This is true if the snow being produced is the flake type which
results
from
the direct crystalization of water vapor. The round "pellet" type
snow
results from the freezing of liquid cloud droplets. Clouds that are
snowing
a lot of pellet type snow have a lot of ice in them.
The smaller droplets being the more dangerous.
Rime ice? Why? That part breaks more easily from surfaces?
Icing is a statistical phenomenon and smaller droplets are more likely to
form ice on wing and rudder surfaces. (ie rudder reversal)
Old October 7th 03, 04:10 AM
Teacherjh
What is "rudder reversal"?
Jose
(for Email, make the obvious changes in my address)
Old October 7th 03, 04:22 AM
Tarver Engineering
"Teacherjh" wrote in message
Rudder reversal is a when the pilot commands rudder in one direction and the
airplane reacts as though opposite rudder was commanded. In icing
conditions, small GA aircraft are especially suseptable to flow seperation
due to icing of tail surfaces. Flow seperation is a known cause of "rudder
reversal".
Old October 7th 03, 03:56 PM
Mike Rapoport
You have it backwards, large droplets are more likely to hit the airplane
and form ice. Additionally large droplet ice is more lilkely to for beyond
the protected surfaces into ridges and horns which can cause airflow
separation.
Mike
MU-2
.net...
results
from
snow
snowing
Old October 8th 03, 03:06 AM
Tarver Engineering
ink.net...
beyond
separation.
I got my information from John Brownlee FAA flight test pilot. He gives a
pretty interesting power point presentation on the subject.
.net...
results
from
snow
are
snowing
to
Old October 8th 03, 03:45 AM
Mike Rapoport
Sorry, but you are recalling it backwards.
Mike
MU-2
news
ink.net...
airplane
beyond
separation.
.net...
results
from
type
snow
are
snowing
to
Old October 8th 03, 03:53 AM
Tarver Engineering
ink.net...
Could be, maybe I'll dig out the URL later.
Mike
MU-2
news
ink.net...
airplane
beyond
separation.
a
.net...
which
results
from
type
snow
that
are
snowing
likely
to
Old October 8th 03, 02:19 PM
David Megginson
"Tarver Engineering" writes:
gives a pretty interesting power point presentation on the subject.
Here's the poop from the weather study guide for my IFR training:
The size of the droplets and the frequency with which the strike the
aircraft are important because the character of the ice depends on
whether or not each drop freezes completely before another drop
strikes the same spot. If the droplets pile rapidly on each other
before being completely frozen, the unfrozen parts mingle and spread
out before freezing. If the droplets freeze completely before being
hit by another droplet, a large amount of air is trapped causing the
ice to be opaque and brittle.
and later,
Because of the low adhesive properties of rime, it is generally
readily removed by de-icing equipment.
and
CLEAR ICE - This type of ice has high adhesive and cohesive
properties. Unlike rime, it can spread from the leading edges, and
in severe cases may cover the whole surface of the aircraft.
(From the Canadian Forces Air Command Weather Manual, Chapter 9.) Of
course, the adhesive properties are irrelevant when I don't have
deicing equipment anyway, but the spread still matters.
All the best,
David
The National Lake Eutrophication Survey 1971-1973 Badwater Bill Home Built 18 June 16th 04 02:27 AM
Which sport/acro biplane from plans? Mr.Twistair Home Built 15 October 6th 03 04:53 AM
