In article , Paul Tomblin
wrote: Contact NASA Lewis Research Center, Cleveland OH. The were giving out Icing DVD's at Sun N Fun this past spring. They fly a Twin Otter out of Cleveland every winter, searching for ice. Lake Erie is on the boundary for high pressure/cold fronts blasting off the Canadian Plains and low pressure/warm fronts moving up from the Gulf of Mexico. The fronts frequently stall and become stationary in the Ohio-Indianna vicinity. If you are on the warm side, ice can be found near the boundary as the cold upper air overflows the warm lower air. This may be 100 nm ahead of the front. Ice is elusive, but if the conditions are right, it can hang around as it did for four days last winter December 31 - January 3 in Southern Ohio/Northern Kentucky. An east-west cold front stalled along the Ohio River late in the afternoon of December 31. Temperature/dew points hovered between 34 and 27 degrees for the next three days. Precipitation in the form of fog, snow, rain, freezing rain were prevelent for the duration. I sat for two days in Mount Sterling KY before driving home to Columbus OH. I drove back to Mount Sterling two days later when the weather cleared. |
![]() "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message .net... This is true if the snow being produced is the flake type which results from the direct crystalization of water vapor. The round "pellet" type snow results from the freezing of liquid cloud droplets. Clouds that are snowing a lot of pellet type snow have a lot of ice in them. The smaller droplets being the more dangerous. Rime ice? Why? That part breaks more easily from surfaces? |
![]() "Tom S." wrote in message ... "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message .net... This is true if the snow being produced is the flake type which results from the direct crystalization of water vapor. The round "pellet" type snow results from the freezing of liquid cloud droplets. Clouds that are snowing a lot of pellet type snow have a lot of ice in them. The smaller droplets being the more dangerous. Rime ice? Why? That part breaks more easily from surfaces? Icing is a statistical phenomenon and smaller droplets are more likely to form ice on wing and rudder surfaces. (ie rudder reversal) |
![]() Icing is a statistical phenomenon and smaller droplets are more likely to form ice on wing and rudder surfaces. (ie rudder reversal) What is "rudder reversal"? Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... Icing is a statistical phenomenon and smaller droplets are more likely to form ice on wing and rudder surfaces. (ie rudder reversal) What is "rudder reversal"? Rudder reversal is a when the pilot commands rudder in one direction and the airplane reacts as though opposite rudder was commanded. In icing conditions, small GA aircraft are especially suseptable to flow seperation due to icing of tail surfaces. Flow seperation is a known cause of "rudder reversal". |
You have it backwards, large droplets are more likely to hit the airplane
and form ice. Additionally large droplet ice is more lilkely to for beyond the protected surfaces into ridges and horns which can cause airflow separation. Mike MU-2 "Tarver Engineering" wrote in message ... "Tom S." wrote in message ... "Tarver Engineering" wrote in message ... "Mike Rapoport" wrote in message .net... This is true if the snow being produced is the flake type which results from the direct crystalization of water vapor. The round "pellet" type snow results from the freezing of liquid cloud droplets. Clouds that are snowing a lot of pellet type snow have a lot of ice in them. The smaller droplets being the more dangerous. Rime ice? Why? That part breaks more easily from surfaces? Icing is a statistical phenomenon and smaller droplets are more likely to form ice on wing and rudder surfaces. (ie rudder reversal) |
And that will quickly inflate you like a balloon! :-)
---JRC--- "Todd Pattist" wrote in message = ... Craig Prouse wrote: =20 It's got a little ball that floats along a scale which is calibrated in thousands of feet. =20 If you have one of the inline tubing scale-with-ball, you need to hold the scale vertical to read it or the little ball can roll to the max flow reading. =20 =20 Todd Pattist |
In article , Craig Prouse
writes: You can get a really nice portable O2 system for significantly less than the cost of a handheld GPS. Nice review, Craig. Thoughts on where to get a simple portable system? Chuck |
A friend of mine flys from Morristown to Buffalo and back a couple times a
week, mostly at night, and he has all kinds of stories of icing. Some of it sounds pretty scary. "Paul Tomblin" wrote in message ... Ok, it's coming up to that season, and was vividly demonstrated when I got hit by hail driving through Watertown last night. I drive a lot between Rochester NY and Ottawa Ontario, and Rochester NY and Whitby Ontario, and frequently those drives are in good VFR conditions except for that band of lake effect snow coming off of Lake Ontario at Watertown, and the one coming off of Lake Erie at Buffalo. This will be my first year with an instrument ticket, and I'm wondering if I can fly these trips. Questions: 1. How high up do those bands go? Can I go over them without oxygen? 2. If I can't go over them, do they produce airframe ice? -- Paul Tomblin http://xcski.com/blogs/pt/ There are mushrooms that can survive weeks, months without air or food. They just dry out and when water comes back, they wake up again. And call the helldesk about their password expiring. -- after Jens Benecke and Tanuki |
The National Lake Eutrophication Survey 1971-1973 | Badwater Bill | Home Built | 18 | June 16th 04 02:27 AM |
Which sport/acro biplane from plans? | Mr.Twistair | Home Built | 15 | October 6th 03 04:53 AM |
