Nimbus 4DT accident 31 July 2000 in Spain.
Old July 5th 05, 12:04 PM
Ian Johnston
On Tue, 5 Jul 2005 10:27:40 UTC, "Bert Willing"
I take of with my ASW20 on a black link. And it's not the winch driver who
decides about this.
If that is the correct link for the glider, then fine. If it's not,
and I were either launch marshall or winch driver, then I can assure
you that I, personally, would have nothing to do with launching you.
The correct weak link for an ASH-25, as specified by the designer and
manufacturer, is brown, 850dN.
Ian
  #192
Old July 5th 05, 01:35 PM
Ian Johnston
On Tue, 5 Jul 2005 10:54:57 UTC, Bill Gribble
As far as character is concerned, I'm pretty certain the last time I
launched an ASH25 (as signaller, at least) it was on a black link. Or it
would have been if that was what the pilot had asked for.
Would you launch a K8 on a black link if the pilot requested it? In
the old days, would you have signalled "all out" to the winch driver
if the pilot requested it and despite open brakes? Would you launch a
glider with a faulty back-release if the pilot said "Oh, that's OK,
just launch me."
I don't think /anyone/ on an airfield is entitled to overlook a clear
safety risk of this sort.
Ian
  #193
Old July 5th 05, 01:45 PM
Bert Willing
The book says it should be red. And as long as I'm operating my private
ship, it's me who is responsible for which weak link I ask for. Launch
marshals may comment on that, but not decide. Winch drivers are told which
glider is on the other side of the rope, and when they should start to pull.
I have seen (from the ground) quite a couple of critical situations
resulting from fatigued weak link breakage, and I prefer to watch angle of
attack and speed, and pull the knob myself if necessary. And even if the
book doesn't like it, that even works while being launched into thermals or
Mistral rotors.
Bert Willing
ASW20 "TW"
"Ian Johnston" a écrit dans le message de news:
dzZo7CxomoOm-pn2-DhT3lGVC8vpw@localhost...
who
decides about this.
Ian
  #194
Old July 5th 05, 04:59 PM
M B
Is there any commonly known way to test a weak
link non-destructively (other than launching a glider)?
I ask for. Launch
situations
to watch angle of
And even if the
into thermals or
Mistral rotors.
Bert Willing
ASW20 'TW'
'Ian Johnston' a écrit dans le message de news:
On Tue, 5 Jul 2005 10:27:40 UTC, 'Bert Willing'
who
decides about this.
If it's not,
then I can assure
launching you.
by the designer and
Ian
Mark J. Boyd
  #195
Old July 5th 05, 05:02 PM
Ian Johnston
On Tue, 5 Jul 2005 12:45:41 UTC, "Bert Willing"
Which is 750dN, and you are launching with black, which is 1000dN.
That 250dN (33%) extra probably represents around 50 - 75% overload at
the wing fuselage junction. With all due respect, that's an insane
risk to take. Would you fly your glider with a cockpit load or ballast
250kg above the maximum permitted? Would your insurance company let
you? Would your national aviation authority let you?
Indeed, but as long as you are being launched by other people it is
their responsibility to assess your request and, if it's unsafe,
refuse it, just as it would be their duty to refuse to launch you if
you were drunk, or if your airbrakes were open.
Launch
On the contrary, I believe that launch marshalls /should/ decide.
Nobody should be complicit in dangerous behaviour of this sort.
Well good luck - and here's hoping that by the time you pull the knob
the hook (and wheel on an ASW20?) isn't on its way to the ground along
with sundry control connections. That's if a good unexpected bump on
the way up hasn't taken your wings off.
Ian
  #196
Old July 5th 05, 05:35 PM
Bert Willing
First of all, if the weak link breaks, the overload would be 33% (I don't
know what you do to get 50-75%).
Secondly, the point is not to get the weak link breaking at all. As long as
you stay within the limits of max winch tow speed, the overload is zero.
You might be not aware, but there is a good number of clubs who don't use
any weak links _at all_ (or launch marshalls...).
And I stand my point - it is my responsability to deal with my security, my
insurance and my legal authorities. Good luck? Go tell that to those who had
an accident initiated by a weak link failure. After 25 years of flying, I
still have to learn about a case of structural overload during winch launch.
However, I can accept that if I don't fly my glider, that I am imposed to
the owner's rules.
Bert Willing
ASW20 "TW"
dzZo7CxomoOm-pn2-8g13dep07KYM@localhost...
Launch
of
Ian
  #197
Old July 5th 05, 05:36 PM
Ian Johnston
On Tue, 5 Jul 2005 15:59:24 UTC, M B
The Tost system uses two in parallel, one slightly longer than the
other. Whoever hooks up the glider should always check that both links
are intact and that only one is taking the load.
Ian
  #198
Old July 5th 05, 05:57 PM
F.L. Whiteley
Ian
We've gone to using a single TOST weak link. Over the years, the metal
sleeve gets dented, making inspection suspect without a time consuming
disassembly. A few times the links part without any warning that perhaps
the first may have failed previously. We have also had both fail at the
same time when going through a sharp wind gradient. We replaced both and
broke both on the very next launch through this sharp gradient. At the
price of the weak links, consuming one at a time, rather than two, just
makes more sense.
NDT would work if you jigged up an accurate test bed. I would be more
concerned with rope weak links used in aerotowing than TOST weak links if I
wanted to test something. From many years of observation I'm pretty
confident that the TOST links perform as expected.
Frank
  #199
Old July 5th 05, 06:03 PM
F.L. Whiteley
as you stay within the limits of max winch tow speed, the overload is
zero. You might be not aware, but there is a good number of clubs who
don't use any weak links _at all_ (or launch marshalls...).
my insurance and my legal authorities. Good luck? Go tell that to those
who had an accident initiated by a weak link failure. After 25 years of
flying, I still have to learn about a case of structural overload during
winch launch. However, I can accept that if I don't fly my glider, that I
am imposed to the owner's rules.
Interesting. I find it odd that German rules, which are often clearly more
strict than other soaring environs, would allow this departure.
Frank
  #200
Old July 5th 05, 06:11 PM
Ian Johnston
On Tue, 5 Jul 2005 16:35:18 UTC, "Bert Willing"
I said already. The overload on the aircraft as a whole is 33%,
However, that's a lot more than 1.3G structurally, because at 1.3G
much of the applied load is on, and then balanced by, the wings.
Except you can stay within that limit with 250dN load more on the
winch hook and the wing attachments than the designers of the aircraft
thought safe.
Would you fly with 250kg of unofficial extra ballast in the fuselage?
Then they are idiots.
Ian
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
