What everyone said.
Often you can quickly figure it out graphically by noting the alignment of the runways. The sectors will often map to the runway alignment in an easily discerned way. AliR wrote: I can never get this right! When the airport list's it's approach freq like this 123.75 (320-152) 119.9 (153-319) does that mean that I should call 123.75 if my heading is between 320 and 152 or the opposite? AliR |
Thanks for the clarifications.
After reading the answers, I was thinking that I can quickly figure out the one that I need to contact by finding the reciprocal of my heading in the different ranges. Say I am flying 090, the reciprocal will be 270 which would be 119.9 Would that work in all cases? Or are there odd shaped approch regions? AliR. "Maule Driver" wrote in message m... What everyone said. Often you can quickly figure it out graphically by noting the alignment of the runways. The sectors will often map to the runway alignment in an easily discerned way. AliR wrote: I can never get this right! When the airport list's it's approach freq like this 123.75 (320-152) 119.9 (153-319) does that mean that I should call 123.75 if my heading is between 320 and 152 or the opposite? AliR |
Evidently the clarification wasn't clear enough. ;-) It has nothing to do
with your heading, but everything to do with where you are in relation to the airport. You could have a easterly (90 degree) heading west of the airport, east of the airport, north of the airport, south of the airport, or some combination of those. The heading has nothing to do with what frequency to use. Where you are in relation to the airport (what sector) does. If you are right of, North-West (320) to South-East (152) of the airport, then use frequency 123.75. Otherwise use 119.9 (153-319). - Steve "AliR" wrote in message ... Thanks for the clarifications. After reading the answers, I was thinking that I can quickly figure out the one that I need to contact by finding the reciprocal of my heading in the different ranges. Say I am flying 090, the reciprocal will be 270 which would be 119.9 Would that work in all cases? Or are there odd shaped approch regions? AliR. "Maule Driver" wrote in message m... What everyone said. Often you can quickly figure it out graphically by noting the alignment of the runways. The sectors will often map to the runway alignment in an easily discerned way. AliR wrote: I can never get this right! When the airport list's it's approach freq like this 123.75 (320-152) 119.9 (153-319) does that mean that I should call 123.75 if my heading is between 320 and 152 or the opposite? AliR |
I wasn't thinking that far ahead. I was thinking about approaching the
airport. As of yet I haven't passed the airport before deciding to call up approach. ;-) But that is a good point. I am always on the lookout for finding shortcuts, to make my work load less. AliR. "Stephen McNaught" wrote in message ... Evidently the clarification wasn't clear enough. ;-) It has nothing to do with your heading, but everything to do with where you are in relation to the airport. You could have a easterly (90 degree) heading west of the airport, east of the airport, north of the airport, south of the airport, or some combination of those. The heading has nothing to do with what frequency to use. Where you are in relation to the airport (what sector) does. If you are right of, North-West (320) to South-East (152) of the airport, then use frequency 123.75. Otherwise use 119.9 (153-319). - Steve "AliR" wrote in message ... Thanks for the clarifications. After reading the answers, I was thinking that I can quickly figure out the one that I need to contact by finding the reciprocal of my heading in the different ranges. Say I am flying 090, the reciprocal will be 270 which would be 119.9 Would that work in all cases? Or are there odd shaped approch regions? AliR. "Maule Driver" wrote in message m... What everyone said. Often you can quickly figure it out graphically by noting the alignment of the runways. The sectors will often map to the runway alignment in an easily discerned way. AliR wrote: I can never get this right! When the airport list's it's approach freq like this 123.75 (320-152) 119.9 (153-319) does that mean that I should call 123.75 if my heading is between 320 and 152 or the opposite? AliR |
In that specific case, heading directly, with no wind correction, to the
airport, than your method would work. For me, it is just as easy, and has more versatility, to visualize the sectors around the airport, know which of those sectors I'm in, and use the appropriate frequency. We all look for methods that decrease our work load. Good luck. - Steve "AliR" wrote in message ... I wasn't thinking that far ahead. I was thinking about approaching the airport. As of yet I haven't passed the airport before deciding to call up approach. ;-) But that is a good point. I am always on the lookout for finding shortcuts, to make my work load less. AliR. |
![]() "AliR" wrote in message ... Thanks for the clarifications. After reading the answers, I was thinking that I can quickly figure out the one that I need to contact by finding the reciprocal of my heading in the different ranges. Say I am flying 090, the reciprocal will be 270 which would be 119.9 Would that work in all cases? Or are there odd shaped approch regions? AliR. That will only work if you are heading directly towards the airport. |
Nope. It makes not a bit of difference what your heading is. What makes a
difference is what the bearing FROM the airport in question is. Let's presume a simple case. If you are anywhere west through east and SOUTH of a particular airport, the approach frequency is 123.0. If you are anywhere west throught east and NORTH of that airport, the approach frequency is 123.5. Now, you are due NORTH of the airport and inbound, so the approach frequency is 123.5. If you turn 180d around and fly AWAY from the airport, your heading changes 180d but the frequency remains the same. It is the SECTOR and not the HEADING that make the difference. Jim "AliR" wrote in message ... Thanks for the clarifications. After reading the answers, I was thinking that I can quickly figure out the one that I need to contact by finding the reciprocal of my heading in the different ranges. |
SNA VFR approach frequency | abripl | Piloting | 2 | March 20th 05 09:22 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Canadian holding procedures | Derrick Early | Instrument Flight Rules | 24 | July 22nd 04 04:03 PM |
Boston Approach frequency question | John R | Piloting | 6 | June 22nd 04 08:22 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
