"Icebound" wrote: But the question really was: what are the consequences? Does it typically lug and die, or will it lug and lumber upward slowly, or do I get one of the above plus twist the crank, etc.??? Do I get away with it? None of the time? Most of the time? Once in while? I suppose it depends. G Pressures in the cylinder will be higher than normal, if taken to extremes you might crack a cylinder. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Precision Landings and practice | [email protected] | Piloting | 34 | December 17th 04 02:08 PM |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 01:48 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
