![]() "John Doe" wrote in message link.net... I would agree with that to a point. If it's IFR conditions and you're trying to get in to land, you might have to hold as ATC tries to work you into the approach. As you hold, ATC will be contacting the military aircraft in the MOA to try and deconflict to get you IFR seperation. You will hold outside the MOA until ATC can work that. What do you base that on? I am not an ATC controller, but most military talks on UHF on their primary radio and VHF by exception. Some jets don't even have VHF. The controller might not be simulcasting his transmissions to the military pilots on VHF, that's probably why you're not hearing them. But I can promise you, ATC is working with them. What puts you in a position to make that promise? |
