New Battery -- thanks for the recommendation
Old July 7th 05, 01:41 PM
David Lesher
"RST Engineering" writes:
but the stuff of choice is plain old
Arm&Hammer baking soda at about a 10% concentration in water. When it stops
bubbling with each fresh application, you is done.
Nod... On cars, I leave some baking soda in place, for future leaks.
The only good news is aircraft are largely aluminum and at least the
mild acid in batteries has little effect on same. Alkali, however....
(Soaking in a tank of 180+F lye is often used to degrease/depaint/derust
{steel} engine blocks. Just be VERY sure that the aluminum pistons etc.
are not attached...or you'll see why...)
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
Battery life...how to test? Jim Kelly Soaring 2 July 11th 03 09:12 PM
