"Fred Choate" wrote in message
... Here is a topic that was of discussion at work today: How much is too much over gross weight? For example.....the 172 has a gross weight of 2300 lbs, but what if you are 2345 at time of takeoff.....is that too much over, even if you are going to be burning enough fuel before your first scheduled stop to be under weight for landing? The "...you are a test pilot" phrase applies to many situations, including going over gross weight. Assuming a non-emergency situation, you fly the airplane by the book. That means, even one pound over max gross is too much. Let's say after landing at a remote airport, you stumbled upon an organized-crime pot growing operation, along with a kidnap victim they kept. Just as you are untying the victim, you are discovered. You and the victim run to the plane, but just as you are getting ready to take off, having narrowly escaped your pursuers, you realize that with your additional passenger, you may be as much as 50 or 100 pounds overweight. Do you at that point shut down the airplane, get out and let yourselves be tied up again by the mobsters? I sure hope not! ![]() There may be moments when being a test pilot is appropriate. In those moments, you should be aware of the effects of the extra weight. To some extent, if you've ever flown the airplane at max gross as well as at lower weights, you already have an idea of the change in performance. The 2% overage you describe will produce a noticeable reduction in performance, but probably nothing that even an average pilot can't accomodate (assuming you're not cutting things too close already). A 10% overage is likely to create significant problems; one can prepare for them (and many pilots have, for the purpose of ferrying airplanes long distances for example), but should attempt only after calculating exactly what the new performance figures will be, and with adequate planning for the flight itself (assuming the drug runners aren't chasing you, that is...in that case, I suppose you can just play it off the cuff ![]() None of that implies that over-gross operations, even by a small margin, are to be taken lightly. When ferry pilots operate over-gross, they do so with a special exception granted by the FAA. This isn't a normal operation, and the fact that some pilots do it doesn't mean it can be done safely by any other random pilot (and certainly doesn't mean it can be done legally). Even ignoring the safety issues, I agree it was entirely irresponsible for your instructor to teach you to fly over gross. And make no mistake, he was *teaching* you to do that. It only makes it worse that he taught it very poorly, not even bothering to address the actual performance issues related to flying over-gross (other than to let you suffer through them). I don't know what kind of discussion you were expecting, but IMHO for standard operations, there is simply no amount of excess weight above max gross that is reasonable. Pete |
Thanks for the comments. I am beginning to feel as if my initial post is
being interpreted as if I wanted to be "re-assured" that flying over gross is okay. That is not what I meant to convey, nor is that ever my intentions. I simply was having a discussion at work about weight in aircraft, and it turned out to be a good discussion there, so I thought it might be one here as well. I know what is legal. And I also know that I never intend on flying over gross. But, I would bet that there are alot of pilots out there that have come up against the max weight, and struggled with this exact decision......."I am only 25 lbs over the max.....will that be okay". Now, if a pilot does that, and the plane fly's 'okay', then the next time, that same pilot may say "well, it flew okay with 25 over, it will probably be okay at 45 over....." and so on. Fred "Peter Duniho" wrote in message ... "Fred Choate" wrote in message ... Here is a topic that was of discussion at work today: How much is too much over gross weight? For example.....the 172 has a gross weight of 2300 lbs, but what if you are 2345 at time of takeoff.....is that too much over, even if you are going to be burning enough fuel before your first scheduled stop to be under weight for landing? The "...you are a test pilot" phrase applies to many situations, including going over gross weight. Assuming a non-emergency situation, you fly the airplane by the book. That means, even one pound over max gross is too much. Let's say after landing at a remote airport, you stumbled upon an organized-crime pot growing operation, along with a kidnap victim they kept. Just as you are untying the victim, you are discovered. You and the victim run to the plane, but just as you are getting ready to take off, having narrowly escaped your pursuers, you realize that with your additional passenger, you may be as much as 50 or 100 pounds overweight. Do you at that point shut down the airplane, get out and let yourselves be tied up again by the mobsters? I sure hope not! ![]() There may be moments when being a test pilot is appropriate. In those moments, you should be aware of the effects of the extra weight. To some extent, if you've ever flown the airplane at max gross as well as at lower weights, you already have an idea of the change in performance. The 2% overage you describe will produce a noticeable reduction in performance, but probably nothing that even an average pilot can't accomodate (assuming you're not cutting things too close already). A 10% overage is likely to create significant problems; one can prepare for them (and many pilots have, for the purpose of ferrying airplanes long distances for example), but should attempt only after calculating exactly what the new performance figures will be, and with adequate planning for the flight itself (assuming the drug runners aren't chasing you, that is...in that case, I suppose you can just play it off the cuff ![]() None of that implies that over-gross operations, even by a small margin, are to be taken lightly. When ferry pilots operate over-gross, they do so with a special exception granted by the FAA. This isn't a normal operation, and the fact that some pilots do it doesn't mean it can be done safely by any other random pilot (and certainly doesn't mean it can be done legally). Even ignoring the safety issues, I agree it was entirely irresponsible for your instructor to teach you to fly over gross. And make no mistake, he was *teaching* you to do that. It only makes it worse that he taught it very poorly, not even bothering to address the actual performance issues related to flying over-gross (other than to let you suffer through them). I don't know what kind of discussion you were expecting, but IMHO for standard operations, there is simply no amount of excess weight above max gross that is reasonable. Pete |
![]() Peter Duniho wrote: Let's say after landing at a remote airport, you stumbled upon an organized-crime pot growing operation, along with a kidnap victim they kept. Just as you are untying the victim, you are discovered. You and the victim run to the plane, but just as you are getting ready to take off, having narrowly escaped your pursuers, you realize that with your additional passenger, you may be as much as 50 or 100 pounds overweight. As I was reading this I was enjoying a nice mental image of "rescuing the damsel in distress"... until I got to the part about "50 or 100 pounds overweight". Doh! -R |
"Rob" wrote in message
ups.com... As I was reading this I was enjoying a nice mental image of "rescuing the damsel in distress"... until I got to the part about "50 or 100 pounds overweight". Doh! What's the problem? There are dozens of ways that still works. A six-foot goddess could add a lot of weight, while still being quite the "damsel". ![]() If you're 50 pounds overweight, you might have only been 50 or 100 pounds below max weight in the first place (depending on height, 150 pounds could be a weight still well within societal norms of beauty, and certainly weights between 100 and 150 are). Or, to be quite frank about it, you might find that a person can be plump and yet still quite the damsel. Personally, I favor the "six foot goddess" scenario, but please feel free to choose your own. ![]() Pete |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
