![]() "once you go over the max weight, you are essentially a test pilot". That's putting it a bit strongly. As long as the CG issues are OK, the effects of being reasonably over-weight are quite predictable in terms of stall speed, take-off requirements etc. The structural issues won't come into it as many aircraft have their max gross determined by other things (eg. stall speed low enough for Part 23, or the need to go-around at max gross with full flaps) and in any case, there's a large safety margin in there. The fact is that assuming you're not on the edge re DA or runway length, 5% overweight is going to be safe. It isn't legal, but it will be safe. As to the arguement that breaking one rule leads to breaking another, with respect, that is nonsense. That's like saying speeding leads to murder... |
"Mike Granby" wrote in message
oups.com... "once you go over the max weight, you are essentially a test pilot". That's putting it a bit strongly. No, it's putting it quite accurately. As long as the CG issues are OK, the effects of being reasonably over-weight are quite predictable in terms of stall speed, take-off requirements etc. The effects of flight at any weight are quite predictable in terms of stall speed, take-off requirements etc. And yet, during certification, the airplane is required to be *tested* at in a variety of configurations by a *test pilot* to demonstrate the actual performance. Just because one can predict the performance, that doesn't change the fact that a person flying an airplane in an untested (as far as they know) configuration is a "test pilot". The structural issues won't come into it as many aircraft have their max gross determined by other things (eg. stall speed low enough for Part 23, or the need to go-around at max gross with full flaps) Very few single-engined airplanes have a stall speed at the maximum allowed value (noting, of course, that the "maximum allowed value" isn't really so much a hard limit, but rather one that a manufacturer is required to meet in order to avoid other things). It's true that max gross weight may be affected by things other than structural issues, but there is no way to know whether this is true without consulting the manufacturer (which I doubt the theoretical over-gross pilot is going to do), and I can think of at least one common airplane for which structural issues DO limit the maximum landing weight (which is lower than the maximum takeoff weight for that airplane). and in any case, there's a large safety margin in there. The reason for that safety margin is for normal, legal weight operations. It's not so you can operate over the legal limits. Operate over the legal weight, and you've just abandoned your "large safety margin". The fact is that assuming you're not on the edge re DA or runway length, 5% overweight is going to be safe. It isn't legal, but it will be safe. It *might* be safe. You are still a test pilot when flying over the legal weight, which is the comment to which you replied. As to the arguement that breaking one rule leads to breaking another, with respect, that is nonsense. That's like saying speeding leads to murder... That's a matter of opinion, I guess. I personally believe that if we had better enforcement of the little laws, we wouldn't have so many people disregarding the more important ones. Looking the other way when it comes to speeding (and similar) simply teaches people disregard for rules. Each person winds up setting their own limits, rather than respecting the limits society claims to have made. And yes, in some cases, those limits go way beyond just speeding. Obviously each individual who speeds doesn't wind up a murderer, but general disregard for the rules does certainly lead to other negative behavior. Pete |
![]() Actually, I don't believe flying at max gross is necessarily safe either. If you have ever flown slightly gross weight, then you have already flown as a test pilot. First, the official weight and balance is probably decades old, and your aircraft most likely weighs several pounds more now. Second, people under-estimate their weight. Unless you have a weighing scale as people board, you can never be sure of the actual weight. Finally, the aircraft is far different from when it was tested during manufacture. A dirty airframe will reduce performance, and an old prop will not work as well as a brand new one. Most importantly, your engine definitely will not perform like a brand new engine. So, whether you like it or not, you have already been a test pilot. For this reason, I never fly an aircraft near its max gross. I have seen pilots diligently trying to unload weight until it is exactly equal to the max gross weight. "Peter Duniho" wrote in : "Mike Granby" wrote in message oups.com... "once you go over the max weight, you are essentially a test pilot". That's putting it a bit strongly. No, it's putting it quite accurately. As long as the CG issues are OK, the effects of being reasonably over-weight are quite predictable in terms of stall speed, take-off requirements etc. The effects of flight at any weight are quite predictable in terms of stall speed, take-off requirements etc. And yet, during certification, the airplane is required to be *tested* at in a variety of configurations by a *test pilot* to demonstrate the actual performance. Just because one can predict the performance, that doesn't change the fact that a person flying an airplane in an untested (as far as they know) configuration is a "test pilot". The structural issues won't come into it as many aircraft have their max gross determined by other things (eg. stall speed low enough for Part 23, or the need to go-around at max gross with full flaps) Very few single-engined airplanes have a stall speed at the maximum allowed value (noting, of course, that the "maximum allowed value" isn't really so much a hard limit, but rather one that a manufacturer is required to meet in order to avoid other things). It's true that max gross weight may be affected by things other than structural issues, but there is no way to know whether this is true without consulting the manufacturer (which I doubt the theoretical over-gross pilot is going to do), and I can think of at least one common airplane for which structural issues DO limit the maximum landing weight (which is lower than the maximum takeoff weight for that airplane). and in any case, there's a large safety margin in there. The reason for that safety margin is for normal, legal weight operations. It's not so you can operate over the legal limits. Operate over the legal weight, and you've just abandoned your "large safety margin". The fact is that assuming you're not on the edge re DA or runway length, 5% overweight is going to be safe. It isn't legal, but it will be safe. It *might* be safe. You are still a test pilot when flying over the legal weight, which is the comment to which you replied. As to the arguement that breaking one rule leads to breaking another, with respect, that is nonsense. That's like saying speeding leads to murder... That's a matter of opinion, I guess. I personally believe that if we had better enforcement of the little laws, we wouldn't have so many people disregarding the more important ones. Looking the other way when it comes to speeding (and similar) simply teaches people disregard for rules. Each person winds up setting their own limits, rather than respecting the limits society claims to have made. And yes, in some cases, those limits go way beyond just speeding. Obviously each individual who speeds doesn't wind up a murderer, but general disregard for the rules does certainly lead to other negative behavior. Pete |
"Andrew Sarangan" wrote in message
1... Actually, I don't believe flying at max gross is necessarily safe either. I can certainly agree with that. There's safe, and there's legal. Safe is not always legal, and legal is not always safe. As a pilot, it is our duty (in my opinion) to take the more conservative of either limitation, except under duress (in which case it could still be argued the chosen action is still the most conservative action available at the moment). Pete |
At the same time, if an airplane can fly safely at MGW with an
underpowered engine and a dirty airframe, what prevents an airplane maintained to a higher standard from flying slightly above MGW? I am not suggesting that people try this, but except from a regulatory point of view, what is the real difference between these two scenarios? |
underpowered engine and a dirty airframe, what prevents an airplane maintained to a higher standard from flying slightly above MGW? I am not suggesting that people try this, but except from a regulatory point of view, what is the real difference between these two scenarios? It depends on what the actual limiting factor is. If there is a structural member that is the limiting factor, more engine power and a cleaner airframe won't make a difference. What I can see more easily is, for situations where (say) takeoff aerodynamics is the first limiting factor, a graph of MGW vs density altitude. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
oups.com... At the same time, if an airplane can fly safely at MGW with an underpowered engine and a dirty airframe, what prevents an airplane maintained to a higher standard from flying slightly above MGW? I am not suggesting that people try this, but except from a regulatory point of view, what is the real difference between these two scenarios? I guess that depends on whom you ask. I already stated that I didn't feel the 2% overage example given in the original post was likely to cause problems for most pilots. I think it ought to be obvious to the most casual observer that in reality, flying a pound or so over max gross is, for all intents and purposes, the same thing as flying right at max gross. Performance suffers in a continuously gradual way as weight increases. There's nothing magical about the certificated max gross weight that changes a safe plane into an unsafe plane at the moment you cross that line. But there IS a limit to how safe the plane is as you increase its weight. There IS a weight above which you should not be flying the plane, even from a safety standpoint. The manufacturer and the FAA have drawn a very clear line for the pilot to mark that maximum weight, and it is the pilot's responsibility to respect that line. A pilot's personal judgment may place that line somewhere else. But they do not have the legal ability to put that line at a higher weight than the manufacturer and FAA have put it. While piloting is in many respects all about making individual judgment calls in order to establish the safety of the flight, that is not ALL that it is about. Not today, and it hasn't been for a long time. Pilots have a responsibility to ensure that the flight remain safe AND legal. The maximum certificated weight of the airplane is a somewhat arbitrary line. Yes, it could have been set a little lower or a little higher, with very little practical effect on airplane performance. But for better or for worse, it is set where it is set. A responsible pilot will respect that. Pete |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
