Gross Weight
Old July 8th 05, 08:08 PM
Frank Ch. Eigler
"Michael" writes:
[...] In other words, the idea that you're uninsured when overgross
is a myth. You're covered if you are drunk, overgross, and fly into
an airport without a clearance. Exemptions are clearly stated.
As a contrary data point, my (Canadian Marsh/Lloyds) insurance
includes an explicit requirement to stay within W&B limits to retain
coverage.
- FChE
Old July 9th 05, 01:51 AM
Mike Granby
insurance includes an explicit requirement to stay within
W&B limits to retain coverage.
Which may or may not be enforcable, depending on state laws. It is
true, thought, that some carrier demand in-envelope operation, and that
others required the airworthiness cert to be in full force and effect,
and then argue that over-weight operation voids said cert. Again,
whether this latter approach would work would depend on the state.
Avemco, though, specifically say that you can be over-weight and
they'll still pay. And no-one has yet produce an example of *any*
company failing to pay as a result of an aircraft being over-weight....
Old July 9th 05, 01:55 AM
Doug
Has anyone identified an accident that was caused by being overweight.
Are they common? Certainly not as common as running out of fuel.
Old July 9th 05, 03:03 AM
Ron Rosenfeld
Plenty of accidents caused by being outside of the CG envelope.
I recall a Bonanza that crashed on takeoff leaving KASH with a load of NH
tax-free liquor.
Old July 9th 05, 01:32 PM
Mike Granby
by being overweight. Are they common?
I've read of quite a few where over-weight operation combined with high
DA to result in an aircraft either running off the end of the runway on
take-off, or, worse, getting into the air and then spinning in upon
being unable to maintain a climb. I am quite convinced that over-weight
operation will cause accidents; I'm not convinced it results in
accidents as a result of structural failure.
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Apache Alternate Gross Weight Jim Burns Owning 1 July 6th 04 05:15 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
