Morgans wrote:
If the receiver is in the Garmin, then that alot of stuff packed in there, plus another monthly subscription... I think we are talking about two different things. I was talking about the fact that while connected to XM for data, with a music subscription, you can take a music feed from the 396 to you choice of listening connections. Reading the "quick reference" .pdf, you sir are correct, it has an internal XM Radio receiver, however you'll need to turn off the XM Weather to activate the receiver... So I wonder if they are tossing in the XM Radio subscription for free with the weather package? Accepts TIS traffic uploads from A GTX 330 transponder, uploads VHF frequency data to a SL30/40 com, DSC Marine VHF connectivity, marine Sonar connectivity (think amphib)... This unit is very k3wl indeed... |
"...however you'll need to turn off the XM Weather to activate the
receiver..." Sorry, but that's not correct. Turning XM Weather on/off and using XM Radio just happen to appear on the same page in the Quick Ref, but there is no correlation between the two. Obviously, you will need to leave the Map Page where the weather data is displayed in order to go to the XM Audio Page. The XM Audio page is where you select your channels, and it also has a Mute/Enable audio output selection, which determines whether the radio is heard. Once you have tuned the XM radio and Enabled audio output, the radio will continue to play even if you leave the XM Audio page and return to the Map Page to view the weather... "Darrel Toepfer" wrote in message .. . Morgans wrote: If the receiver is in the Garmin, then that alot of stuff packed in there, plus another monthly subscription... I think we are talking about two different things. I was talking about the fact that while connected to XM for data, with a music subscription, you can take a music feed from the 396 to you choice of listening connections. Reading the "quick reference" .pdf, you sir are correct, it has an internal XM Radio receiver, however you'll need to turn off the XM Weather to activate the receiver... So I wonder if they are tossing in the XM Radio subscription for free with the weather package? Accepts TIS traffic uploads from A GTX 330 transponder, uploads VHF frequency data to a SL30/40 com, DSC Marine VHF connectivity, marine Sonar connectivity (think amphib)... This unit is very k3wl indeed... |
Lakeview Bill wrote:
"...however you'll need to turn off the XM Weather to activate the receiver..." Sorry, but that's not correct. Turning XM Weather on/off and using XM Radio just happen to appear on the same page in the Quick Ref, but there is no correlation between the two. Obviously, you will need to leave the Map Page where the weather data is displayed in order to go to the XM Audio Page. The XM Audio page is where you select your channels, and it also has a Mute/Enable audio output selection, which determines whether the radio is heard. Once you have tuned the XM radio and Enabled audio output, the radio will continue to play even if you leave the XM Audio page and return to the Map Page to view the weather... Thanks for the correction... And at the bottom of the page it mentions seperate subscriptions for Music and Weather... The PDF for the GXM30 antenna shows some additional screen shots... |
![]() The 396 manual is now available on Garmin's website and it contains lots of screen pictures. -------------------- Richard Kaplan www.flyimc.com |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
