In this thread you mention syncing the 430 to the 396. I can not find
any documentation or installer who is aware this can be done. Can you point me in the right direction for some info? Thanks, Mike Burrill Richard Kaplan wrote: "Jonathan Goodish" wrote For a portable weather system--no question about it. However, if you're an aircraft owner and never move the weather system, it's a moot point. Less significant, yes. Moot, no. It is still a piece of equipment which needs either a quasi-permanent power connection to ship's power or else regular recharging or replacing of batteries. None of this is relevant for renter pilots. If I'm considering a 396 primarily for weather, why wouldn't I use a small TabletPC, which has a superior display and orientation compared with the 396, and WxWorx on Wings software, which provides a superior weather display? Throw a small Bluetooth GPS on the glare shield and you can see where you are in It is relevant to renter pilots in particular because it is by far the easiest way to put both GPS navigation and weather in a rental airplane. Sure you can set up an XM receiver, Bluetooth GPS, and PDA whenever you rent a plane, but that is a lot more work then plugging in a 396 relation to the weather. Entering a flight plan into a Tablet or PDA isn't a big deal Yes it is if you are talking about an IFR situation when you need to enter flight plan or navaid info into panel-mount IFR equipment and then duplicate it in a portable GPS and then reprogram both when you receive changes in routings or approach clearances enroute. For VFR flight this is not a huge issue; for IFR flight the convenience from the crossfed data is HUGE. and I probably wouldn't hesitate to use the Tablet or PDA for primary enroute navigation if I had a panel mount that wasn't doing anything other than navigation anyway. That is fine for VFR but not IFR. sure how that would be much different for VNAV guidance than using a Garmin portable--unless you're referring to specific software features in the Garmin. Yes, I am referring to the "Vertical Speed to Target" feature of the Garmin portables (and some Lowrance units as well). This is a highly desirable feature for executing a deadstick landing when VFR or especially IFR or at night. I'm not saying there aren't advantages to the Garmin portables, but if I had an IFR panel mount, I'm not sure that I'd run out and drop $2500 on a Garmin portable just so that it can sync my flight plan. If you had a Garmin 430 or 530 in your panel, it would be downright silly not to add a Garmin portable GPS given the advantages it offers.. it could be any portable model since the 195. Once it is a given that you add a Garmin portable, then it does not make much sense to have a Garmin portable GPS for backup nav and a separate portable weather system. The realistic options at that point are either a Garmin 396 or else an older Garmin portable GPS plus panel-mount weather. renter pilot, the 396 would be an ideal system due to its easy portability. If I was an owner serious about certified weather uplink and features not available on the 430/530, I think I'd investigate selling the 430/530 and buying another certified system that can better serve my needs. There is no such thing as certified weather uplink -- it is easier panel or portable. Weather on the 430/530 themselves are marginal. The apparent best IFR panel weather datalink options at this point are either a Garmin 430/530 coupled to panel-mount EX500 multi-function display for weather (an expensive option) or else a Garmin 430 coupled to a 396 portable for weather and terrain. no obstacles, terrain, or weather capability, so it has been relegated to storage. That is one of the key points... the terrain feature of the 296 is stupendous and ought to be considered the Product of the Year -- in many ways its terrain implementation is superior to that on much more expensive panel solutions such as an MX20 or an EX500. -------------------- Richard Kaplan www.flyimc.com |
![]() The Garmin 430/530 installation manual documents a connection from the 430/530 serial output to the 195/295/296/396/196 serial input. Set the 430/530 to "Aviation Out" and the handheld to "Aviation In" and use the combined data/power cable available from Garmin. It should take less than 2 hours of avionics tech time and under $100 of parts. -------------------- Richard Kaplan www.flyimc.com |
The finished install with the permanent data/power cable looks like this:
www.flyimc.com/newpanel.html -------------------- Richard Kaplan www.flyimc.com |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
