Try just OTP. The actual altitude is not needed.
Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
OK, I'll try, but it used to work.
"Newps" wrote in message ... Try just OTP. The actual altitude is not needed. Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
I tried it and OTP is accepted. However, I then tried OTP/125, and that was
also accepted, as was VFR/125 (for FF). I just had the order of the subfields switched in my head. Apparently nothing has changed. Stan "Newps" wrote in message ... Try just OTP. The actual altitude is not needed. Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
There's no reason to put an altitude in when you're OTP. ATC knows you
may need to change altitudes for clouds, winds, etc. Stan Prevost wrote: I tried it and OTP is accepted. However, I then tried OTP/125, and that was also accepted, as was VFR/125 (for FF). I just had the order of the subfields switched in my head. Apparently nothing has changed. Stan "Newps" wrote in message ... Try just OTP. The actual altitude is not needed. Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
If I put the desired altitude in the plan, then the controller knows that I
want 12500 and can tell me to "maintain VFR On Top at or below 12500". If I don't put it in, then he has to ask me what altitude I want or just arbitrarily assigns me something and then if it's not what I want we have to go through more radio exchange. How is it better to not include the altitude? "Newps" wrote in message ... There's no reason to put an altitude in when you're OTP. ATC knows you may need to change altitudes for clouds, winds, etc. Stan Prevost wrote: I tried it and OTP is accepted. However, I then tried OTP/125, and that was also accepted, as was VFR/125 (for FF). I just had the order of the subfields switched in my head. Apparently nothing has changed. Stan "Newps" wrote in message ... Try just OTP. The actual altitude is not needed. Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
Include what you *think* the weather conditions *might* allow your VFR
cruising altitude to be if you feel like it but "VFR-On-Top" alone is your *requested/assigned* IFR altitude. Once you report reaching VFR-On-Top and the controller reclears to to "Maintain VFR-On-Top" he isn't responsible for separation. After that he doesn't really care much what your actual altitude is now or might be later (beyond verifying your Mode C for traffic or idle curiosity). Any altitude restrictions issued *before* you reach VFR-On-Top are a different matter. "Stan Prevost" wrote in message ... If I put the desired altitude in the plan, then the controller knows that I want 12500 and can tell me to "maintain VFR On Top at or below 12500". If I don't put it in, then he has to ask me what altitude I want or just arbitrarily assigns me something and then if it's not what I want we have to go through more radio exchange. How is it better to not include the altitude? "Newps" wrote in message ... There's no reason to put an altitude in when you're OTP. ATC knows you may need to change altitudes for clouds, winds, etc. Stan Prevost wrote: I tried it and OTP is accepted. However, I then tried OTP/125, and that was also accepted, as was VFR/125 (for FF). I just had the order of the subfields switched in my head. Apparently nothing has changed. Stan "Newps" wrote in message ... Try just OTP. The actual altitude is not needed. Stan Prevost wrote: I used to use DUAT to file flight plans for VFR Flight Following and VFR On Top. Not long ago, they changed their software. Now I can't get it to accept an OTP flight plan. Haven't tried FF. Example: Yesterday I filed an IFR plan having altitude field of 125/OTP. It rejected it. It accepted 125 for altitude, but I had to put "VFR On Top" in Remarks. Anyone else have this problem with DUAT? I haven't tried DUATS. Stan |
"Maintain VFR-On-Top" he isn't responsible for separation. After that he doesn't really care much what your actual altitude is now or might be later (beyond verifying your Mode C for traffic or idle curiosity). Maybe so, but you're required to report changing altitudes when flying VFR-On-Top (at least, per the AIM)... -- Cheers, John Clonts Temple, Texas N7NZ |
![]() "John Clonts" wrote in message oups.com... Maybe so, but you're required to report changing altitudes when flying VFR-On-Top (at least, per the AIM)... The AIM says pilots SHOULD advise ATC prior to any altitude change when operating OTP. |
![]() "KP" nospam@please wrote in message ... Include what you *think* the weather conditions *might* allow your VFR cruising altitude to be if you feel like it but "VFR-On-Top" alone is your *requested/assigned* IFR altitude. Once you report reaching VFR-On-Top and the controller reclears to to "Maintain VFR-On-Top" he isn't responsible for separation. After that he doesn't really care much what your actual altitude is now or might be later (beyond verifying your Mode C for traffic or idle curiosity). I have never received a clearance for just "VFR On Top" without further restrictions, although I understand it is permitted. Restrictions can be "Maintain VFR On Top at or below xxx", "....at or above xxx", or "... at or between xxx and yyy". I understand that the controller is not responsible for separation, so I wonder why I always get an altitude restriction, usually "at or below". Stan |
![]() Stan Prevost wrote: I have never received a clearance for just "VFR On Top" without further restrictions, although I understand it is permitted. I can't understand why you'd restrict an aircraft, outside of a class B. Restrictions can be "Maintain VFR On Top at or below xxx", "....at or above xxx", or "... at or between xxx and yyy". Yes, but what's the point? I don't have to separate you so why restrict you? I understand that the controller is not responsible for separation, so I wonder why I always get an altitude restriction, usually "at or below". Ask next time. |
Duat Graphics | Slick | Piloting | 0 | January 23rd 05 01:35 PM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
DTC DUAT | Matt Whiting | Instrument Flight Rules | 0 | June 5th 04 03:23 PM |
Picking Optimal Altitudes | O. Sami Saydjari | Instrument Flight Rules | 20 | January 8th 04 02:59 PM |
