Generally, if it is not excluded, it is covered. So look in the
exclusions. Mine does not have an exclusion for over maximum weight. So I am covered. |
But does an exclusion requiring the aircraft to be operated in accordance
with it's type certificate? That will exclude overgross operations. So will an exclusion requiring operation in accordance with the FARs... "Doug" wrote in message oups.com... Generally, if it is not excluded, it is covered. So look in the exclusions. Mine does not have an exclusion for over maximum weight. So I am covered. |
No such exclusions for those either.
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
