I've taxied back from run up more than once: if it ain't right, don't
do it! |
"Tony" wrote in message
oups.com... I've taxied back from run up more than once: if it ain't right, don't do it! I have as well. Though, one time I had to leave the plane at the run-up pad, because the parking brake cable came loose with the brakes set. Doh. Hard to taxi back from that "ain't right" situation. ![]() |
This is a true story, and it happened so long ago the statute of
limitations has to be protection. I was in the takeoff run for my Instrument Rating -- a 172 sometime in the 60s, and the damned airspeed needle wouldn't come off the stop. I chopped the power, the examiner asked what was wrong, and I pointed to the airspeed indicating zero while we were at maybe 30 kts. It was on a 5000 foot runway as I remember. He said "Go anyway." I think I won my rating when I pulled back the throttle. Anyhow, I had some real partial panel flying that day, and can tell you the Cessna 172 is a real forgiving airplane! I don't recall ever returning after taxiing out for weather reasons, but must have a dozen times for equipment problems. NAV not testing right, carb heat cable breaking -- it's not supposted to come out a foot! -- bad radio, too rough on one mag, etc. Nearly all of those were on rental airplanes, that means within my first 300 or so hours. Problems like that went way down when I began flying my own airplane. |
Tony wrote:
I've taxied back from run up more than once: if it ain't right, don't do it! I did it once with a FAA inspector in the back seat (Citabria) :-) --Sylvain |
Long flight today... | Steve R. | Rotorcraft | 1 | October 21st 04 11:16 PM |
Time logging question... | hellothere.adelphia.net | Rotorcraft | 1 | September 3rd 04 12:04 AM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
