#21
![]() wrote in message ups.com... The UK's APT (Advanced Passenger Train) of the 1970s used 6 gas turbines to power it. Never made it into service. pics of one of the turbines. http://www.apt-e.org/index/apt73.htm David That was only the experimental version, the prototype and production versions were intended to be electrically hauled. The BoBo power car design was used to build a new locomotive, the Class 91 capable of 140mph, which pulls the Inter City 225 on the East Coast main line today. Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() Eunometic wrote: I think conversions of gasoline based internal combustion engine turbochargers to gas turbines are not that uncommon. I saw a Sydney University student do it for his thesis once. An issue with diesel turbochargers is that they may be made of alloys less heat and corrosion resistent than that of gasoline ones since the diesel cycle has a much lower exhaust temperature (550C) than a gasoline engine (850C). This should effect life iof the turbocharger. Many automotive turbo's are now ceramic based. I believe the turbochargers of diesel trucks such as SAAB and Volvo and other European types are turbocompounded have for many years had a hydraulic torque coupling to put surplus power not needed for the compressor back into the drive shaft. Most of the turbocharger conversions are using diesel, or kersosene for fuel. Gas is much too volitle and dangerous. |
You're right - but it was still the nicest of the APTs! would look
state of the art, even today.The protype had a few things batting against it - one of which was that the turbines were built by Leyland ....this was around the same time they were churning out Princesses/Ambassadors and Allegros... David |
As a note, Jay Leno's jet turboshaft motorcycle:
http://media.popularmechanics.com/im...0108AUCCAB.jpg Remember that thing? Rob |
Rob Arndt wrote:
As a note, Jay Leno's jet turboshaft motorcycle: http://media.popularmechanics.com/im...0108AUCCAB.jpg Remember that thing? Made in New Iberia, Louisiana... |
![]() Anton wrote: wrote Have you ever taken a car and fitted a much larger engine to it? Read up.Before that 2.8 V6, engine vas 1.6 4-cyl. OK, good then. A lot of times people ask questions like this and don't really have the slightest idea what they're getting into. Clearly you have a little more experience. Have you ever worked with turbine engines before? (Obviously not, based on your questions) No.I prefer NA engines.Even now.I'm interested in turbines as engines, not like add on to piston engines. Yeah, I know, I mean "gas turbine engines," not turbo/supecharged engines. In order to succeed, you first need to turn your turbochargers into a turbine engine. Before you can even begin to think about doing this you need to learn how turbines work. Then you can begin laying out a plan. I know principles, after all, I'm studying railway traffic, and we have many mechanical courses. Well, when you asked, "what is a compressor," I wondered. That is like asking a piston mechanic, "what is a cylinder?" This is a project that would probably keep you busy for 5 years if you work part-time. You mean on locomotive turbine into car, or just plain turbocharger converting to gas turbine?If is this last, then you must se what people on intrent have made for month or less with scrap turbocharges from local junkyard. Are they generating useful power, or just making a lot of noise? Making noise is easy, making power takes engineering skill. That's what will take you time. Are they skilled mechanics doing their second or third project, or a first-time experimenter just like you? I'll bet the second time you do this, you will do it a lot faster than the first. As for how much power it puts out, who knows? There's a ton of variables in there. I'd suspect a few hundred horsepower, maybe more, quite likely less. It will probably turn out heavier than an equivalent piston engine, and thus the car will actually go slower. Why?That doesn't mean that it must be like you said. Well, let's look at it this way. Teams of engineers, with literally billions of dollars to spend, build turbines that put out maybe 800 horsepower (and of course a lot larger too). Of course, you don't have to worry about safety or reliability, so your job is easier that way, but you're also working with inferior materials and knowledge (not meant as criticism, just fact). You may be able to get 500, 700, 1000HP out of a turbine but my guess is that your turbine will end up weighing a LOT. Weight is not the first concern when building parts that go on locomotives- durability and low maintenance cost matter a lot more. The result is that heavier, cheaper materials are used and often overbuilt (adding more weight). Weight is your enemy. If my car has the same power as yours, and mine is heavier, then your will be faster. Simple physics. How cool will that be? Why that tone?I mean, what is so wrong if I ask something like this Sorry, I'm not trying to be discouraging, just realistic. If you think you can build a turbine in a few months that will make your car go super-fast, you're probably going to be disappointed. If you're ready to spend a couple of years in the shop, building, testing, fixing, building, fixing, testing, then you just may be able to get something pretty cool. Hey, really, I wish you the best of luck. I hope it works. Best, -cwk. |
Hello
I know this is not exactly what you guys are up to, but you might find it interesting anyway. http://www.junkyardjet.com/ There are many sites like this. Guys build jet engines out of automotive turbochargers, usually with something like an old fire extinguisher for the expansion chamber, and the burner assembly form a household heating oil furnace to supply the fuel feed and ignition. Lots of them actually working. |
#28
Before the 1963 Chrysler gas turbine car was the Rover JET-1:
http://news.bbc.co.uk/onthisday/hi/d...00/2516271.stm Rob |
#29
B-17 with claimed gas turbine engine, WW2:
http://www.de220.com/Strange%20Stuff/TEST-80G419784.jpg Rob p.s. What was the engine? |
#30
there was a site in New Zealand put up by a guy building his own
pulsejet powered cruise missile with parts from hardware stores etc. Main site: http://www.aardvark.co.nz/pjet/ ....and his cruise missile project: http://www.aardvark.co.nz/pjet/cruise.shtml David |
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power | TurbineMini Richard | Rotorcraft | 2 | January 28th 09 07:50 PM |
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit | TurbineMini Richard | Rotorcraft | 2 | January 24th 04 01:15 AM |
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit | TurbineMini Richard | Rotorcraft | 0 | January 15th 04 11:48 PM |
TRUTH OF THE MINI-500 TURBINE CONVERSION | Dennis Chitwood | Rotorcraft | 10 | January 7th 04 05:33 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
