Is there a "proper" tape for protecting the leading edge ? Reason I ask, is
talking to some boy`s that work on WRC rally car`s a lot, They use a thick transparent about 3inch wide tape to protect bit`s, They call it helicopter tape and said that`s what it`s original design was for ? Tim Rocky p.s. did you ever use the trick of SaranWrap on the leading edges and you can just peel off a layer at the end of the day for a clean edge? Have not tried it on rotor. |
I've tried a bunch of stuff on my MR to keep salt from building up on it.
The only thing that seems to work is coating the leading edge with Corrosion X HD, but you have to do it pretty frequently. My Jet Ranger used to have a heavy teflon tape on the leading edge, but Maintenance removed it for some reason that has yet to be explained to me. 3M makes a leading edge abrasion tape (for planes). I think you can find it at Aircraft Spruce. I have it on one of my airplanes and it works nicely at protecting but its a tad harder to clean than a painted surface and you have to avoid using degreasers on it. Bart "Tim" h wrote in message ... Is there a "proper" tape for protecting the leading edge ? Reason I ask, is talking to some boy`s that work on WRC rally car`s a lot, They use a thick transparent about 3inch wide tape to protect bit`s, They call it helicopter tape and said that`s what it`s original design was for ? Tim Rocky p.s. did you ever use the trick of SaranWrap on the leading edges and you can just peel off a layer at the end of the day for a clean edge? Have not tried it on rotor. |
Actually there is a "proper " tape and it's been used mostly for erosion
control by various militarys including or own, I can look up the P/N if there's a need, don't know all the aircraft it has been on though. "B4RT" wrote in message ... I've tried a bunch of stuff on my MR to keep salt from building up on it. The only thing that seems to work is coating the leading edge with Corrosion X HD, but you have to do it pretty frequently. My Jet Ranger used to have a heavy teflon tape on the leading edge, but Maintenance removed it for some reason that has yet to be explained to me. 3M makes a leading edge abrasion tape (for planes). I think you can find it at Aircraft Spruce. I have it on one of my airplanes and it works nicely at protecting but its a tad harder to clean than a painted surface and you have to avoid using degreasers on it. Bart "Tim" h wrote in message ... Is there a "proper" tape for protecting the leading edge ? Reason I ask, is talking to some boy`s that work on WRC rally car`s a lot, They use a thick transparent about 3inch wide tape to protect bit`s, They call it helicopter tape and said that`s what it`s original design was for ? Tim Rocky p.s. did you ever use the trick of SaranWrap on the leading edges and you can just peel off a layer at the end of the day for a clean edge? Have not tried it on rotor. |
Frank
I'd like to see it. Will ask our shop if they use it on any of the ag machines. The sandy soil here in spud country is really tough on blades. I imagine not as bad as Iraq though! Company has several WASP's and I took a look last week. Look nice and sound like performers. My engine is due this winter if it lasts the season..... Another 12 hr in the cockpit yesterday and probably 8 today to get caught up. Cheers Rocky |
OK, I'll dig up a MFG and P/N, maybe there's an approval for the 47 series,
if not you would have to get an approval for the mod, should be easy, just tell the DER what you would like to do n why, cite your research (documented uses) write a procedure for application of tape, balance, interchangeability maybe continues maintenance and stand back, DER does the number crunching and forwards it to the FAA. wrote in message oups.com... Frank I'd like to see it. Will ask our shop if they use it on any of the ag machines. The sandy soil here in spud country is really tough on blades. I imagine not as bad as Iraq though! Company has several WASP's and I took a look last week. Look nice and sound like performers. My engine is due this winter if it lasts the season..... Another 12 hr in the cockpit yesterday and probably 8 today to get caught up. Cheers Rocky |
Be careful with the tape, if it starts coming off life can get
interesting - if you think dirty blades are bad, you haven't seen anything yet. Just keep an eye on it & replace it before it starts wearing through the leading edge. I've used it on Bell 47's & Hiller 12's - can't tell you if it was "approved", but it definitely saves wear & tear on the blade. You'll want to have the exact same length on both blades in the exact same location, or you'll be rebalancing... On Wed, 13 Jul 2005 00:01:07 GMT, "Franklin Newton" wrote: Actually there is a "proper " tape and it's been used mostly for erosion control by various militarys including or own, I can look up the P/N if there's a need, don't know all the aircraft it has been on though. |
Brett
Had the same thoughts. We used it for a while in ag work in CA but it was such a pain to redo all the time and YES it can get exciting if you shed some tape....!! However, if it can save blades in a really harsh environment it is worth serious consideration. I like to use plan old carnuba wax on them once a week or so. Extra work and hard on the shoulders but well worth the effort when working off the truck. Rocky |
New news Soaring is dangerous ? | R Barry | Soaring | 29 | October 3rd 04 03:40 AM |
Ping Jay Honeck... Mighty Grape stuff.. | Dave S | Owning | 6 | September 16th 04 02:09 AM |
FS2004- Where's All the Old Stuff? | RobertS975 | Simulators | 3 | July 19th 04 01:16 AM |
Hmmmmm. FS98 'mystery' | Dr. Anthony J. Lomenzo | Simulators | 3 | April 15th 04 06:51 AM |
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet | Larry Smith | Home Built | 0 | August 4th 03 01:31 PM |
