Brief an approach
Old October 13th 03, 03:35 PM
A109Drvr
Here is what I use..it is loose enough that you can modify it make it your own
but it works for me. It is kind of a briefing/set-up for the approac guide:
Acronym: "A MICE ATM"
A: Atis, Altimeter and approach
M: marker beacon (pins and sensitivity)
I: ID navaids
C: Course..briefed and set
E: Entry..brief PT and any set up needed
A: Altitudes. Also brief callouts expected
T: Times (if a timed approach)
M: Missed (brief and set up in standby avionics)
may sound kind of daunting but it is pretty user friendly and I have shared it
with several other people who seemed to find it useful. Your mileage may vary
Old October 13th 03, 09:28 PM
Doug
For approaches I use WestCoastRailRoad
Weather, Clearance, Radios, and Review. I'll admit its a bit short of
being exhaustive. I also have an IFR checklist in the plane for
takeoff, cruise, arrival and approach phases. It IS exhaustive. As for
my clearance, everything goes into a radio or instrument. Frequecies
go into the radios, altitudes go into the altitude bug and headings go
into the heading bug and waypoints go into the GPS. Not a bad idea to
write them down also, but so long as my radios work, I can always ask.
The reality is I just keep a 4 1/4" x 5 1/2" (half) pad of paper and a
few pens in the plane and write down what I need on that. One of the
things I do have is a business card sized flight plan form, I use it
all the time so I have all the info to give flight service. All I
really need to jot down is my takeoff time and enroute time that I
gave him when I filed (well, ok, my destination, but I usually do know
that). Works great and I dont have to bring any paperwork into the
FBO, just my wallet, which I always have.
It all depends on how exhaustive and organized YOU want to be. Do you
want to emulate the airlines, or just fly around with minimum hassle?
Or somewhere in between? I only file IFR if I need to, to get where I
am going. Some file IFR all the time.
So my suggestion, memorize an anacronym, get several 1/2 size
notepads, some pens or pencils, and business card flight plan form,
and you have the minimum necessary.
Old October 13th 03, 10:14 PM
John R. Copeland
I gotta get me one of them "anacronyms". :-)
Seriously, though, filing IFR whether needed or not is good training.
Pretty soon you'll find you no longer need mnemonics and acronyms.
Maybe you'll need only a place to record clearances and amendments.
---JRC---
"Doug" wrote in message =
om...
=20
=20
Old October 14th 03, 12:05 AM
Ray Andraka
I use "wire math": Weather, instruments, radios, everything else (speed, flaps) for set-up, and missed,
altitude, time and heading for breifing the approach.
---JRC---
"Doug" wrote in message om...
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old October 14th 03, 12:10 AM
Ray Andraka
I used to use "wire math": Weather, instruments, radios, everything else (speed, flaps) for set-up, and missed,
Now after flying lots of hours in the system, it is easier to just use the audio panel plus the instrument faces
to brief the setup. For each switch on the audio panel, check the switch in the right position, and set the
corresponding radio. Reach the last switch, and all your radios are set up for the approach. Then check each of
the primary instruments and set any knobs as appropriate. In my case, that is the autopilot, the altimeter,
match the DG to the compass and set the heading bug, then go across the switches to make sure things there are
set properly: lights, pitot heat, fuel pump etc, then all the way to the floor to check fuel tank and flaps.
---JRC---
--Ray Andraka, P.E.
email
The perfect approach Capt.Doug Home Built 25 December 3rd 04 03:37 AM
DME req'd on ILS (not ILS-DME) approach? Don Faulkner Instrument Flight Rules 13 October 7th 03 03:54 AM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
CAT II Minimums on a CAT I Approach Giwi Instrument Flight Rules 11 July 24th 03 07:46 AM
