DUAT
Old July 13th 05, 12:23 AM
Stan Prevost
nk.net...
An alternative clearance is issued when necessary to ensure separation
from other traffic or airspace. For example, if the controller had
traffic at nine thousand a proper clearance would be; "Climb to and report
reaching VFR-on-top, no tops reports. If not on top at eight thousand
maintain eight thousand and advise." Remember, you're just another IFR
aircraft until you report reaching and are cleared to maintain VFR-on-top.
It seems to be to everyone's advantage for the pilot to report being OTP as
soon as he is and can remain that way, even if that is on the runway, as
newps described, or on initial contact with Departure. That minimizes the
time and space during which I must be provided separation, as long as I am
willing to forego that.
Old July 13th 05, 04:39 AM
Newps
If you report it prior to departure the tower controller can amend your
clearance in the computer and this will save a landline call to the
center. Once you tag up on the radar the tower/departure controller
loses the ability to make changes in the computer, only the center can
do it.
Old July 13th 05, 05:27 AM
Stan Prevost
"Newps" wrote in message
news
as soon as he is and can remain that way, even if that is on the runway,
as newps described, or on initial contact with Departure. That minimizes
the time and space during which I must be provided separation, as long as
I am willing to forego that.
center. Once you tag up on the radar the tower/departure controller loses
the ability to make changes in the computer, only the center can do it.
Interesting. I never heard that before. So a TRACON controller cannot
change a clearance without calling center to do it?
Old July 13th 05, 07:03 PM
Steven P. McNicoll
"Stan Prevost" wrote in message
It's a flight data processing issue. A terminal controller cannot amend a
flight plan in the computer if the host center has auto-acquired a target on
that flight. The revised clearance must then be manually coordinated. The
alternative is to suspend the auto-acquire feature, which will then require
the center to manually start a track on aircraft that depart from airports
where the center provides approach control services. Suspending the
auto-acquire is the way to go, starting a track is quick and easy and is
more than made up for by the reduced manual coordination.
Old July 13th 05, 07:51 PM
Stan Prevost
.net...
on that flight. The revised clearance must then be manually coordinated.
The alternative is to suspend the auto-acquire feature, which will then
require the center to manually start a track on aircraft that depart from
airports where the center provides approach control services. Suspending
the auto-acquire is the way to go, starting a track is quick and easy and
is more than made up for by the reduced manual coordination.
So this becomes an issue only at a towered field using center approach
control services?
Old July 13th 05, 08:04 PM
Steven P. McNicoll
control services?
No, it's an issue at any field using center approach control services and
pop-ups in center airspace.
Old July 13th 05, 08:47 PM
Stan Prevost
nk.net...
control services?
I don't understand. Your prior discussion was in the context of a terminal
controller and center approach control, I thought. That's why I was trying
to clarify that it applied to a towered field using center approach control.
Can the terminal controller suspend auto-acquire?
If there is not a terminal controller, does center suspend auto-acquire?
Is suspending auto-acquire done on a per-acft basis?
Old July 13th 05, 09:46 PM
Newps
control services?
No it's an issue for any TRACON. All computer systems run thru the
center computer. They set the paramters. Right now whenever you
takeoff and tag up on the radar I lose the ability to make changes to
your flightplan thru the computer. I have to call the center controller
on the landline. We are in the process of having that changed with Salt
Lake. Both them and us here at BIL don't like this needless
coordination so we are changing it.
Old July 14th 05, 04:10 AM
Steven P. McNicoll
No, it's only an issue for TRACONs hosted by centers that use auto-acquire.
Old July 13th 05, 09:35 PM
Newps
Right. Although here at BIL we are in the process of getting that
changed, so anytime I want I can change any aircrafts data in the
computer. It's a pain in the ass and a relic from days gone by.
Duat Graphics Slick Piloting 0 January 23rd 05 01:35 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
DTC DUAT Matt Whiting Instrument Flight Rules 0 June 5th 04 03:23 PM
Picking Optimal Altitudes O. Sami Saydjari Instrument Flight Rules 20 January 8th 04 02:59 PM
