![]() "Steven P. McNicoll" wrote in message ink.net... "Stan Prevost" wrote in message ... I have never received a clearance for just "VFR On Top" without further restrictions, although I understand it is permitted. Restrictions can be "Maintain VFR On Top at or below xxx", "....at or above xxx", or "... at or between xxx and yyy". I understand that the controller is not responsible for separation, so I wonder why I always get an altitude restriction, usually "at or below". Do you receive these restrictions after reporting VFR-on-top? Sometimes yes, sometimes no. Are you operating in airspace where ATC provides separation to VFR aircraft? Not to my knowledge. Not in Class B airspace nor Class C airspace. Is Special Use Airspace a factor? My flight path is always clear of SUA. Well, when I have received the OTP restrictions, anyway. I always file a route that is clear of SUA, but sometimes I get recleared enroute for direct destination (without request) which puts me through SUA, and sometimes I get vectored around the SUA when I get to it. Arghhh.. |
![]() "Stan Prevost" wrote in message ... Do you receive these restrictions after reporting VFR-on-top? Sometimes yes, sometimes no. Are you operating in airspace where ATC provides separation to VFR aircraft? Not to my knowledge. Not in Class B airspace nor Class C airspace. Is Special Use Airspace a factor? My flight path is always clear of SUA. Then there is no reason for the altitude restrictions. Well, when I have received the OTP restrictions, anyway. I always file a route that is clear of SUA, but sometimes I get recleared enroute for direct destination (without request) which puts me through SUA, and sometimes I get vectored around the SUA when I get to it. Arghhh.. I stay out of the cockpit when I'm controlling and when I'm flying I expect the controller to stay out of my cockpit. As a controller I'll move an airplane for traffic, for SUA, or to comply with a LOA. That's it. If I see you're /G but have filed a bunch of VORs or airways I'll offer a shortcut, but I won't just issue one of my own volition. If you want to pay for GPS and still navigate by VOR that's your business. |
Steve,
I thought that for /G there still needed to be a vor or other nav fix in the route. I generally draw a line between the start AP and the destination and then add a vor in the middle that doesn't increase the distance by much. Gices me two nav checks for redundancy, too. Are you saying that /g can be diredt between APs over several hundred miles with no other fixs? Chuck |
![]() "Chuck" wrote in message oups.com... I thought that for /G there still needed to be a vor or other nav fix in the route. I generally draw a line between the start AP and the destination and then add a vor in the middle that doesn't increase the distance by much. Gices me two nav checks for redundancy, too. Are you saying that /g can be diredt between APs over several hundred miles with no other fixs? You don't even have to be /G. IFR flight off-airways and beyond normal navaid distance/altitude limits just requires radar monitoring by ATC. Now, if you're going to a rather small airport hundreds of miles away there may be a flight data processing problem. The NAS computer serving the departure airport may not know where the destination airport is. You can get around that by filing a few waypoints based on H-class VORs that fall on your route, that will also help ATC visualize the route. Or you can just file the destination coordinates as an intermediate fix. |
"Steven P. McNicoll" wrote in message =
link.net... =20 "Chuck" wrote in message oups.com... I thought that for /G there still needed to be a vor or other nav fix in the route. I generally draw a line between the start AP and the destination and then add a vor in the middle that doesn't increase = the distance by much. Gices me two nav checks for redundancy, too. Are you saying that /g can be diredt between APs over several hundred = miles with no other fixs? =20 You don't even have to be /G. IFR flight off-airways and beyond = normal=20 navaid distance/altitude limits just requires radar monitoring by ATC. = Now,=20 if you're going to a rather small airport hundreds of miles away there = may=20 be a flight data processing problem. The NAS computer serving the = departure=20 airport may not know where the destination airport is. You can get = around=20 that by filing a few waypoints based on H-class VORs that fall on your = route, that will also help ATC visualize the route. Or you can just = file=20 the destination coordinates as an intermediate fix.=20 Sometimes, but not always, when I file direct to a distant point, even an H-class VOR, I'll be cleared first to a nearby fix, then as = filed. I usually make a note of that nearby fix, and include it in subsequent = trips. I figure the departure controllers prefer that, and it's OK by me. |
Duat Graphics | Slick | Piloting | 0 | January 23rd 05 01:35 PM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
DTC DUAT | Matt Whiting | Instrument Flight Rules | 0 | June 5th 04 03:23 PM |
Picking Optimal Altitudes | O. Sami Saydjari | Instrument Flight Rules | 20 | January 8th 04 02:59 PM |
