![]() Anton wrote: wrote Have you ever taken a car and fitted a much larger engine to it? Read up.Before that 2.8 V6, engine vas 1.6 4-cyl. OK, good then. A lot of times people ask questions like this and don't really have the slightest idea what they're getting into. Clearly you have a little more experience. Have you ever worked with turbine engines before? (Obviously not, based on your questions) No.I prefer NA engines.Even now.I'm interested in turbines as engines, not like add on to piston engines. Yeah, I know, I mean "gas turbine engines," not turbo/supecharged engines. In order to succeed, you first need to turn your turbochargers into a turbine engine. Before you can even begin to think about doing this you need to learn how turbines work. Then you can begin laying out a plan. I know principles, after all, I'm studying railway traffic, and we have many mechanical courses. Well, when you asked, "what is a compressor," I wondered. That is like asking a piston mechanic, "what is a cylinder?" This is a project that would probably keep you busy for 5 years if you work part-time. You mean on locomotive turbine into car, or just plain turbocharger converting to gas turbine?If is this last, then you must se what people on intrent have made for month or less with scrap turbocharges from local junkyard. Are they generating useful power, or just making a lot of noise? Making noise is easy, making power takes engineering skill. That's what will take you time. Are they skilled mechanics doing their second or third project, or a first-time experimenter just like you? I'll bet the second time you do this, you will do it a lot faster than the first. As for how much power it puts out, who knows? There's a ton of variables in there. I'd suspect a few hundred horsepower, maybe more, quite likely less. It will probably turn out heavier than an equivalent piston engine, and thus the car will actually go slower. Why?That doesn't mean that it must be like you said. Well, let's look at it this way. Teams of engineers, with literally billions of dollars to spend, build turbines that put out maybe 800 horsepower (and of course a lot larger too). Of course, you don't have to worry about safety or reliability, so your job is easier that way, but you're also working with inferior materials and knowledge (not meant as criticism, just fact). You may be able to get 500, 700, 1000HP out of a turbine but my guess is that your turbine will end up weighing a LOT. Weight is not the first concern when building parts that go on locomotives- durability and low maintenance cost matter a lot more. The result is that heavier, cheaper materials are used and often overbuilt (adding more weight). Weight is your enemy. If my car has the same power as yours, and mine is heavier, then your will be faster. Simple physics. How cool will that be? Why that tone?I mean, what is so wrong if I ask something like this Sorry, I'm not trying to be discouraging, just realistic. If you think you can build a turbine in a few months that will make your car go super-fast, you're probably going to be disappointed. If you're ready to spend a couple of years in the shop, building, testing, fixing, building, fixing, testing, then you just may be able to get something pretty cool. Hey, really, I wish you the best of luck. I hope it works. Best, -cwk. |
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power | TurbineMini Richard | Rotorcraft | 2 | January 28th 09 07:50 PM |
Locomotive turbine conversion? | Anton | Home Built | 34 | July 20th 05 02:42 PM |
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit | TurbineMini Richard | Rotorcraft | 2 | January 24th 04 01:15 AM |
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit | TurbineMini Richard | Rotorcraft | 0 | January 15th 04 11:48 PM |
TRUTH OF THE MINI-500 TURBINE CONVERSION | Dennis Chitwood | Rotorcraft | 10 | January 7th 04 05:33 PM |
