#41
"Mortimer Schnerd, RN" wrote in message . com... Dudley Henriques wrote: There's a lot to be said for an articulate man. Which one of us are you trying to nail with this gem of wit? Not you... I'm on your side. He has his head buried in his ass. Not entirely...he sees it (probably) on the same level as auto racing or other forms with high risk of catastrophe. This all for mere entertainment as opposed to flight test where the purpose is R&D. |
#42
"Tina Marie" wrote About the only acro act I really enjoy are the Red Barons, who probably do qualify as the above. I can't stand the Reds, because of the G*d awful noise! I think because of the physiology of pressure waves on the body, I become nearly nauseated. If they would sacrifice a little bit of power, by going to a shorter prop, or one with more blades, or slow the RPM's a bit, I would indeed enjoy them. As is, if able to (not working), I go in a building, or back to camp, to escape the noise. I like noise and airplanes. I like B-1 full afterburner passes. I like the Harrier hovering. I like a B-17 taking off, and P-51's, and .... There is something about the slow beating of big props (some of them) that I just can't stand. Any act that substitutes excessive aircraft power for pilot skill will bore me quickly... Shaun Tucker bores you? He has extreme power, but the stuff he does can not be done by airplanes. Somehow he does them. :-) -- Jim in NC |
#43
"Newps" wrote in message ... Dudley Henriques wrote: "Denny" wrote in message oups.com... Interesting bunch of responses, but nothing I have read so far induces me to change my statement... Reread the first sentence of my original post... For those who suggest I am operating from lack of information, I have been ground crew at internationally sanctioned aerobatic competitions... cheers ... denny WOW!!! Aerobatics performers are like bull riders. A goddamned stupid thing to do, serves no useful purpose and you deserve what you get. Idiot. Name one sport you enjoy watching that has an element of danger. If you cant, explain why nobody else should. Prove your lack of mental competence and imagination for posterity. m moo |
#44
"Mortimer Schnerd, RN" wrote in message m... Dudley Henriques wrote: Well that's good to know anyway :-) Perhaps if you could be just a tad more articulate in the future please? :-)))))))))))))))))))))))))) I'll see what can be done. Hell, I've always admired those who can do aerobatics. I have a different skill set but that doesn't mean I can't appreciate skillful flying of whatever type. Well said. Do what you do well. Do what you enjoy. moo |
#45
Morgans wrote:
I can't stand the Reds, because of the G*d awful noise! I think because of the physiology of pressure waves on the body, I become nearly nauseated. If they would sacrifice a little bit of power, by going to a shorter prop, or one with more blades, or slow the RPM's a bit, I would indeed enjoy them. You want bigger blades; not shorter. The rasping noise the Red Barons make is the blade tips going supersonic. Shorter blades go even faster. Personally, I find that rasp is like music. -- Mortimer Schnerd, RN VE |
#46
"Mortimer Schnerd, RN" wrote in message om... Morgans wrote: I can't stand the Reds, because of the G*d awful noise! I think because of the physiology of pressure waves on the body, I become nearly nauseated. If they would sacrifice a little bit of power, by going to a shorter prop, or one with more blades, or slow the RPM's a bit, I would indeed enjoy them. You want bigger blades; not shorter. The rasping noise the Red Barons make is the blade tips going supersonic. Shorter blades go even faster. Personally, I find that rasp is like music. Ummm...no, it's all a function of blade diameter and the corresponding circumference of the prop at the tip. At the same RPM, the shorter blade's tips are traveling SLOWER (due to the smaller circumference) than a larger blade. |
#47
circumference of the prop at the tip. At the same RPM, the shorter blade's tips are traveling SLOWER (due to the smaller circumference) than a larger blade. This is true. However, it is not what is (likely) important. When you change blade length, you need to change something else to compensate (for what?). Depending on what you will be holding constant, you will get different results. Hold RPM constant and power goes down. Hold power constant, and RPM must go up. If you want to do the same routine with shorter blades, you'll need to hold power, not RPM, constant. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
#48
m... There's a lot to be said for an articulate man. "Profanity is the inevitable linguistic crutch of the inarticulate mother****er." |
#49
Hi I read your message and I have to admit I totally disagree with you, I have been watching aerobatics since I was a young boy and a reason I became a pilot is from watching these guys putting their planes upside down. As someone previously stated we don't need any more reductions in freedom, I like watching aerobatics and obviously a lot of other people do, if you don’t like it just don’t attend the show. Oliver. -- oliverledoux ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
#50
"Mortimer Schnerd, RN" wrote You want bigger blades; not shorter. The rasping noise the Red Barons make is the blade tips going supersonic. Close. It is the air over the blades being accelerated to supersonic speeds. Shorter blades go even faster. Shorter blades turned at the same RPM would not have supersonic airflow. Personally, I find that rasp is like music. I don't mind a certain amount of rap. Theirs is too much. IMHO -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 05 08:29 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 04:58 PM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
