![]() "Newps" wrote in message news ![]() Stan Prevost wrote: Then another controller wouldn't let me descend in time (while I was still VFR On Top), I wound up cancelling IFR and circling down to the airport. Wouldn't let you descend? It's not his call. You tell him you're descending, if you choose to tell him at all. Yes, I know, but when I have been given an instruction to advise of altitude changes, and then when I advise of an altitude change and am told to remain at my present altitude and he will give me lower in a few miles, my choices are limited. I can start an argument on the frequency, cancel IFR, disregard his instructions, or go along with what he says. There is that pesky FAR that says pilots must comply with ATC clearances and instructions (as long as they would not cause me to violate a FAR or compromise the safety of my flight). Some say that pilots are not obligated to comply with an instruction that an controller is not authorized to give, but that is usually an issue to be sorted out on the ground, IMO. If he wanted to keep me at altitude, he could have and probably should have assigned me a hard IFR altitude, such as 12000 (I was at 12500). There is not a lot of difference in the end result, so why cause a scene over it in the air? |
![]() "Stan Prevost" wrote in message ... Yes, I know, but when I have been given an instruction to advise of altitude changes, and then when I advise of an altitude change and am told to remain at my present altitude and he will give me lower in a few miles, my choices are limited. I can start an argument on the frequency, cancel IFR, disregard his instructions, or go along with what he says. There is that pesky FAR that says pilots must comply with ATC clearances and instructions (as long as they would not cause me to violate a FAR or compromise the safety of my flight). Some say that pilots are not obligated to comply with an instruction that an controller is not authorized to give, but that is usually an issue to be sorted out on the ground, IMO. If he wanted to keep me at altitude, he could have and probably should have assigned me a hard IFR altitude, such as 12000 (I was at 12500). There is not a lot of difference in the end result, so why cause a scene over it in the air? You're dealing with a controller unfamiliar with VFR-on-top. Separation is not an issue so there's no reason to keep you at altitude. |
![]() Stan Prevost wrote: Yes, I know, but when I have been given an instruction to advise of altitude changes, and then when I advise of an altitude change and am told to remain at my present altitude and he will give me lower in a few miles, my choices are limited. My first choice will be to then ask why or play chicken on the air and say "I'm descending to maintain VFR." He can't deny that. Assuming you're not real close to a terminal area and sequencing becomes an issue the controller shouldn't be stopping you from changing altitudes. |
![]() "Newps" wrote in message ... Stan Prevost wrote: Yes, I know, but when I have been given an instruction to advise of altitude changes, and then when I advise of an altitude change and am told to remain at my present altitude and he will give me lower in a few miles, my choices are limited. My first choice will be to then ask why or play chicken on the air and say "I'm descending to maintain VFR." He can't deny that. Assuming you're not real close to a terminal area and sequencing becomes an issue the controller shouldn't be stopping you from changing altitudes. I was approaching the terminal area, IND, from the north. |
Duat Graphics | Slick | Piloting | 0 | January 23rd 05 01:35 PM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
DTC DUAT | Matt Whiting | Instrument Flight Rules | 0 | June 5th 04 03:23 PM |
Picking Optimal Altitudes | O. Sami Saydjari | Instrument Flight Rules | 20 | January 8th 04 02:59 PM |
