![]() "Jose" wrote This is true. However, it is not what is (likely) important. When you change blade length, you need to change something else to compensate (for what?). To use the HP being produced. You could use wider blades, or add more blades. Efficiency would suffer a certain amount. None of that will happen, since a whole new prop system would have to be invented, and that would be something less than inexpensive. (insert sarcasim here) -- Jim in NC |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 05 07:29 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
