New Garmin 396
Old July 13th 05, 08:02 AM
Morgans
"Jose" wrote
What other IFR approved navigation equipment does he have?
If he has VOR, and there's a VOR approach at the destination, I see no
reason not to continue on and shoot the VOR approach with the IFR
certified VOR equipment on the aircraft, using the handheld GPS for
situational awareness.
His destination and all options only have GPS instrument approaches, or all
his other IFR instruments crapped out.
What he is thinking of doing, is not telling anyone that his other stuff
crapped out, and go ahead shooting a GPS approach to high minimums, and if
the weather does not let him decide early to go visual, go missed.
Jim in NC
Old July 13th 05, 12:18 PM
Peter Clark
On Wed, 13 Jul 2005 03:02:32 -0400, "Morgans"
Wouldn't that violate the "must report equipment malfunction that
affects navigation" FAR?
Isn't the "right" answer in this case to report the malfunction and go
to the airport which allows descent from enroute VMC and get it fixed?
Old July 13th 05, 02:16 PM
Jose
If all the other IFR instruments crapped out, something is seriously
wrong that needs fixing. Go to the VFR alternate. If, once VFR, the
weather at the destination allows VFR flying, then fly VFR to the
destination (assuming it is unlikely that the rest of the airplane will
fall apart, leaving the pilot clutching the 396 and an empty yoke, like
in the cartoons.
Yes, I figured. That would be an emergency procedure. This isn't an
emergency yet. Don't make it one.
Yes, it's likely that the 396 will do fine. But it may be "less than
fine" in a surprising way, since it hasn't been tested in ways the FAA
considers sufficient. I have issues with the FAA sometimes, but they
also have their good points.
Jose
Nothing takes longer than a shortcut.
Old July 13th 05, 03:01 PM
Grumman-581
"Jose" wrote in message . ..
Yeah sarcasmRIGHT/sarcasm... Tell that to all the trees that they've
directly or indirectly killed in their mountains of paperwork over the
years...
Old July 14th 05, 03:37 AM
Morgans
In my hypothetical situation, since his destination was 1000 and 1 mile, I
was fishing for who would (at those rather high minimums) go take a look,
and if not visual by that time, then go elsewhere.
No take-rs, I see.
Jim in NC
Old July 14th 05, 04:47 PM
Gig 601XL Builder
all
If all the other IFR instruments crapped out, something is seriously wrong
that needs fixing. Go to the VFR alternate. If, once VFR, the weather at
the destination allows VFR flying, then fly VFR to the destination
(assuming it is unlikely that the rest of the airplane will fall apart,
leaving the pilot clutching the 396 and an empty yoke, like in the
cartoons.
if
considers sufficient. I have issues with the FAA sometimes, but they also
Now here's where I don't understand the FAA's logic.
I'm building an airplane. I can put in any non-certified equipment I want to
including NAV equipment that is not new or yellowed tagged and "I" can
certify that it is up to IFR standards.
But... If I want a IFR GPS it has to be installed to the standard of the TSO
(Can't remember number).
Basicly Garmin gould build a device that derived it's information from
VOR/LOC/NDB/GS to the same standard as the 1/2/396 and I could fly IFR with
it. But because they use GPS I can't.
Old July 13th 05, 06:17 PM
john smith
The handheld doesn't have RAIM.
Shooting the GPS approach with the handheld is an invitation to disaster.
Old July 14th 05, 05:12 AM
Doug
In 2200 hours of flying, I've never had a RAIM failure on my IFR GPS.
Trying to shoot an approach with a handheld, the problem is the unit
being in your scan. If it were permanently mounted and you were
familiar with it, it could work. I never do GPS approaches much anyway.
I take the ILS if I can.
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
