My Annual
Old July 14th 05, 02:35 PM
Darrel Toepfer
Charles Talleyrand wrote:
I own a Cessna 150, which I have had for several years. This year my
annual ..
'65 C172F, recently sold. Paying $200 a month for hanger was the final
straw. 4R7 ($400 for the hanger, split 2 ways)...
Spark plugs cleaned and gapped
Replaced fine wire with massive electrode from those fine folks out on
the left coast...
Valve cover gaskets replaced on three cylinders
Same here, but all six cylinders, new valve covers as well. Cured the
majority of the oil leaks. Replacing o-rings on the dipstick, tightning
all the cylinders and replacing all the crush rings - fixed all the
others...
Compressions of 74,76,74,76 (not bad for a 1100 hour engine).
3400+ hours, 900+ since topped with chrome cylinders, readings about the
same, 2 higher, 2 lower, all above 70...
Nose gear torque tube link retightened
Shimmy damper cleaned and serviced.
Replaced the little henge piece behind the nose strut (cracked in 2
places), 2.3 AMU's is what cessna wants, did it for $300 through a
salvage firm. 5 sets of strut seals before they finally got one that
didn't leak down in a few days time. Added some shims in the strut as
well. Replaced a tire with a bald spot at the same time, used tire from
the same salvage people, plus new tube ($35)...
Nose rim also had spun bearings, replaced the rim and the bearings.
Forget what the AMU's were on a rim, $100 or so through salvage. Keep in
mind that all of this was repaired/replaced less than 2 months after
prior owner's annual and we took ownership of it and at our expense...
Wheel bearings cleaned and repacked
Replaced both brake discs, one had actually rusted through in a few
places, both worn to minimums. New brake pads, new chrome discs ($100
ea.). Steel was cheaper, stainless was more expensive...
Total cost $800. This is the only maintenance I've needed this year.
Annual inspection labor was under $300, we did most of the work
ourselves, did all of the annual dissasembly and reassembly...
Shopping planes again. Would like an amphib, 4 seats preferred...
Old July 14th 05, 05:32 PM
Doug
I happen to have an Aviat Husky Amphib for sale. Not a 4 place but a
great two place. Just annualed.
Contact me at anothername(at)comcast(dot)net. (Repalce the at with an
@ and the dot with . ).
Nothing like Seaplane flying. Great freedom. Land on lakes!!!
Pics on Jays website.
Old July 14th 05, 05:41 PM
RST Engineering
It seems some Cessna 150 owners have been finding cracks in the
vertical tail attach bracket.
It seems the FAA thinks the same thing, since they issued an Airworthiness
Directive in 1980 for that same problem. See AD 80-11-04.
It's a piece of metal the size of my
palm that any fool could weld together. It costs (I'm told) $200. To
inspect it requires removing both vertical and horizontal stabilizers,
the elevator and rudder. I'm told this is 10 hours labor. Our local
mechanic has inspected seven and found two cracked.
Horsefeathers. It requires a flashlight, an inspection mirror, and ten
minutes. See Cessna service letter 79-49.
Doing this also means you can replace some nut plates with
actual nuts and terminate a repeetitive AD.
That's true.
In addition I got
Several repetitive AD inspections checked
New oil and filter
Had nothing to do with the annual INSPECTION.
Seals on vacuum pump replaced
ELT inspected (It's fine)
That's not bad, but you could have done $600 worth of it yourself.
Old July 14th 05, 06:39 PM
Steve Foley
Nobody mentioned the word INSPECTION.
This is the annual "Mechanic needs a new toy so I get to buy it for him"
party.
For anyone wondering, go check out
http://www.rst-engr.com/annual/
For Jim's opinion of how an owner should have his ANNUAL INSPECTION done.
"RST Engineering" wrote in message
Old July 15th 05, 06:27 AM
Charles Talleyrand
I do wonder if we are mis-understanding each other. The inspection i'm
trying to describe was according to the A&P an optional inspection, and
a new one. He's normally on the ball.
New oil and filter
Yes, technically you are right. However, almost everyone describes the
inspection and the repair as "the annual". And this is a useful bit of
speach. And you've already made this point several times over the
years. And if you really want to be technical, I didn't say "annual
inspection" I just said "annual". But I think you are being picky for
no reason.
Old July 15th 05, 03:37 PM
I'm going in on Monday (25th) for my 7th annual . . . '67 C-172-H.
I will do everything owner is permitted to do (as I have for the last 5
years).
Will report results here when complete. I fly about 125 hrs a year,
and at least once a week, often 3 times.
We shall see.
www.Rosspilot.com
Old July 27th 05, 09:01 PM
Well, not such good news :-(
My #5 cylinder compression was only 57 . . . so my mechanic did what he
called "staking the valve" . . . by rapping on it with a plastic mallet
while checking the compression gage. No improvement.
The exhaust valve is not seating properly so we have to pull the
cylinder and either send it out for repair or exchange for another one
Any comments or suggestions as to which course of action is better?
Old July 27th 05, 10:17 PM
nrp
Check the calibrations on that compression gage (assuming you are
loooking for 60/80 psi?). Fly the airplane for 10 hours and check the
compression on that cylinder again. Lots of times our 172M wouldn't
quite make compression & but then it would 10 hours later on a recheck.
This assumes you don't have a problem with excessive oil consumption or
fouling.
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
My Aztec's first Annual Louis L. Perley III Owning 11 November 11th 04 05:04 AM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
