Roger wrote:
On Thu, 14 Jul 2005 08:23:48 -0700, Smitty wrote: snip The punches have to be in good shape other wise the edges of the hole (usually by the points) can roll in and they oft times have a small lip on the inside. This *usually* isn't much of a problem, however the pilot hole needs to be a slip fit for the bolt and it needs to be round if you expect close tolerances in positioning. That brings me to the next one which is the larger punches. They require a pilot hole punched with a smaller punch which needs to be a good fit to the larger bolt. This can either give the user a chance to even out any misplacement with the first hole, or accidentally add the displacements to the point of where they are noticeably out-of-line. I'd probably use a lot of Aluminum sigh and I've punched a *lot* of holes using both the mechanical and hydraulic operated ones. One final point. This type of punch is *EXPENSIVE*. Good quality ones large enough for instruments will run well over a $100 and you need a smaller one for the pilot. Over all it'd probably take about 5 different punches to do a panel with the punches ranging from about $65 to $150 if they are real Greenlee punches. (Now if you know some one with a set that's in good shape... G) I was going to purchase a set and came away with a real case of "sticker shock". I'm still keeping my eyes open for a used set in good condition though. I have bought several Greenlee hole punches from e-bay relatively cheaply. My 3 1/8" cost me $100 plus shipping. Two things must be taken into consideration: first most are used and need to be sharpened and second conduit punches run 3/8" larger than the given size, e.g. a 2" conduit punch is 2 3/8" actual. Sharpening is easy with either a medium grit wheel (you use the side of the wheel) or a good, flat medium grit whet stone. Punches listed as radio chassis punches are acual size. Dan, U.S. Air Force, retired |
Are All Batteries Created Equal? (Does Size Matter?) | [email protected] | Soaring | 4 | July 17th 05 02:04 PM |
DIGGING A DEEPER HOLE | Cribsheet | Piloting | 3 | December 10th 04 12:00 AM |
Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 12:58 AM |
Finding vent hole in wing skin | Martin Eiler | Soaring | 7 | November 21st 03 01:44 PM |
Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 12:18 AM |
