Just a comment on really short landings. I have a Husky and it lands
about as short as anything. Short landings tend to be rough. This is because your forward speed is low compared to your vertical speed. Also, a vertical bounce uses up energy. So don't be afraid to "bounce it in". If you look at the videos of the short landing contests in Alaska, those guys just plop on, hard, and usually bounce. The Idaho strips are very challenging. The key in Idaho is don't fly in the afternoon. Mornings and after 6 pm are much better. For charted strips, Idaho actually has more challenging stuff than Alaska. My Husky is for sale, btw. Contact me at anothername(at)comcast(dot)net. Make the @ and . substitutions. Doug |
A firm landing (or a bounce) is better than running off the end but it is
better yet to manage power and energy to land smoothly at minimium speed both forward and vertical. This is easier said than done however! Rules for flying in ID "Go flying at 7" (either "7") "Tie down by 10" Mike MU-2 "Doug" wrote in message oups.com... Just a comment on really short landings. I have a Husky and it lands about as short as anything. Short landings tend to be rough. This is because your forward speed is low compared to your vertical speed. Also, a vertical bounce uses up energy. So don't be afraid to "bounce it in". If you look at the videos of the short landing contests in Alaska, those guys just plop on, hard, and usually bounce. The Idaho strips are very challenging. The key in Idaho is don't fly in the afternoon. Mornings and after 6 pm are much better. For charted strips, Idaho actually has more challenging stuff than Alaska. My Husky is for sale, btw. Contact me at anothername(at)comcast(dot)net. Make the @ and . substitutions. Doug |
One thing that works on my Husky is to drag it in, cut the power and
retract the flaps at the point of desired landing from a foot or so off the ground. This plants me firmly. Then it is a braking contest. How hard can I brake without nosing over? If the tail comes up during braking, back off. There really are two different short field techniques. One where there is an obstacle, and one with a clear, no obstacle approach. If there is an obstacle, drag it in along the tops of the trees, cut the power and come down as steep as possible and get it planted as soon as possible and on the brakes. You slow down faster on the ground than in the air. This is where it is good to have a plane with a steep decent capability. The other is where you drag it in only a few feet up and flare and dump the flaps and brake as described. I really only like to land if I have a times two margin. My Husky can usually get down in 400' once it touches, at the Idaho 7000' density altitudes. So I need 900' to be comfortable. Most of those Idaho strips are long enough. I need less if the landing is uphill. The times two margin gives me some room for error. I am most nervous on the ones with no go around. Biggest problem is winds. If theres much disagreeable wind or turbulence, just don't do it. It's nerve wracking to fly around that Idaho wilderness. There are so many trees, if you lost an engine, not many options. I did a lot of strips out there on two visits. But I don't go there much anymore. I guess I think its a little hazardous. Well, more than a little. Some of those strips, the trees have gotten taller and taller every year. That and there have been so many fires, the place isn't all that attractive. But its the place to go for real world small strip experience. If you can handle those strips, you can handle just about any. The Alaska stuff is another story. Need inside information to operate up there. They aren't charted. Nor are they maintained. |
What I have found to be the best technique in the Helio at about 3100lbs is
to slow way down to about 45kts. This will yeild about 500fpm with 11"MP which is a steep descent. When I am about 200AGL, I increase speed to 55kts to provide energy for the flair. You can brake as hard as possible with the Helio and there is no chance of it nosing over because the gear is so far forward. What I found last week is that these speeds and power setting do not work well at 3400lb. I need quite a bit more speed. I will have to figure out what the numbers should be. I was quite surprised at the difference. I agree that there arn't too many options if you have to land but if you hit the trees at 50-60mph you will live unless you center puntch a large tree. Mike MU-2 "Doug" wrote in message oups.com... One thing that works on my Husky is to drag it in, cut the power and retract the flaps at the point of desired landing from a foot or so off the ground. This plants me firmly. Then it is a braking contest. How hard can I brake without nosing over? If the tail comes up during braking, back off. There really are two different short field techniques. One where there is an obstacle, and one with a clear, no obstacle approach. If there is an obstacle, drag it in along the tops of the trees, cut the power and come down as steep as possible and get it planted as soon as possible and on the brakes. You slow down faster on the ground than in the air. This is where it is good to have a plane with a steep decent capability. The other is where you drag it in only a few feet up and flare and dump the flaps and brake as described. I really only like to land if I have a times two margin. My Husky can usually get down in 400' once it touches, at the Idaho 7000' density altitudes. So I need 900' to be comfortable. Most of those Idaho strips are long enough. I need less if the landing is uphill. The times two margin gives me some room for error. I am most nervous on the ones with no go around. Biggest problem is winds. If theres much disagreeable wind or turbulence, just don't do it. It's nerve wracking to fly around that Idaho wilderness. There are so many trees, if you lost an engine, not many options. I did a lot of strips out there on two visits. But I don't go there much anymore. I guess I think its a little hazardous. Well, more than a little. Some of those strips, the trees have gotten taller and taller every year. That and there have been so many fires, the place isn't all that attractive. But its the place to go for real world small strip experience. If you can handle those strips, you can handle just about any. The Alaska stuff is another story. Need inside information to operate up there. They aren't charted. Nor are they maintained. |
In article . net,
"Mike Rapoport" wrote: What I have found to be the best technique in the Helio at about 3100lbs is to slow way down to about 45kts. This will yeild about 500fpm with 11"MP which is a steep descent. When I am about 200AGL, I increase speed to 55kts to provide energy for the flair. You can brake as hard as possible with the Helio and there is no chance of it nosing over because the gear is so far forward. If you're going to end up at 55 on the bottom end why slow to 45? -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Because the descent angle is too low at 55, it just doesn't want to come
down. Mike MU-2 "Dale" wrote in message ... In article . net, "Mike Rapoport" wrote: What I have found to be the best technique in the Helio at about 3100lbs is to slow way down to about 45kts. This will yeild about 500fpm with 11"MP which is a steep descent. When I am about 200AGL, I increase speed to 55kts to provide energy for the flair. You can brake as hard as possible with the Helio and there is no chance of it nosing over because the gear is so far forward. If you're going to end up at 55 on the bottom end why slow to 45? -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Mike Rapoport wrote:
What I have found to be the best technique in the Helio at about 3100lbs is to slow way down to about 45kts. This will yeild about 500fpm with 11"MP which is a steep descent. When I am about 200AGL, I increase speed to 55kts to provide energy for the flair. You can brake as hard as possible with the Helio and there is no chance of it nosing over because the gear is so far forward. What I found last week is that these speeds and power setting do not work well at 3400lb. I need quite a bit more speed. I will have to figure out what the numbers should be. I was quite surprised at the difference. Try 50 initial, accelerate to 60 at 3400 lbs. (that's a guess using math formula based on what you posted) To be accurate, I need max gross weight and stall speed at max gross. |
Thanks. There is no stall speed on a Helio.
Mike MU-2 "john smith" wrote in message .. . Mike Rapoport wrote: What I have found to be the best technique in the Helio at about 3100lbs is to slow way down to about 45kts. This will yeild about 500fpm with 11"MP which is a steep descent. When I am about 200AGL, I increase speed to 55kts to provide energy for the flair. You can brake as hard as possible with the Helio and there is no chance of it nosing over because the gear is so far forward. What I found last week is that these speeds and power setting do not work well at 3400lb. I need quite a bit more speed. I will have to figure out what the numbers should be. I was quite surprised at the difference. Try 50 initial, accelerate to 60 at 3400 lbs. (that's a guess using math formula based on what you posted) To be accurate, I need max gross weight and stall speed at max gross. |
RIP Mike Valentine | Mal | Soaring | 0 | December 11th 04 08:27 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Home Built | 1 | December 3rd 04 09:16 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Piloting | 1 | December 3rd 04 09:16 PM |
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga | Jay Honeck | Owning | 0 | December 3rd 04 08:25 PM |
PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 03:36 AM |
