"RV9" wrote in message
... You say that you are required to carry an extinguisher. I assume that the regulation specifies the minimum rating of the extinguisher - if not the agent. Haven't found the regulation pertaining to the quantity, though 2 lbs. seems the norm. If anyone has the specific information, that would be appreciated. The regs probably specify a numerical rating rather than a weight. In addition to the number, there should be some letter(s) which rate the extinguisher for the type of fire. A = Ordinary combustibles, B = Flammable liquids, C = Suitability for fires involving electricity, D = Flammable metals, etc. I must admit that I have been out of the fire business for twenty years and much of my knowledge is out-of-date, especially where regulations are concerned. Here's an explanation of an extinguisher's rating taken from the NFPA question and answer page: I have a dry chemical fire extinguisher rated 2-A:10-B:C. What does that rating mean? Extinguishers achieve their ratings by putting out fires in laboratory settings. The fire test standard is UL711, Standard for Rating and Fire Testing of Fire Extinguishers. For the 2-A rating, 78 pieces of trade-sized 2-by-2-by-255/8 inch (5-by-5-by-66 centimeter) spruce or fir are placed in a wood crib in 13 layers, then ignited and allowed to burn for 10 minutes. Another fire test uses a vertical wood panel with 10-by-10-foot (3-by-3-meter) furring strips. A third traditional fire test using excelsior may be eliminated. The 10-B test involves a 25-square-foot (2.3-square-meter) pan of heptane. The C rating doesn't involve fire, but requires that the extinguishing agent not conduct electricity when discharging across a 10-inch (25-centimeter) air gap between a grounded plate and a potential of 100,000 volts AC. If the fires are extinguished during the tests, the extinguisher gets the rating. Rich S. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
