"Refusing to Handle You"
Old July 17th 05, 05:44 AM
Jose
I am given the route via SCAPE, but I
"unable" that for weather, and they go away for a few minutes, and then
clear me as filed. I take off, and everything is fine, until I'm headed
southbound from the HGR VOR, when the Washington Center controller
calls me and says "Err, 8096J, Potomac Approach is refusing to handle
you, say intentions."
"I intend to fly my clearance. What are yours?" Hmmph.
Ok, might not put it quite that way, but I have a clearance and the
alternative of flying through thunderstorms is not acceptable. I think
I might ask what they mean "refused to handle me", but in any case a
NASA report is in order.
I would refuse to fly through thunderstorms to make them happy. If I
had spherics I would have more options, but blind and knowing what's
probably out there, I would have solid grounds for saying "unable" and
letting them sort it out later.
Jose
Nothing takes longer than a shortcut.
Old July 17th 05, 04:40 PM
Steven P. McNicoll
"Jose" wrote in message
An odd thing to say after you've been told that's not an option.
I'm sure the controller understands that. That's why he asked you for your
intentions after informing you that your previous clearance was not
acceptable.
Why would they find happiness in your flight through a thunderstorm?
If I had
spherics I would have more options, but blind and knowing what's probably
out there, I would have solid grounds for saying "unable" and letting them
sort it out later.
You'd be unable to do anything other than your previous clearance? How
could that be?
Old July 18th 05, 02:05 AM
Richard Kaplan
Sure it was an option. That was his clearance and the clearance remains
valid until he accepts a new one.
Richard Kaplan
www.flyimc.com
Old July 18th 05, 09:12 PM
Steven P. McNicoll
"Richard Kaplan" wrote in message
news:1121648744.326f39a050170b4a3dc316b048821a11@t eranews...
So a pilot is under no obligation to accept any change to his clearance?
What do you base that on? What about the traffic that's creating the need
for the amended clearance? They're also operating on a clearance that
remains valid until acceptance of a new one, are they not?
Old July 18th 05, 11:00 PM
Richard Kaplan
I never said that. I said a pilot is under no obligation to accept any
change to his clearance which the pilot feels is unsafe.
Richard Kaplan
www.flyimc.com
Old July 19th 05, 01:34 PM
Steven P. McNicoll
news:1121724013.a978ad36df82d0f25296e0ee95ad9be6@t eranews...
So "unable reroute due to weather" means "unable any reroute that puts me
into weather"?
Old July 18th 05, 05:19 PM
Jose
Well, "Potomac is refusing to accept you, what are your intentions" is
also an odd thing to say. It's the equivalent of "get lost kid, you
bother me", which is exactly what Potomac is saying to the controller
who is (presumably) just relaying the message to the pilot. It makes
ATC's coordination problem into the pilot's problem to solve.
Because if the thunderstorm is outside of Potomac's airspace, Potomac
doesn't have to deal with you. "It's not my watch". Of course I don't
really believe airborne shredded aluminum makes anybody involved here
happy, my phrasing "make them happy" is metaphorical.
could that be?
The only thing I have is my previous clearance.
I would expect the controllers to work with me to get an acceptable
reroute, not to dump the thing in my lap saying "you can't go here any
more". That is getting close to the controller saying "IFR cancelled,
squawk 1200" while I'm in the soup.
I have my previous clearance. I would fly that unless (and until) I got
something acceptable to both me and the controller. But the controller
saying "Potomac won't handle you, what are your intentions" is
inappropriately confrontational. If Potomac won't accept the clearance
that ATC has already given me, that's ATC's problem to solve, and they
should offer (or at least appear to be prepared to offer) some solutions.
Jose
Old July 18th 05, 07:53 PM
Richard Kaplan
Exactly correct.
Richard Kaplan
www.flyimc.com
Old July 19th 05, 03:20 AM
Steven P. McNicoll
m...
Why's that?
bother me", which is exactly what Potomac is saying to the controller who
is (presumably) just relaying the message to the pilot. It makes ATC's
There's no coordination problem. The problem is the pilot has a route he
can't fly. ATC is going to change his route, the problem will be solved at
that time. ATC is just asking the pilot for his input. Isn't that better
than deciding for him?
But you're going to get a new one. That's why the controller is asking for
your intentions. So that your new clearance can be as close as possible to
what you'd like to do. Would you want it any other way?
more".
He's trying to do exactly that. That's why he said "say intentions."
Bull****. The guy seems to have been overly accommodating.
They're going to solve that problem by directing you away from Potomac
approach. Your choices are to either follow ATC instructions or continue
into Potomac approach contrary to ATC instructions and face the
consequences.
Old July 19th 05, 05:42 AM
Jose
Why's that?
Because ATC is supposed to be helpful, and this is not. The pilot has
no idea what "Potomac" is (from a routing standpoint) or for how long
they will be refusing to honor the clearance the pilot =already= has.
Therefore the pilot has no basis from which to plan a new routing, or to
consider the altenratives. The only alternatives that are clear are to
turn around, hold, or land, but those are likely not the only
alternatives avaliable.
ATC however does know the pilot's destination and equipment, and
probably has a pretty good idea of what the weather and traffic ahead
is. Therefore ATC is in a good position to offer helpful alternatives.
They are refusing to do so.
Empirically, it's an odd thing to say because it is rarely said. That
by itself makes it odd.
can't fly.
The pilot certainly can fly that route. ATC doesn't want him to.
Specifically Potomac doesn't want him to.
Meaningful input requires information that ATC has, that the pilot
doesn't, and that ATC is pointedly not giving the pilot.
But the controller
Perhaps we have different definitions of "accomodating".
Let's see if I can learn something, and turn this around. It's =you=
flying up the coast, say to Teterboro. You're directly on the other
side of Potomac Approach's airspace (whatever shape it happens to be at
that time). For argument's sake, you're at 5000 feet in a rental 172RG
with a moving map GPS, no radar, no spherics, and no weather imagery
available to you (except via descriptions on the radio). You have three
and a half hours of gas, and have a clearance through to your
destination, which takes you in between building TCU. There are cells
to your west and northwest somewhere, maybe forty miles off your route.
You're IMC.
"N423YL, Potomac is refusing to handle you. What are your intentions?"
How do you respond?
Jose
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
G103 Acro airbrake handle Andy Durbin Soaring 12 January 18th 04 11:51 PM
How do you handle your EFB in the cockpit? greg Instrument Flight Rules 5 November 17th 03 03:47 AM
Need door handle for 1959 Cessna 175 Paul Millner Owning 0 July 4th 03 07:36 PM
