"Dave S" wrote in message And if "standing your
ground" results in a hold in current position until you choose to land, reverse course, or accept the offered routing, then what? I suppose anything is possible but that is highly unlikely. In any event, the proper response is to state "Unable" and then wait to see what the controller says. Most likely the controller will then offer to work with you with a hold and/or vectors around traffic that will more or less be equivalent to the route you need. Now I agree the controller might instead come back not with a terse "Potomac will not accept you" but rather "There has been a major incident and BWI is closed" or something catastrophic like that, in which case yes, landing might be your only option. But 99% of the time "Unable" will indeed prompt ATC to come up with another plan. If you declare an "emergency" then the expectation is that you will land at the nearest suitable airport. I am not at all proposing to declare an emergency. I am proposing the pilot fly his clearance and not accept any alternate clearance which he feels is unsafe. There is nothing of an emergency nature here. There is no reason the posting pilot couldn't have landed and waited the weather out. ATC would have to give me a good reason for me to do that -- the reason would have to be more than "Potomac is not accepting traffic." What if the area of unavailable airspace was a hot MOA or Restricted area? Then ATC would have to contact the relevant military aircraft and make the airspace cold if weather requires their airspace to be used for traffic already on an IFR clearance. I've been rerouted enroute because of an area going hot after i No problem if there are no weather or other reasons to preclude your reroute. I am not saying to decline the new clearance arbitrarily -- only to decline it if there are weather concerns. whats available), turn back or land. The controller cant offer what he doesnt have available. If you tell the controller you are "Unable" to accept an alternate route, he may well be able to negotiate for more airspace to become available. Bottom line: A clearance is a clearance. You must accept an assigned revised clearance if it is within your capability, but if you judge the revised clearance to be unsafe there is no reason why you need to accept it and instead ATC will work with you to find a solution. -------------------- Richard Kaplan www.flyimc.com |
![]() Richard Kaplan wrote: What if the area of unavailable airspace was a hot MOA or Restricted area? Then ATC would have to contact the relevant military aircraft and make the airspace cold if weather requires their airspace to be used for traffic already on an IFR clearance. Oh? I've read quite a bit of stuff, and I've yet to come across something that lets ATC take a MOA or Restricted area back at their choosing. Tell me where that procedure is found. Back to the original point... You dont have to accept what they are offering. But they dont have to offer you what you want (or NEED). They also cant offer what the "system" wont provide. Your options can be as harsh as "cancel IFR" and scud run, or land at the nearest field and sort it out on the ground. The phrase " XXX approach is refusing to handle you" tells me that they are not going to play ball. No telling what the reason is, from the original post. Perhaps the airspace was busy, perhaps there was a "push" going on in the middle of the desired sectors, perhaps what you wanted was contrary to an exiting LOA between center and approach, and approach was within their right to say "preferred routing or go all the way around". No matter how you cut it, unless you are excercising emergency authority, you have to go where they tell you. Usually this isnt a prob, and most of the times they can work with you. But.. push comes to shove, you have to fly your clearance. If you dont accept it, you are the one who has to deal with it if no other alternatives are forthcoming. Dave |
![]() "Dave S" wrote Oh? I've read quite a bit of stuff, and I've yet to come across something that lets ATC take a MOA or Restricted area back at their choosing. ATC often is in communication with aircraft in the MOA or Restricted area. I have had times when I have been vectored through an MOA or Restricted area which is officially hot but the controller advises me he has coordinated with the aircraft in that area. Back to the original point... You dont have to accept what they are offering. But they dont have to offer you what you want (or NEED). They also cant offer what the "system" wont provide. I think we probably agree here. The point is that there needs to be negotiation both ways. You are correct that sometimes ATC cannot give you what you want. It is also equally correct that a pilot does not need to accept whatever re-route is given to him if there is a potential safety of flight issue. Certainly "Unable re-route into convective weather" or "Unable re-route to SCAPE due to convective wather" should be accepted by ATC. Considering in this case the re-route is at their request (not for example a pilot request to deviate around weather), it seems to me incumbent upon ATC to propose a solution... the solution may be a different altitude or vectors for spacing or a brief hold but certainly it is not reasonable for ATC to expect a re-route to an area of active or even potentially active thunderstorms and I do not think ATC requiring someone to land short of their destination is appropriate either absent some critical infrastructure failure or national security event. the nearest field and sort it out on the ground. The phrase " XXX approach is refusing to handle you" tells me that they are not going to play ball. Actually the phrase "Approach is refusing to handle you" tells me this is ATC's problem, not mine, and they need to come up with the solution, not me. I would tend to be much more flexible if ATC told me about some specific reason why airspace I was already cleared into is all of a sudden not available. Just telling me some ATC facility "is refusing to handle you" seems bizarre to me if I have already been cleared through that airspace. Perhaps the airspace was busy, perhaps there was a "push" going on in the middle of the desired sectors, perhaps what you wanted was contrary to an exiting LOA between center and approach, and approach was within their right to say "preferred routing or go all the way around". All of which are contrary to my existing clearance in this case and thus suggest to me that ATC ought to be a bit more helpful in proposing a solution that does not involve thunderstorms. No matter how you cut it, unless you are excercising emergency authority, you have to go where they tell you. No, there is no emergency authority needed here. Saying "Unable Re-Route through convective weather" is no different than when ATC misunderstands the performance of my piston plane and requests an expedited climb in hot weather at a rate of climb my plane is unable to deliver. "Unable" means just what is says --- my plane is unable to fly through convective weather and it is unable to maintain an 800FPM climb in the flight levels. I need no emergency authority to advise ATC of this. and most of the times they can work with you. But.. push comes to shove, you have to fly your clearance. Correct... you have to fly the clearance that you accepted. You do NOT need to accept a new clearance if your airplane is unable for performance or safety reasons to fly that new clearance. If you dont accept it, you are the one who has to deal with it if no other alternatives are forthcoming. In the case described here, it is incumbent on ATC to propose an alternate clearance within my airpane's abilities. -------------------- Richard Kaplan www.flyimc.com |
![]() "Richard Kaplan" wrote in message news:1121692673.581a839e2ccbc36555a8723f0d1f42f7@t eranews... ATC often is in communication with aircraft in the MOA or Restricted area. I have had times when I have been vectored through an MOA or Restricted area which is officially hot but the controller advises me he has coordinated with the aircraft in that area. ATC is sometimes in communication with aircraft in a MOA or Restricted Area, but usually not. I think we probably agree here. The point is that there needs to be negotiation both ways. Yes, exactly, that's the point that a few of us have been trying to get across to you. You are correct that sometimes ATC cannot give you what you want. It is also equally correct that a pilot does not need to accept whatever re-route is given to him if there is a potential safety of flight issue. Certainly "Unable re-route into convective weather" or "Unable re-route to SCAPE due to convective wather" should be accepted by ATC. Yes, but you didn't suggest either of those responses, you advocated responding with, "Unable reroute due to weather". Considering in this case the re-route is at their request (not for example a pilot request to deviate around weather), it seems to me incumbent upon ATC to propose a solution... That's easy to do. "Cleared to Hagerstown Regional Airport via direct Hagerstown VOR direct." How's that? the solution may be a different altitude or vectors for spacing or a brief hold but certainly it is not reasonable for ATC to expect a re-route to an area of active or even potentially active thunderstorms There is nothing in the OP that suggested that. and I do not think ATC requiring someone to land short of their destination is appropriate either absent some critical infrastructure failure or national security event. There is nothing in the OP that suggested that. Actually the phrase "Approach is refusing to handle you" tells me this is ATC's problem, not mine, and they need to come up with the solution, not me. And they will, you can be sure of that, even if you refuse to provide any input towards it. But why wouldn't you want to provide any input? I would tend to be much more flexible if ATC told me about some specific reason why airspace I was already cleared into is all of a sudden not available. Just telling me some ATC facility "is refusing to handle you" seems bizarre to me if I have already been cleared through that airspace. It appears the controller that issued the departure clearance was a bit too accommodating. When the pilot declined the original clearance he probably should have replied, "Unable, that'll take you into Potomac approach." Instead, he tried to help him on his way, probably hoping that he could convince Potomac to accept him. That didn't work. Potomac approach says he can't go through their airspace and that settles that issue. The pilot cannot simply refuse all amendments to his clearance without reason. If he had gone through Potomac approach contrary to ATC instructions you can be sure he'd have spent some time as a non-pilot. All of which are contrary to my existing clearance in this case and thus suggest to me that ATC ought to be a bit more helpful in proposing a solution that does not involve thunderstorms. What part of "Say intentions" do you not understand? The controller knows you don't want to go through the weather and he's just informed you that you're not going through Potomac approach. So tell him what you do want to do! If he can accommodate you you'll be cleared that way, if not he may suggest an alternative. How do you expect him to know what you want if you don't tell him? Stop being an asshole and start being a pilot. No, there is no emergency authority needed here. Saying "Unable Re-Route through convective weather" is no different than when ATC misunderstands the performance of my piston plane and requests an expedited climb in hot weather at a rate of climb my plane is unable to deliver. "Unable" means just what is says --- my plane is unable to fly through convective weather and it is unable to maintain an 800FPM climb in the flight levels. I need no emergency authority to advise ATC of this. What reroute through convective weather are you referring to? Correct... you have to fly the clearance that you accepted. You do NOT need to accept a new clearance if your airplane is unable for performance or safety reasons to fly that new clearance. But that's not the situation we're discussing. In the case described here, it is incumbent on ATC to propose an alternate clearance within my airpane's abilities. Then when asked for your intentions don't respond with "Unable reroute due to weather", respond with "I'll accept any alternate clearance within my airpane's abilities." |
![]() What part of "Say intentions" do you not understand? The controller knows you don't want to go through the weather and he's just informed you that you're not going through Potomac approach. So tell him what you do want to do! If he can accommodate you you'll be cleared that way, if not he may suggest an alternative. How do you expect him to know what you want if you don't tell him? Stop being an asshole and start being a pilot. Steven, I don't know if you are a pilot who flies solo IFR. But in the cockpit of most singles or light twins on an IFR flight plan the "big picture" of nearby convective activity is usually not available in real time. The pilot perhaps spent 15-30 minutes studying the airspace and weather, filed an IFR flight plan, had the clearance issued and launched. He understood that he might be issued an amended clearance (most of us are prepared for that), a hold or be given a vector for deviation but it is difficult to expect him to in essence file a new "flight plan" in the air without "all the information" necessary for the flight (as the FARs state). The ATC at that point in time knows the "big picture" much better than the pilot (closed airspace, severe weather, etc.) and it would be helpful if they could present him with a workable alternate plan which he could then analyze and either accept or reject. Within the previous hour the pilot had analyzed many factors, planned a flight and submitted it. It was accepted. Now he might repeat that process with less information available, propose it, and then have it rejected again. Perhaps repeat the cycle several times not really knowing what ATC wants. All this while flying the airplane in less than optimal weather. There are still planes out there flying IFR below the flight levels, using VHF radios and sporting numbers that begin with N. It's a messy system but we have to work together. As I said earlier I have never run across this scenario before. Usually the controller will issue an amended clearance or propose a couple of alternatives which will work for both of us. Howard C182P |
![]() "Howard Nelson" wrote in message m... Steven, I don't know if you are a pilot who flies solo IFR. I have. But in the cockpit of most singles or light twins on an IFR flight plan the "big picture" of nearby convective activity is usually not available in real time. The pilot perhaps spent 15-30 minutes studying the airspace and weather, filed an IFR flight plan, had the clearance issued and launched. Heunderstood that he might be issued an amended clearance (most of us are prepared for that), a hold or be given a vector for deviation but it is difficult to expect him to in essence file a new "flight plan" in the air without "all the information" necessary for the flight (as the FARs state). He's not expected to do that. He's expected to tell the controller what he'd like to do; "I'd like routing around Potomac approach", "I'd like routing around the weather", "I'd like to go back to Hagerstown and wait out the weather", "8096J canceling IFR, have a nice day." The ATC at that point in time knows the "big picture" much better than the pilot (closed airspace, severe weather, etc.) and it would be helpful if they could present him with a workable alternate plan which he could then analyze and either accept or reject. A workable alternate plan will be presented as soon as the pilot decides what he wants to do. Within the previous hour the pilot had analyzed many factors, planned a flight and submitted it. It was accepted. Now he might repeat that process with less information available, propose it, and then have it rejected again. Perhaps repeat the cycle several times not really knowing what ATC wants. All this while flying the airplane in less than optimal weather. There are still planes out there flying IFR below the flight levels, using VHF radios and sporting numbers that begin with N. It's a messy system but we have to work together. As I said earlier I have never run across this scenario before. Usually the controller will issue an amended clearance or propose a couple of alternatives which will work for both of us. That's not the situation at all. You're making this far more complicated than it is! With "say intentions" the controller is just asking what the pilot wants in a very general way. He's expecting a response like, "I'd like routing around Potomac approach." He doesn't expect you to know the approach boundaries. |
![]() "Dave S" wrote in message ink.net... Back to the original point... You dont have to accept what they are offering. But they dont have to offer you what you want (or NEED). They also cant offer what the "system" wont provide. In this case ATC wasn't offering anything, the controller just informed the pilot that he couldn't go through Potomac approach and asked him for his intentions. A few somehow got the idea that ATC was requiring the pilot to fly through nasty weather. The pilot needs to decide on an alternative that avoids the weather and Potomac approach. His options are diverting to another airport, flying around the other side of Potomac approach, or cancel IFR and go VFR clear of Class B airspace. |
"Richard Kaplan" wrote:
I suppose anything is possible but that is highly unlikely. In any event, the proper response is to state "Unable" and then wait to see what the controller says. This started out with Wash Center: "Err, 8096J, Potomac Approach is refusing to handle you, say intentions." I don't think "unable" is a useful response to "say intentions". |
"Roy Smith" wrote in message
I don't think "unable" is a useful response to "say intentions". I think "Unable routing through SCAPE or other convective weather; please propose alternative re-route" would be fine. -------------------- Richard Kaplan www.flyimc.com |
![]() "Richard Kaplan" wrote in message news:1121692774.c01dc1e7a3768ab5fcc211551cdda8b3@t eranews... I think "Unable routing through SCAPE or other convective weather; please propose alternative re-route" would be fine. That's certainly better than "Unable." Note that the controller did not attempt to issue routing through SCAPE or other convective weather. |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
G103 Acro airbrake handle | Andy Durbin | Soaring | 12 | January 18th 04 11:51 PM |
How do you handle your EFB in the cockpit? | greg | Instrument Flight Rules | 5 | November 17th 03 03:47 AM |
Need door handle for 1959 Cessna 175 | Paul Millner | Owning | 0 | July 4th 03 07:36 PM |
