![]() "Richard Kaplan" wrote in message news:1121655367.94780c5d45d39e3a9574ee99bb5f5c1b@t eranews... I suppose anything is possible but that is highly unlikely. In any event, the proper response is to state "Unable" and then wait to see what the controller says. Most likely the controller will then offer to work with you with a hold and/or vectors around traffic that will more or less be equivalent to the route you need. One property of the route needed in this case is that it not go through Potomac approach. The controller demonstrated he was willing to work with the pilot when he informed him of that requirement and asked him his intentions. Your suggested response of "unable" isn't helpful at all and suggests an unwillingness to work with ATC. Now I agree the controller might instead come back not with a terse "Potomac will not accept you" but rather "There has been a major incident and BWI is closed" or something catastrophic like that, in which case yes, landing might be your only option. It doesn't have to be anything catastrophic, it could just be normal traffic. As I said in an earlier message, there are TRACONs that simply do not allow thruflights. It's not because they're too good to work thruflights, it's because they're up to their armpits with arrival and departure traffic. I am not at all proposing to declare an emergency. I am proposing the pilot fly his clearance and not accept any alternate clearance which he feels is unsafe. There is nothing of an emergency nature here. The pilot wasn't asked to fly a clearance he felt was unsafe. He was aware of an area of weather that he wouldn't fly through and he was informed that he couldn't fly through Potomac approach. He needs an alternative that avoids both of those, that's why the controller asked him his intentions. ATC would have to give me a good reason for me to do that -- the reason would have to be more than "Potomac is not accepting traffic." Why isn't that good enough? Once the center controller is informed that Potomac approach won't accept you he has to revise your clearance in some manner so that you do not enter Potomac approach. Then ATC would have to contact the relevant military aircraft and make the airspace cold if weather requires their airspace to be used for traffic already on an IFR clearance. No, ATC would have to amend your clearance to avoid SUA. If you tell the controller you are "Unable" to accept an alternate route, he may well be able to negotiate for more airspace to become available. But probably not. Bottom line: A clearance is a clearance. You must accept an assigned revised clearance if it is within your capability, but if you judge the revised clearance to be unsafe there is no reason why you need to accept it and instead ATC will work with you to find a solution. Now you're whistling a different tune. |
![]() "Steven P. McNicoll" wrote in message Now you're whistling a different tune. Overall I think I agree with the points you are making except I just do not think it is reasonable for ATC to say "Potomac refuses to work you" when they just issued a clearance through that airspace 10 minutes ago. If Potomac never works through flights then do not issue clearances -- it is one thing if the clearance were issued 500 miles away but a flight departing HGR ought to be processed in a way that knows if Potomac will accept through clearances. And therein lies the issue here... legal or not, safe or not, is just seems absolutely poor service for a sector to flat-out "refuse" an airplane with no explanation right after takeoff. I think at the minimum some better explanation should be given to the pilot to understand what his happening and let him propose an alternate plan to ATC. The fact that ATC said "State intentions" rather than offer a re-route suggests ATC was surprised by this as well. And most important of all, I suspect this may have been a subtle suggestion to the IFR pilot to cancel and go VFR and I think that is particularly disappointing and frankly unacceptable. "State Intentions" usually occurs only when ATC has no clue what you want to do or wants to give you some hint as to what they want you to do... neither seems appropriate here. -------------------- Richard Kaplan www.flyimc.com |
![]() "Richard Kaplan" wrote in message news:1121727600.b3bc3a1423b9b3b0f6d273c7323e0e2a@t eranews... Overall I think I agree with the points you are making except I just do not think it is reasonable for ATC to say "Potomac refuses to work you" when they just issued a clearance through that airspace 10 minutes ago. If Potomac never works through flights then do not issue clearances -- it is one thing if the clearance were issued 500 miles away but a flight departing HGR ought to be processed in a way that knows if Potomac will accept through clearances. Okay. Fine. The center controller was wrong to issue the requested routing. He should have told the pilot the only way he could go IFR was via the preferential routing. Damn him for trying to do the pilot a favor! The point you have to understand is that once Potomac approach says they can't accept your flight the only way you're going through that airspace is contrary to ATC instructions. And therein lies the issue here... legal or not, safe or not, is just seems absolutely poor service for a sector to flat-out "refuse" an airplane with no explanation right after takeoff. I think at the minimum some better explanation should be given to the pilot to understand what his happening and let him propose an alternate plan to ATC. Well, that's essentially what the controller did when he said "state intentions", he invited the pilot to propose an alternate plan to ATC. The fact that ATC said "State intentions" rather than offer a re-route suggests ATC was surprised by this as well. Perhaps, but there's still no excuse for your suggested response. And most important of all, I suspect this may have been a subtle suggestion to the IFR pilot to cancel and go VFR and I think that is particularly disappointing and frankly unacceptable. Canceling IFR and proceeding VFR is one possible solution but is in no way suggested by "state intentions". The controller just wants to know what you want to do given that you're not going to be continuing on your current clearance. So tell him. About half the people participating in this discussion seem to be under the impression that they must immediately respond with a route that avoids the weather and Potomac approach. That's not the case at all. The controller's expecting a response like, "I'd like routing around Potomac approach clear of the weather", or "I'd like routing around the weather", etc., etc., etc. Soliciting your input prior to issuing a new clearance saves time. "State Intentions" usually occurs only when ATC has no clue what you want to do That's exactly how it was used here. |
![]() -------------------- Richard Kaplan www.flyimc.com "Steven P. McNicoll" wrote in message Okay. Fine. The center controller was wrong to issue the requested routing. Thank you.. we agree. Damn him for trying to do the pilot a favor! Favor or not, changing a clearance in this type of weather is serious business. The controller ought to fix the problem by being more proactive in proposing solutions to the pilot. The point you have to understand is that once Potomac approach says they can't accept your flight the only way you're going through that airspace is contrary to ATC instructions. Or by convincing Potomac to work harder to fix their error. Well, that's essentially what the controller did when he said "state intentions", he invited the pilot to propose an alternate plan to ATC. The pilot did not need the extra workload; it would have been better for ATC to work harder with Potomac or else for ATC to propose a routing to the pilot. suggested by "state intentions". The controller just wants to know what you want to do given that you're not going to be continuing on your current That is obvious. The pilot wants to efficiently get to his destination. If ATC cannot honor their initial clearance then they should propose workable alternatives. It is obvious this is what the pilot wants. |
![]() "Richard Kaplan" wrote in message news:1121823244.3f20b0e8e6c677a1a5f1609735509f17@t eranews... Favor or not, changing a clearance in this type of weather is serious business. The controller ought to fix the problem by being more proactive in proposing solutions to the pilot. In what type of weather? Nothing in the OP indicated the pilot was in any significant weather at that point. The pilot wanted to fly from HGR to THV. Normally such flights are taken north over SCAPE to avoid Camp David but there was weather affecting that route. So he filed a route to the south to avoid the weather, HGR..MRB..EMI..THV. The problem with that route is it goes through Potomac approach. Hell, am I the only one that ever consults a map in these discussions? Or by convincing Potomac to work harder to fix their error. He tried as hard as he could, Potomac approach made no error. The pilot did not need the extra workload; There is no extra workload on the pilot. it would have been better for ATC to work harder with Potomac He made a maximum effort. or else for ATC to propose a routing to the pilot. ATC will do that as soon as the pilot decides where he wants to go. That is obvious. Then why did I have to explain it? The pilot wants to efficiently get to his destination. If ATC cannot honor their initial clearance then they should propose workable alternatives. It is obvious this is what the pilot wants. That is not obvious. The pilot may want to divert to another airport. The pilot has to tell the controller what he wants. I've explained this many times. Are you even trying to understand it, or are you just being argumentative? |
"Steven P. McNicoll" wrote:
Hell, am I the only one that ever consults a map in these discussions? Could be. The rest of us look at charts :-) |
Potomac approach. No. One property of the route =wanted= in this case is that it not go through Potomac approach. It appears from what the controller said that he didn't much care one way or the other. Now, maybe this controller tried everything he could and in frustration passed it on to the pilot. But it seems equally likely that Potomac just didn't want to handle him, and my response would be "try harder". I know - not very constructive, but I'm not in the air right now, I'm on Usenet. Your suggested response of "unable" isn't helpful at all and suggests an unwillingness to work with ATC. Their approach suggests an unwillingness to work with the pilot. As I said in an earlier message, there are TRACONs that simply do not allow thruflights. IFR? At any altitude? Why isn't that good enough? Once the center controller is informed that Potomac approach won't accept you he has to revise your clearance in some manner so that you do not enter Potomac approach. Because the pilot has no reasonable way of knowing where "Potomac Approach" is, especially since it changes with the whim and the weather. What is getting my dander up isn't the situation of an approach not being able to handle an aircraft at the moment. I'm sure it happens many times. Rather, the phrase "what are your intentions?" in this context (right after "we're not going to do this") hints at an unwillingness of ATC to work with the pilot(*). ATC is there =for= the pilots, not the other way around. I wonder how many airline pilots have heard "XYZ approach is refusing to handle you". (*) I will note that that same phrase is very empowering to the pilot in other situations. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. No. One property of the route =wanted= in this case is that it not go through Potomac approach. No, one property of the route WANTED in this case is that go through Potomac approach. The route is wanted by the pilot but Potomac approach says he can't go through Potomac approach. So, one property of the route NEEDED in this case is that it NOT go through Potomac approach. You can't always get what you want, you get what you need. It appears from what the controller said that he didn't much care one way or the other. Now, maybe this controller tried everything he could and in frustration passed it on to the pilot. But it seems equally likely that Potomac just didn't want to handle him, and my response would be "try harder". That answer just wastes time. It's already been decided that you're not going through Potomac approach. Their approach suggests an unwillingness to work with the pilot. The controller demonstrated a willingness to work with the pilot when he issued the pilot's requested routing at departure instead of the preferential route. Nothing in the OP's message suggests a change in his attitude. IFR? At any altitude? Yes. Because the pilot has no reasonable way of knowing where "Potomac Approach" is, especially since it changes with the whim and the weather. Potomac approach boundaries are fixed. The pilot doesn't need to know where they are, the controller does. All the pilot has to do is decide if he wants to go around Potomac approach, or go around the weather, or divert to another airport or cancel and go IFR. That's the information the controller's seeking with, "say intentions." What is getting my dander up isn't the situation of an approach not being able to handle an aircraft at the moment. I'm sure it happens many times. Rather, the phrase "what are your intentions?" in this context (right after "we're not going to do this") hints at an unwillingness of ATC to work with the pilot(*). ATC is there =for= the pilots, not the other way around. Okay. You think seeking pilot input prior to deciding on a course of action hints at an unwillingness of ATC to work with the pilot. It's actually the opposite. I wonder how many airline pilots have heard "XYZ approach is refusing to handle you". Conduct a survey. |
You can't always get what you want, you get what you need. But only if you try, and then only sometimes. |
approach. The route is wanted by the pilot but Potomac approach says he can't go through Potomac approach. So, one property of the route NEEDED in this case is that it NOT go through Potomac approach. You can't always get what you want, you get what you need. No, one property of the route WANTED by Potomac approach is that it not go through there. Who's wagging the what? Potomac approach boundaries are fixed. The pilot doesn't need to know where they are, the controller does. All the pilot has to do is decide if he wants to go around Potomac approach Whether they are fixed or not is not information readily available to the pilot (there are plenty of examples of controller boundaries that are not fixed). And the pilot =does= need to know what the boundaries are in order to make an intellegent decision as to whether to go around it or do something else. I wonder how many airline pilots have heard "XYZ approach is refusing to handle you". Conduct a survey. OK. For all airline pilots on this newsgroup who are willing to participate, please post here whether or not you have ever heard in flight a controller say that "XYZ approach is refusing to handle you, say intentions" (for the pedants, replace XYZ by any approach). "NO" answers are just as important as "YES" answers. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
G103 Acro airbrake handle | Andy Durbin | Soaring | 12 | January 18th 04 11:51 PM |
How do you handle your EFB in the cockpit? | greg | Instrument Flight Rules | 5 | November 17th 03 03:47 AM |
Need door handle for 1959 Cessna 175 | Paul Millner | Owning | 0 | July 4th 03 07:36 PM |
