Autopilot and ILS crashes 747
Old July 18th 05, 06:15 AM
R.V. Gronoff
Sammy Yousef a écrit :
Hi,
I'm relatively new to FS2004, and I'm just trying to learn to land the
747 using ILS and autopilot.
I've set up a flight where I'm just about to capture the glide path at
2000ft at Sydney airport. I have no problem capturing the glide path.
Alt switches off on the autopilot when I intercept. However the
autopilot was crashing the 747 on landing. It was bobbing the aircraft
up and down slightly, which I believe was causing the problem. I started
speeds from 140 knots to 200 in increments of 10. 140 falls out of the
sky. 170 crashes, 150 is perfect (no crash).
Is this a bug or am I missing something vital? Does a real ILS behave
this way? Is there an easier way to determine the correct speed?
Nope, jumbos land at 150kt. In case you're a bit too high on the slope,
add 10-20kt then slow back to 150 when you're at the right alt.
Just for your knowledge: normal twin jets commercial planes (b737,
a320...) land at 135kt and private jets at 125-130.
Virez Saddam pour me répondre.
Remove Saddam to reply.
http://www.charles-de-gaulle.org
http://www.francelibre.net
http://www.concours-resistance.org
