KAP140 Autopilot Details
Old October 19th 03, 08:30 PM
Craig Prouse
"Dan Luke" wrote:
The heading bug plays no part in NAV tracking on S-Tec 30 or 50
autopilots. Why is it necessary on tha KAP-140?
If I recall correctly, those S-Tec autopilots require the pilot to establish
the aircraft on course before engaging the NAV course tracking mode. Once
on course, the error signal from the CDI is probably sufficient to remain
there.
The KAP 140 has the capability to compute an automatic intercept heading and
will take you to the desired radial or DTK then turn on course and track.
You can be anywhere, pointing in the wrong direction altogether, with a
full-scale deflection of the CDI, and the autopilot will turn you around and
get you on course. This requires a reference heading for orientation.
Old October 19th 03, 10:31 PM
Ron Natalie
"Craig Prouse" wrote in message ...
there.
Depends which model you have. The 20/30 will not intercept a course, just hold it.
The more expensive ones in the line will intercept the course.
Old October 19th 03, 10:54 PM
Craig Prouse
hold it.
Yes, when I said "those S-Tec autopilots" I was referring specifically to
"those," the 20/30.
The KAP 140 is similar in many respects to the S-Tec 55. Actually the 55 is
a little nicer in several ways. I expect that the 55 would also require a
heading reference to support its intercept feature.
It seems like a heading reference might improve the ability of an autopilot
to maintain course precisely or at least reduce any tendency to weave or
hunt while bracketing the course. Would anyone with direct experience like
to offer a comparison?
Old October 19th 03, 11:20 PM
Dan Luke
autopilot to maintain course precisely or at least reduce any
tendency to weave or hunt while bracketing the course. Would
anyone with direct experience like to offer a comparison?
I can only testify about my S-Tec 50, which is the same in this
respect as the 20 or 30. It works strictly off CDI deflection and rate
of turn. I don't think there is room for improvement. Using the GPS
CDI, once established on a track, it will maintain a xtrack error of
just a few feet without hunting. That is with the autopilot set to
"approach" sensitivity and the GPS CDI scale set to one mile.
Dan
C172RG at BFM
Details on Wittman Buttercup Charlie Home Built 1 November 25th 03 04:19 AM
Looking for a home for C130 autopilot amplifier... tongaloa Home Built 0 August 18th 03 06:44 PM
Kinda OT but... Trying to flog a Sperry SP 20 autopilot servo ampfor C130... tongaloa Home Built 0 August 8th 03 07:45 PM
Oshkosh Rec.Aviation Get-together details... Jay Honeck Home Built 2 August 3rd 03 04:31 PM
