Well, "Potomac is refusing to accept you, what are your intentions" is
also an odd thing to say. Why's that? Because ATC is supposed to be helpful, and this is not. The pilot has no idea what "Potomac" is (from a routing standpoint) or for how long they will be refusing to honor the clearance the pilot =already= has. Therefore the pilot has no basis from which to plan a new routing, or to consider the altenratives. The only alternatives that are clear are to turn around, hold, or land, but those are likely not the only alternatives avaliable. ATC however does know the pilot's destination and equipment, and probably has a pretty good idea of what the weather and traffic ahead is. Therefore ATC is in a good position to offer helpful alternatives. They are refusing to do so. Empirically, it's an odd thing to say because it is rarely said. That by itself makes it odd. The problem is the pilot has a route he can't fly. The pilot certainly can fly that route. ATC doesn't want him to. Specifically Potomac doesn't want him to. ATC is just asking the pilot for his input. Meaningful input requires information that ATC has, that the pilot doesn't, and that ATC is pointedly not giving the pilot. But the controller saying "Potomac won't handle you, what are your intentions" is inappropriately confrontational. Bull****. The guy seems to have been overly accommodating. Perhaps we have different definitions of "accomodating". Let's see if I can learn something, and turn this around. It's =you= flying up the coast, say to Teterboro. You're directly on the other side of Potomac Approach's airspace (whatever shape it happens to be at that time). For argument's sake, you're at 5000 feet in a rental 172RG with a moving map GPS, no radar, no spherics, and no weather imagery available to you (except via descriptions on the radio). You have three and a half hours of gas, and have a clearance through to your destination, which takes you in between building TCU. There are cells to your west and northwest somewhere, maybe forty miles off your route. You're IMC. "N423YL, Potomac is refusing to handle you. What are your intentions?" How do you respond? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote: Let's see if I can learn something, and turn this around. It's =you= flying up the coast, say to Teterboro. You're directly on the other side of Potomac Approach's airspace (whatever shape it happens to be at that time). For argument's sake, you're at 5000 feet in a rental 172RG with a moving map GPS, no radar, no spherics, and no weather imagery available to you (except via descriptions on the radio). You have three and a half hours of gas, and have a clearance through to your destination, which takes you in between building TCU. There are cells to your west and northwest somewhere, maybe forty miles off your route. You're IMC. "N423YL, Potomac is refusing to handle you. What are your intentions?" How do you respond? Good question. From my relaxed position in this comfy chair, my reply is "Well, I still need to get to Teterboro and I don't have any weather gear on board, what do you suggest?" If I was at 5,000, IMC and sweating about imbedded thunderstorms, I might not be so quick with an apt reply. -- Dan C172RG at BFM |
Jose wrote:
Let's see if I can learn something, and turn this around. It's =you= flying up the coast, say to Teterboro. You're directly on the other side of Potomac Approach's airspace (whatever shape it happens to be at that time). For argument's sake, you're at 5000 feet in a rental 172RG with a moving map GPS, no radar, no spherics, and no weather imagery available to you (except via descriptions on the radio). You have three and a half hours of gas, and have a clearance through to your destination, which takes you in between building TCU. There are cells to your west and northwest somewhere, maybe forty miles off your route. You're IMC. "N423YL, Potomac is refusing to handle you. What are your intentions?" How do you respond? I'm not quite sure where you intended that I am in your scenario, but I'll assume "the other side of Potomac" from Teterboro means I'm somewhere around Gordonsville VOR. Well, first I would ask myself what the heck I'm doing flying with no weather imagery and embedded thunderstorms all around me. That's not my idea of fun. Second, I would realize that I no longer have clearance through to my destination. Sure, we haven't yet dotted the I's and crossed the T's by agreeing on a new clearance, but it's already been made clear to me that the original plan just isn't happening any more. I need to come up with an alternative plan. There's two basic choices; land, or continue flying. Let's assume I decide I want to try to press on. I need to fly around or over Potomac's airspace. So, I might start by asking some questions: "If I climbed up to 9000, would that help?" Center comes back with, "Sorry, you'd need to get up to 13,000 to stay in Center airspace on that route, can you make that?" (I'm making that up, but it sounds plausable). "Unable 13,000. Tell you what, can you give me direct Salisbury VOR for now, and let me go off frequency for a while to talk to Flight Service?" "N423YL, cleared to the Salisbury VOR via direct, maintain 5000, report back on the frequency within 5 minutes". At that point, I'd call up Flight Watch, figure out what the weather is doing over there, and decide if I could continue or not. If things didn't look good weather-wise in that direction, or I just decided the workload was getting to high, I'd just pick a reasonable nearby airport and ask for clearance to it. Once on the ground, I could take my time and make a new plan. A couple of weeks ago, I departed BWI for HPN with ****ty weather reported at my destination, but forecast to clear up about by the time I got there. Along the way, we got a re-route the long way around (i.e. New York was refusing to work us). Called FSS, got a weather update, discovered things still sucked at HPN (1/8 mile in heavy rain), got back to ATC and told them I wanted to land at Allentown. Landed, bought some more fuel, met another pilot who was ferrying a Pitts from New Jersey to California and spent an hour swapping stories with him over lunch. By then, the weather had cleared up a bit, and off we went. |
now, and let me go off frequency for a while to talk to Flight Service?" "Unable Salsbury. I already told you Potomac is refusing to accept you." (I'm making up the fact that Salsbury is served by Potomac approach - you as a pilot have no good way to know what is and what isn't. In fact, Salsbury may only be served by Potomac from 3000 to 7000, but you are at 5000 and the controller is being as helpful and forthcoming now as he was originally). Now what? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Jose wrote:
"Unable 13,000. Tell you what, can you give me direct Salisbury VOR for now, and let me go off frequency for a while to talk to Flight Service?" "Unable Salsbury. I already told you Potomac is refusing to accept you." (I'm making up the fact that Salsbury is served by Potomac approach - you as a pilot have no good way to know what is and what isn't. In fact, Salsbury may only be served by Potomac from 3000 to 7000, but you are at 5000 and the controller is being as helpful and forthcoming now as he was originally). Now what? I'm not sure where this is going, but how about: "What clearance can you give me which will get me around to the east of Potomac's airspace?" Maybe he'll say something like, "I need to keep you about 5 miles south of Salisbury. Can you navigate direct to XXXXX and I'll try and get you something better after that?" Or maybe he'll say, "Unfortunately, I can't get you anywhere near there. The best I can do in that direction is blah, blah. Can you do that?" You seem to be expecting that he's going to say, "Bzzzt, wrong answer, try again". It doesn't work like that. It doesn't do either you or the controller any good to waste time playing 20 questions. He's just as interested in getting you where you're going as you are. Why is this such a complicated concept? You know what you want to do and you ask for it. If ATC is unable to give it to you, you decide what you want to do instead and ask for that. "Say intentions" should not be something pilots fear hearing. It's nothing more than a jargony way of saying, "What can I do for you?" If you can't come up with a useful answer to "say intentions", you have no business being PIC. |
"What clearance can you give me which will get me around to the east of Potomac's airspace?" Good enough. ...Or maybe he'll say, "Unfortunately, I can't get you anywhere near there. The best I can do in that direction is blah, blah. Can you do that?" Well, he's at this point offering something. He could have been offering something from the start, since he knows where I am and where I'm heading. A more helpful original call would have been: "Potomac can't take you right now. I can take you around twenty miles to the East if you like, or to the northwest direct XXX. Which would you prefer?" You seem to be expecting that he's going to say, "Bzzzt, wrong answer, try again". It doesn't work like that. No, it doesn't usually work like that. However, "you can't do that, what are you going to do about it?" sure makes it seem like the controller is playing that game. "Say intentions" should not be something pilots fear hearing. It's not. But "we've revoked your clearance. Say intentions." is. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Jose wrote:
"Say intentions" should not be something pilots fear hearing. It's not. But "we've revoked your clearance. Say intentions." is. "We've revoked your clearance" boils down to a re-route. Surely you're not saying that you fear getting a re-route? It happens all the time. "We've revoked your clearance, say intentions" is just a re-route plus an offer to let you decide how you would like to be re-routed. Why should that be something to fear? |
"We've revoked your clearance" boils down to a re-route. No, it boils down to "guess the reroute or go home." It only looks like an offer to let me decide how I would like to be rerouted - to =actually= decide I'd have to know what Potomac's airspace looks like. I don't, and should not be expected to. It's probably just a misunderstanding based on the controllers not being pilots, and the pilots not being controllers (and therefore not knowing what can and cannot be taken for granted), but in this context "say intentions" sounds like "what are you going to do about it?", which makes it seem like the controller is going to be non-helpful when the pilot is depending on the cooperation of the controller. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message ... Well, he's at this point offering something. Yup. All he needed was some idea of your intentions. He could have been offering something from the start, since he knows where I am and where I'm heading. But not what you want. A more helpful original call would have been: "Potomac can't take you right now. I can take you around twenty miles to the East if you like, or to the northwest direct XXX. Which would you prefer?" Well, those are obvious and not the only options. Stating the obvious just wastes time. No, it doesn't usually work like that. However, "you can't do that, what are you going to do about it?" sure makes it seem like the controller is playing that game. That's the way it seems to you. It's not that way. It's not. But "we've revoked your clearance. Say intentions." is. That wasn't said. |
Jose wrote:
I'm not sure where this is going, but how about: "What clearance can you give me which will get me around to the east of Potomac's airspace?" Good enough. ...Or maybe he'll say, "Unfortunately, I can't get you anywhere near there. The best I can do in that direction is blah, blah. Can you do that?" Well, he's at this point offering something. He could have been offering something from the start, since he knows where I am and where I'm heading. A more helpful original call would have been: "Potomac can't take you right now. I can take you around twenty miles to the East if you like, or to the northwest direct XXX. Which would you prefer?" You seem to be expecting that he's going to say, "Bzzzt, wrong answer, try again". It doesn't work like that. No, it doesn't usually work like that. However, "you can't do that, what are you going to do about it?" sure makes it seem like the controller is playing that game. "Say intentions" should not be something pilots fear hearing. It's not. But "we've revoked your clearance. Say intentions." is. Jose Exactly. They tear up my clearance constantly and issue new ones. The best I can think of is that since the entire plan basically got canceled, they were letting the OP rethink it all. |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
G103 Acro airbrake handle | Andy Durbin | Soaring | 12 | January 18th 04 11:51 PM |
How do you handle your EFB in the cockpit? | greg | Instrument Flight Rules | 5 | November 17th 03 03:47 AM |
Need door handle for 1959 Cessna 175 | Paul Millner | Owning | 0 | July 4th 03 07:36 PM |
