![]() "Jose" wrote in message ... Because ATC is supposed to be helpful, and this is not. Why isn't it helpful for ATC to ask the pilot's intentions? Do you think it'd be better if ATC decided on a remedial course of action without input from the pilot? The pilot has no idea what "Potomac" is (from a routing standpoint) The controller does. Ask him. or for how long they will be refusing to honor the clearance the pilot =already= has. Until about 2 AM. Therefore the pilot has no basis from which to plan a new routing, or to consider the altenratives. He knows he can't go through Potomac approach and he doesn't want to go through the weather, he needs to select an alternative to those. That shouldn't be too hard for any experienced pilot. ATC however does know the pilot's destination and equipment, and probably has a pretty good idea of what the weather and traffic ahead is. Therefore ATC is in a good position to offer helpful alternatives. They are refusing to do so. No they're not. Empirically, it's an odd thing to say because it is rarely said. That by itself makes it odd. That you haven't experienced it doesn't make it rare, it just means you're inexperienced. Many high density TRACONs simply do not work thruflights. The pilot certainly can fly that route. ATC doesn't want him to. Specifically Potomac doesn't want him to. The pilot can't fly that route because Potomac approach says he can't. Meaningful input requires information that ATC has, that the pilot doesn't, and that ATC is pointedly not giving the pilot. The pilot can ask, ATC can't read minds. Perhaps we have different definitions of "accomodating". Perhaps. I use Webster's. What do you use? Let's see if I can learn something, and turn this around. Oooh, something new! It's =you= flying up the coast, say to Teterboro. You're directly on the other side of Potomac Approach's airspace (whatever shape it happens to be at that time). For argument's sake, you're at 5000 feet in a rental 172RG with a moving map GPS, no radar, no spherics, and no weather imagery available to you (except via descriptions on the radio). You have three and a half hours of gas, and have a clearance through to your destination, which takes you in between building TCU. There are cells to your west and northwest somewhere, maybe forty miles off your route. You're IMC. "N423YL, Potomac is refusing to handle you. What are your intentions?" How do you respond? I respond with, "Never mind that center, my route takes me in between building TCU. N423YL requests clearance to Richmond via direct." |
The pilot has no
idea what "Potomac" is (from a routing standpoint) The controller does. Ask him. Supposed I asked. What would the answer be? (I'm more interested in how long it would take for the controller to communicate the relevant information). Therefore ATC is in a good position to offer helpful alternatives. They are refusing to do so. No they're not. Yes they are. We're back to Monty Python. The pilot wants to get to his destination efficiently. The controller knows what's 'open' and what's not, or is at least in a much better position to ascertain this. The pilot can ask, ATC can't read minds. ATC can read flight plans. Doing so would provide a clue as to what the pilot wants, unless things are so balled up that there really isn't any good way to get to the destination. In that case, ATC really doesn't know what the pilot would want. Otherwise, it pretty much goes without saying that the pilot wants to get to his destination, and that makes it reasonable for ATC to offer reasonable alternatives. Let's see if I can learn something, and turn this around. Oooh, something new! Actually, I learned something once before. ![]() "N423YL, Potomac is refusing to handle you. What are your intentions?" How do you respond? I respond with, "Never mind that center, my route takes me in between building TCU. N423YL requests clearance to Richmond via direct." "Unable direct Richmond, that takes you through Potomac. What are your intentions?" I made that up; I'm pretty sure that you know where Potomac lies and picked a good route, but if it were an unfamiliar approach, you might not reasonably know that direct wherever would take you through the closed approach. So, pretend with me that you didn't know the area, and are now faced with my reply. At some point you are likely to ask for suggested routings, and that's where I think the controller should have started. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message ... Supposed I asked. What would the answer be? (I'm more interested in how long it would take for the controller to communicate the relevant information). Probably the airways or VORs that define the route around it. Yes they are. We're back to Monty Python. No, you're just being Jose. You say ATC is refusing to offer helpful alternatives, but ATC wasn't asked for any alternatives, therefore it cannot be said that ATC is refusing to offer helpful alternatives. Well, I guess it can if you want to appear stupid. The pilot wants to get to his destination efficiently. How do you know he doesn't want to divert and wait out the weather? The controller knows what's 'open' and what's not, or is at least in a much better position to ascertain this. But not in a position to know what the pilot wants. ATC can read flight plans. Doing so would provide a clue as to what the pilot wants, unless things are so balled up that there really isn't any good way to get to the destination. In that case, ATC really doesn't know what the pilot would want. Now you're catchin' on! "Unable direct Richmond, that takes you through Potomac. What are your intentions?" No, it takes me into Potomac approach. I'm no longer a thruflight, I'm now an arrival. Potomac approach may not do thruflights, but they definitely do arrivals. I made that up; I'm pretty sure that you know where Potomac lies and picked a good route, but if it were an unfamiliar approach, you might not reasonably know that direct wherever would take you through the closed approach. So, pretend with me that you didn't know the area, and are now faced with my reply. As I explainedabove, it's not a closed approach anymore. At some point you are likely to ask for suggested routings, and that's where I think the controller should have started. Why would I need a route suggestion? My diversion takes care of the weather problem, I don't need any help navigating. |
No, you're just being Jose. And you're just being Steven. How do you know he doesn't want to divert and wait out the weather? It's not the weather that prompted the exchange, it was Potomac's refusal to accept the flight. Had it been the weather, the pilot would likely have requested the diversion first. Granted, maybe the weather contributes to Potomac's INABILITY to handle the flight, but REFUSAL does not imply INABILITY (though it does imply inconvenience). unless things are so balled up... Now you're catchin' on! "State intentions": "what are you going to do?" (controller has hands-off stance) "State request": "how can I help you?" (controller is offering coordination assistance - which is the controller's reason for being) No, it takes me into Potomac approach. I'm no longer a thruflight Got it. I'd have to know (or suspect) that the reason they are =refusing= to accept me is that they (as a matter of policy) don't take thruflights, and not that they are balled up by the weather, or don't like the position of my wings, or just don't feel like doing whatever it takes to squeeze me through. I would never (prior to this exchange) suspected that "they just don't do thruflights" or "today they aren't doing thruflights". Ok, in the future I'll try gaming the system. Everyone does that, and soon Potomac will refuse to accept incoming. Chicago will follow suit. That is what's happening. The pilots of all those air carrier jets streaming through the airspace you want to use are getting what they want. Traffic flows are dictated by air carrier needs because they're the biggest users. Some time back, in a different thread (about angelflight) you stated that angelflight did not get any priority, and continued to say that aircraft are handled on a first-come first-served basis. Your statement above seems to contradict that (otherwise I could just be scooted in front of the next jet that's not there yet). "Refusing" to accept you is different from "IS UNABLE" to accept you. Not in this case. Yes in this case, if they are "unable" to handle me because of all the jets that haven't gotten there yet. They are unable to handle me =and= give the jets priority. If what you say is operative, they are =unwilling= to not give the jets priority in order to let me through. ARTCC boundaries sometimes change, but they're on the charts. Maybe that's it, but as I recall it also had to do with altitudes, which to my knowledge are not charted in that detail. Then you haven't flown enough. Right. I could fly twice as much and it wouldn't be enough. ![]() Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message m... And you're just being Steven. Thank you. It's not the weather that prompted the exchange, it was Potomac's refusal to accept the flight. Weather was his reason for the route through Potomac approach. |
On Wed, 20 Jul 2005 03:45:23 GMT, Jose
wrote: That is what's happening. The pilots of all those air carrier jets streaming through the airspace you want to use are getting what they want. Traffic flows are dictated by air carrier needs because they're the biggest users. Some time back, in a different thread (about angelflight) you stated that angelflight did not get any priority, and continued to say that aircraft are handled on a first-come first-served basis. Your statement above seems to contradict that (otherwise I could just be scooted in front of the next jet that's not there yet). Well, how often is an air carrier flying low enough to be in approach airspace for an airport they're not landing at? Gets back to "they have to deal with arrivals, not throughflights". |
![]() "Jose" wrote in message m... "State intentions": "what are you going to do?" (controller has hands-off stance) State tr.v. stat·ed, stat·ing, states To set forth in words; declare. In·ten·tion n. 1. A course of action that one intends to follow. 2. An aim that guides action; an objective. So, "State intentions": "Declare a course of action that you intend to follow." (controller wants to know what the pilot would like to do) The phrases "say intentions" and "state intentions" are not standard phraseology. The phrase "advise intentions" is standard phraseology", the Pilot/Controller Glossary defines it as "tell me what you plan to do." "Say intentions" is far more common than "advise intentions", however. Got it. I'd have to know (or suspect) that the reason they are =refusing= to accept me is that they (as a matter of policy) don't take thruflights, and not that they are balled up by the weather, or don't like the position of my wings, or just don't feel like doing whatever it takes to squeeze me through. I would never (prior to this exchange) suspected that "they just don't do thruflights" or "today they aren't doing thruflights". It comes with experience. Some time back, in a different thread (about angelflight) you stated that angelflight did not get any priority, and continued to say that aircraft are handled on a first-come first-served basis. Your statement above seems to contradict that (otherwise I could just be scooted in front of the next jet that's not there yet). No contradiction. Aircraft are routed based on performance and destination, within those parameters they're handled on a first-come, first served-basis. Yes in this case, if they are "unable" to handle me because of all the jets that haven't gotten there yet. They are unable to handle me =and= give the jets priority. If what you say is operative, they are =unwilling= to not give the jets priority in order to let me through. They're coming in a steady stream. There's no room to let you through. What you're asking for is akin to crossing a busy interstate on a bicycle. |
Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 04:54 AM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
G103 Acro airbrake handle | Andy Durbin | Soaring | 12 | January 18th 04 11:51 PM |
How do you handle your EFB in the cockpit? | greg | Instrument Flight Rules | 5 | November 17th 03 03:47 AM |
Need door handle for 1959 Cessna 175 | Paul Millner | Owning | 0 | July 4th 03 07:36 PM |
