You need to find a "friendly" prop shop that will split the hub, do a
very general inspection-looking for corrosion or other very bad things-replace all the seals and put it back together with a re-seal sign-off. What, in your recommendation, is a "friendly" prop shop. Heck, I can't even name a prop shop -- period -- let alone a "friendly" one! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Thanks TC.
Another item Maxwell mentioned is that they often see the teflon quad seals failing strictly due to an age. Their theory is that they are simply getting old and brittle after 7 or 8 years. Now they've been replaceing them with "O" rings that retain their softness longer. Jim |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Cherokee Strut Lower Strut Seal Replacement Report | Mike Spera | Owning | 3 | July 23rd 05 07:07 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
