VOR Check question
Old July 24th 05, 05:43 AM
Brien K. Meehan
Ah, cool, thank you very, VERY much for posting those references.
The FAA's policy subject to ICAO membership doesn't make it regulatory,
as the ICAO is a standards organization and holds no sovereignty. If a
DOT organinzation outside the FAA, or a department outside the DOT,
adopted those ICAO standards as regulatory, then the FAA would assume
an indirect regulatory role - even so, the equipment requirement would
be arguable (the equipment assumption is for the purpose of determining
minima, not actual navigation, and regulatory equipment requirements
are otherwise very precise). But, as far as I know, this is not the
case.
The second part describes Class I and Class II navigation, but doesn't
spell out an equipment requirement either. On the contrary, it says
that you don't automatically need equipment appropriate for the
corresponding class of navigation.
Old July 24th 05, 09:57 AM
case.
Indeed, ICAO is not regulatory. What the FAA accepts as navigation policy,
though, is subject to FAA regulation, ala 91.205(d)(2); i.e.
"appropriate." "Appropriate" serves to the benefit of the FAA, not the
pilot.
Old July 26th 05, 01:36 AM
Mike Rapoport
wrote in message ...
Ron Natalie wrote:
Mark Hansen wrote:
You are also required to have available in the aircraft equipment
necessary
for navigation along your route, in the event GPS goes out. That sounds
like
VOR to me.
Not if you have the right GPS. But an unchecked VOR is technically not
airworthy, so unless you're going to follow the procedures for inop
equipment, it would be easier just to do it.
Not so. VOR is still the primary means of navigation in the NAS. Even
latest and greatest airline aircraft with dual GPS sensors, dual FMSes,
triple
IRUs, etc, cannot be dispatched without operate VOR receivers (in their
case
two).
The presumption is that the GPS system can fail at any time; at least in a
given
area. WAAS doesn't mitigate that whatsoever.
I thought that WAAS was approved for sole means of navigation?
Mike
MU-2
Old July 26th 05, 04:36 AM
Stan Gosnell
"Mike Rapoport" wrote in
nk.net:
Not that I'm aware of. WAAS has nothing to do with reliability, other
than vertical accuracy. Its only function is to give enough vertical
accuracy to allow a semi-precision approach.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old July 26th 05, 03:42 PM
Mike Rapoport
My understanding is that WAAS has an integrety function and is able to
detect an inaccurate signal.
Mike
MU-2
"Stan Gosnell" wrote in message
nk.net:
Regards,
Stan
Old July 26th 05, 04:09 PM
Steven P. McNicoll
triple
case
two).
given
So why is it presumed that the VOR system cannot fail?
Old July 26th 05, 04:58 PM
Steven P. McNicoll
Well, okay, but I work with this stuff all the time.
That doesn't mean you understand it.
Here is from the current FAA Order 8260.19C:
l. Dual Minimums. Enter dual minimums, when authorized. Do not publish
dual minimums unless a 60-foot operational advantage is obtained or a
reduction in visibility can be achieved. To avoid proliferation of dual
minimums, *all IFR aircraft are assumed to have at least one VOR
receiver*. Dual minimums based on a stepdown fix combined with local and
remote altimeter settings could result in four sets of minimums. When two
remote sources are used, treat the source resulting in lower minimums as
the "LOCAL" altimeter setting source in the following paragraphs.
Document only two sets of minimums. The combinations authorized are
minimums with and without a stepdown fix; or minimums with local and
remote altimeter settings.
The words between the asteriks are reflective of FAA Class I navigation
policy, which is a requirement to be a part of ICAO.
FAA Order 8260.19C places no regulatory requirements upon pilots or the
operation of aircraft.
How are you doing with that reference for the timing tables on NACO charts
being IAS?
Old July 27th 05, 05:11 AM
Jose
I would assume (and I know the etymology) that VORs fail 1000 square
miles at a time, and GPS fails 3,000,000 square miles at a time. Or,
more to the point, there is more systemic redundancy in the VOR system.
Jose
Nothing takes longer than a shortcut.
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
