Missing oil?
Old July 25th 05, 03:29 AM
Don Hammer
All this makes us think that the plane really is burning the oil but
wouldn't the compression check yeild much lower results if it were burning
that amount oil? Where's the likely suspect here?
Could be worn valve guides. They won't show up on a compression
check, but oil can be sucked in around the intake guide when the valve
is open.
Don
Old July 25th 05, 03:31 AM
Jon Kraus
You are corect... For that matter worn valve seals too...
Jon Kraus
'79 Mooney 201
is open.
Don
Old July 25th 05, 03:56 AM
pbc76049
Check and see that the slit in the oil drain tube
is not plogged up inside the cowled area. If the slit is
plugged with old oil gunk, the tube will suck oil overboard
and since they stick out a bit into the airstream, you probably
won't see a bunch on the belly. ANOTHER PLACE is a clogged
air/oil seperator on the vacuum pump if a wet pump is installed.
They can pump much oil overboard and still function.
Old July 25th 05, 04:09 AM
Scott Skylane
Jon Kraus wrote:
You are correct... For that matter worn valve seals too...
'scuse me??? Which version of the "old 300" are we talking about, here?
Happy Flying!
Scott Skylane
N92054
Missing in Action Serviceman Identified Otis Willie Naval Aviation 0 March 18th 05 11:58 PM
Presidewnt reagan's Missing Man Formation tony Piloting 45 June 16th 04 11:00 AM
missing man formation for Reagan Paul Hirose Military Aviation 1 June 14th 04 12:50 AM
Search for missing plane C J Campbell Piloting 2 March 4th 04 01:42 AM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 03:01 AM
