#111
On Tue, 26 Jul 2005 11:18:36 -0400, Corky Scott
wrote: I wrote: Sorry Icebound, I can't tell if you are being sarcastic or if you really believe this. I thought it was common knowledge now that the Bush administration actually did invent the WMD specifically to start the war. On Mon, 25 Jul 2005 17:55:23 -0400, Bob Noel wrote: at one time it was common knowledge that the earth was flat. Exactly, until it was overwhelmingly proved otherwise. Thanks, great parallel. Unfortunately, some still believe the world is flat... Another great parallel. Yup! The only way you can have true parallels N/S AND E/W is on a flat surface. We've been given two paralles so it must be flat. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Corky Scott |
#112
W P Dixon wrote:
Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() You are obviously using much larger targets than the rest of us. Matt |
#113
![]() W P Dixon wrote: Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() Ever been in a firefight where the 'target' is shooting back at you? Makes a difference :-) |
#114
As an old Marine you could say I have been in a 'few" firefights..and my
target was the basic human "shadow" and all hits are in the center chest . Also Marine rifle coach with 4 awards expert rifleman. And I still do not see how a 'trained' professional marksman can miss so much. An M-16/AR-15 is a very accurate weapon in the right hands. Patrick "John E. Carty" wrote in message ... W P Dixon wrote: Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() Ever been in a firefight where the 'target' is shooting back at you? Makes a difference :-) |
#115
Matt Whiting wrote:
You are obviously using much larger targets than the rest of us. there is also a bit of a difference between shooting in a safe environment at cardboard targets that don't move and don't shoot back (I am not half bad at that either) and doing same in a combat zone environment (about which I don't have the beginning of a clue, but I'd guess it probably affects one's marksmanship a bit) --Sylvain |
#116
You are correct , it will have an effect but some of these stories of 50-75
shots being fired within 15 feet and no one gets a scratch? Hardly a professional marksman. A SWAT sniper should NEVER miss as for the fact is he is a sniper and should be in hiding and not seen thus not in the situation of having return fire . Patrick "Sylvain" wrote in message ... Matt Whiting wrote: You are obviously using much larger targets than the rest of us. there is also a bit of a difference between shooting in a safe environment at cardboard targets that don't move and don't shoot back (I am not half bad at that either) and doing same in a combat zone environment (about which I don't have the beginning of a clue, but I'd guess it probably affects one's marksmanship a bit) --Sylvain |
#117
I'm also a former combat Marine and could always hit 10 for 10 from the 500
yard line (it was never measured in meters for us) with an M-16 with open sights. However, firing a rifle from the prone position and firing a handgun while on the move are two entirely different things :-) "W P Dixon" wrote in message ... As an old Marine you could say I have been in a 'few" firefights..and my target was the basic human "shadow" and all hits are in the center chest . Also Marine rifle coach with 4 awards expert rifleman. And I still do not see how a 'trained' professional marksman can miss so much. An M-16/AR-15 is a very accurate weapon in the right hands. Patrick "John E. Carty" wrote in message ... W P Dixon wrote: Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() Ever been in a firefight where the 'target' is shooting back at you? Makes a difference :-) |
#118
but John,
50 or so shots and not hit anything? Now firing the old .45 out the huey door while flying, doubt I could hit anything ..but you'd have to be running away firing over your shoulder not to hit anything that close. ![]() could get a better grouping than that! heck alot of these "shoot outs" are within 15 feet. Maybe it's all the donut glaze stuck on their trigger fingers? ![]() Semper Fi, Patrick "John E. Carty" wrote in message ... I'm also a former combat Marine and could always hit 10 for 10 from the 500 yard line (it was never measured in meters for us) with an M-16 with open sights. However, firing a rifle from the prone position and firing a handgun while on the move are two entirely different things :-) "W P Dixon" wrote in message ... As an old Marine you could say I have been in a 'few" firefights..and my target was the basic human "shadow" and all hits are in the center chest . Also Marine rifle coach with 4 awards expert rifleman. And I still do not see how a 'trained' professional marksman can miss so much. An M-16/AR-15 is a very accurate weapon in the right hands. Patrick "John E. Carty" wrote in message ... W P Dixon wrote: Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() Ever been in a firefight where the 'target' is shooting back at you? Makes a difference :-) |
#119
Patrick,
Hey, that old .45 certainly had better stopping power then a 9mm, but we only had 7 rounds in which to hit the target! :-) Semper Fi, John {Formerly} Headquarters Company 2nd Force Service Support Group Fleet Marine Force Atlantic Camp Lejeune, NC "W P Dixon" wrote in message ... but John, 50 or so shots and not hit anything? Now firing the old .45 out the huey door while flying, doubt I could hit anything ..but you'd have to be running away firing over your shoulder not to hit anything that close. ![]() My grandma could get a better grouping than that! heck alot of these "shoot outs" are within 15 feet. Maybe it's all the donut glaze stuck on their trigger fingers? ![]() Semper Fi, Patrick "John E. Carty" wrote in message ... I'm also a former combat Marine and could always hit 10 for 10 from the 500 yard line (it was never measured in meters for us) with an M-16 with open sights. However, firing a rifle from the prone position and firing a handgun while on the move are two entirely different things :-) "W P Dixon" wrote in message ... As an old Marine you could say I have been in a 'few" firefights..and my target was the basic human "shadow" and all hits are in the center chest . Also Marine rifle coach with 4 awards expert rifleman. And I still do not see how a 'trained' professional marksman can miss so much. An M-16/AR-15 is a very accurate weapon in the right hands. Patrick "John E. Carty" wrote in message ... W P Dixon wrote: Wow that's sad!, I don't understand why the cops have such poor shots. At 500 meters I am bullseye 10 out 0f 10 , with a scope that range would get wayyyy on out there. Really makes the officers look like Keystone Cops when the only inflicted wound in a 50 round fired shoot out is a bruise from an ejected 9mm empty brass! ![]() Ever been in a firefight where the 'target' is shooting back at you? Makes a difference :-) |
#120
Yep,
The old .45, we seemed to always have the most rattlin' pistols available. Loose barrels and all, but was sad to see them start going bye bye in the 80's. And now I carry a 9mm, would not dream of carrying the .45 anymore. I like the .45 stopping power, but I am much more accurate with the 9mm. Can't say that is the way it is for everyone but it sure makes a difference in my grouping! But hey maybe we may be onto something there? Maybe some of those officers need to caliber down? Maybe they could also get a better grouping by using the smaller cal? I like the CZ52 myself, matter of fact I need to get me another one! Pick them up really cheap and do some custom work on it and you have a nice custom slabside for a fraction of the cost of the new tricked out .45's . And sorry guys , I guess we have gotten way off the aviation toipc here. Patrick student SPL aircraft structural mech (formerly) HML-167, HMM-261 REIN MCAS NEW RIVER USS Iwo Jima 22MAU Peacekeeper "John E. Carty" wrote in message ... Patrick, Hey, that old .45 certainly had better stopping power then a 9mm, but we only had 7 rounds in which to hit the target! :-) Semper Fi, John {Formerly} Headquarters Company 2nd Force Service Support Group Fleet Marine Force Atlantic Camp Lejeune, NC |
The Real Reason For Airlines' No Smoking Policy | Larry Dighera | Piloting | 3 | April 3rd 05 09:16 PM |
Give Me A GOOD Reason | [email protected] | Piloting | 43 | January 27th 05 03:24 PM |
Is expense of a new sailplane the reason? | Nolaminar | Soaring | 0 | January 7th 05 03:40 PM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
