Thanks Corky,
My assumptions about the rotary were not based on experience, so it's good to learn something new. I would have expected the rotary to have less spiky torque output than a piston, but perhaps the wobble of the rotor along its ellipsoidal path creates enough inertia to cause some sizable spikes. I may post a question about this to the Mazda newsletter -- once Paul gets back from Osh. I'm sure there will be some people there with good insight on this. I still have to think though that maximum torque is the limiting factor in both gear and belt design. Even if torsional vibration is an issue (with the rotary or any engine), the way to address that is to dampen the spikes and prevent harmonics from causing destructive resonance. Just using bigger stronger gears is one approach, but not really the most elegant -- or lightweight. I notice that Tracy uses rubber doughnuts between the flywheel and the gearbox coupling, just for that reason I would assume. Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. I was hoping the rotary was less of a problem in this area. Darn. Regards, Gordon. "Corky Scott" wrote in message ... On Thu, 28 Jul 2005 16:08:46 -0400, "Gordon Arnaut" wrote: Still, compared to a piston engine, the rotary is a pussy cat when it comes to torsional issues, because it does not have the lever-arm effect of the crankshaft throws to worry about -- which creates the bulk of the torsional flex in a piston engine. This may not be accurate Gordon. There was a company based up in Washington State that produced a planetary gear box as a PSRU for the Mazda rotory and they had a HORRENDOUS developmental period with many, repeat many broken boxes. They finally got something that was extremely professional looking as machined aluminum can be, and robust and long lived. They had it on the front of an RX4 and flew it to various air shows. One of the developmental partners was killed in an airplane crash and for a while the psru was still available but I don't know if it still is. The big issue, the one that was busting props and tearing their boxes apart was torsional vibration. I remember reading that they claimed there was something about the rotory engine that gave it a really powerful torque spike. I think they eventually solved the problem with some kind of cushion drive. But for a while it was busting one attempt after another on the test stand, and a bunch of dead stick landings. Corky Scott |
gearbox coupling, just for that reason I would assume. As I understand it, there are two ways to avoid the resonance issue. One is to make the drive coupling tighter, and the other is to make it looser. Powersports chose tighter I believe, and the precision they need could be why their drive costs $6000. Tracy chose the looser path. Both work fine. The biggest unknown I face with the single rotor is the resonance frequency, and how it works with the rubber dampeners that Tracy chose for the two rotor engine. I may very well have to change the durometer of the rubber dampeners, but I won't know until I try it. Cheers, Rusty |
On Thu, 28 Jul 2005 22:08:10 -0400, "Gordon Arnaut"
wrote: Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. Really? Not even Eggenfellner's? I haven't heard of any failures of his design yet, but I haven't been actively following Subaru conversions. Corky Scott |
Yes, the Egg redrive has no failures yet, from what I know.
However, he seems to have taken the "build it strong as hell" approach and doesn't use any kind of damping, such as elastomers, sprag clutch, etc. He is also using a heavy flywheel that helps to smooth out the torque spikes. The result is quite a heavy unit. Still his FWF package is competitive with Lyc on a power-to-weight basis. Not bad at all. Regards, Gordon. "Corky Scott" wrote in message ... On Thu, 28 Jul 2005 22:08:10 -0400, "Gordon Arnaut" wrote: Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. Really? Not even Eggenfellner's? I haven't heard of any failures of his design yet, but I haven't been actively following Subaru conversions. Corky Scott |
Gordon Arnaut wrote:
Yes, the Egg redrive has no failures yet, from what I know. However, he seems to have taken the "build it strong as hell" approach and doesn't use any kind of damping, such as elastomers, sprag clutch, etc. He is also using a heavy flywheel that helps to smooth out the torque spikes. The result is quite a heavy unit. Still his FWF package is competitive with Lyc on a power-to-weight basis. Not bad at all. Regards, Gordon. "Corky Scott" wrote in message ... On Thu, 28 Jul 2005 22:08:10 -0400, "Gordon Arnaut" wrote: Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. Really? Not even Eggenfellner's? I haven't heard of any failures of his design yet, but I haven't been actively following Subaru conversions. Corky Scott Sorry for coming in a little late on this; I usually frequent the Flyrotary list & Rusty mentioned that this thread was alive over here. The non-existent email address is there because I got tired of a steady diet of spam. Several things come to mind about the previous few messages in this thread, from the stuff I've read in about 10 years of following Powersport, then Tracy Crook's development trials & tribulations. This is from memory & I never claim to have a good memory. :-) Gearbox strength for 1rotor vs 2rotor: The big deal about a 1rotor is that the torque curve actually reverses (goes negative) with a 1 rotor, like a 4cyl 4stroke piston engine. With a 2 rotor, the torque curve never actually reverses so the gear box isn't stressed as much in the torsional resonance dept. even though there's twice the power. If you frequent Paul Lamar's list I'm sure he will be happy to show you the torque curve for the 2rotor. IIRC, the torque curve for a 1rotor looks like a 4cyl piston engine, going negative between each positive torque peak. If the system resonates & you continue to excite it without damping the resonance, no amount of strength will keep it from breaking. The 1st incarnation of Powersport are the guys in the northwest with the rotary powered RV-4 that had such horrendous torsional resonance problems *on a dyno*. Current thinking is that they had a problem with resonance on that particular dyno with that particular engine/dyno coupling (it was built to test V-8's) They also had severe problems getting their P-port engine to idle properly. Others have had no problem at all getting them to idle smoothly. The developers had racing V-8 backgrounds & some of that stuff doesn't transfer well to the rotary. Their internal tooth ring gear, designed to keep the gearbox 'tight', like Rusty mentioned, is very heavy, very expensive, & if it isn't heavy enough will actually loosen up as rpm comes up & the ring gear tries to stretch. Kind of self-defeating. The 'tight' vs 'loose' issue is really an issue of moving resonant frequency above the operating rpm range or moving it below the operating range. 'Tight' moves it up; 'loose' moves it down. Manual transmission cars are 'loose', moving resonance below normal operating rpm. You've probably experienced the automotive version of torsional resonance if you've put a manual trans car in 2nd or 3rd & let the idling engine try to pull the car. If the engine continues to run, the car will move forward in big surges. That's the resonant frequency of the drive train. I don't remember Powersport ever having a problem with broken props or gearboxes; my memory is that they went straight from their dyno problems to the big internal spur gear. They did have a gearbox failure when competing in time-to-climb at SNF because they were using nitrous & over stressed a bearing in the gearbox. I think they were producing somewhere between 350-400hp (13B without turbo) when that happened. Damping torque pulses with belt slippage: inefficient & produces a lot of heat. I think Corky mentioned the nightmare of an intake manifold on RX-7 13B's; fortunately a much simpler & lighter intake works fine for aircraft since low rpm torque isn't needed. Eggenfellner: I believe they've recently had the 1st failure of one of their gearboxes. Charlie (Rusty's 'hangar away from home' for the next hurricane) |
Charlie,
Thanks for the insightful post. What exactly is the source of the torsional vibration in the rotary? And how does it compare in severity to a piston engine? Regards, Gordon. "Charlie" wrote in message .. . Gordon Arnaut wrote: Yes, the Egg redrive has no failures yet, from what I know. However, he seems to have taken the "build it strong as hell" approach and doesn't use any kind of damping, such as elastomers, sprag clutch, etc. He is also using a heavy flywheel that helps to smooth out the torque spikes. The result is quite a heavy unit. Still his FWF package is competitive with Lyc on a power-to-weight basis. Not bad at all. Regards, Gordon. "Corky Scott" wrote in message ... On Thu, 28 Jul 2005 22:08:10 -0400, "Gordon Arnaut" wrote: Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. Really? Not even Eggenfellner's? I haven't heard of any failures of his design yet, but I haven't been actively following Subaru conversions. Corky Scott Sorry for coming in a little late on this; I usually frequent the Flyrotary list & Rusty mentioned that this thread was alive over here. The non-existent email address is there because I got tired of a steady diet of spam. Several things come to mind about the previous few messages in this thread, from the stuff I've read in about 10 years of following Powersport, then Tracy Crook's development trials & tribulations. This is from memory & I never claim to have a good memory. :-) Gearbox strength for 1rotor vs 2rotor: The big deal about a 1rotor is that the torque curve actually reverses (goes negative) with a 1 rotor, like a 4cyl 4stroke piston engine. With a 2 rotor, the torque curve never actually reverses so the gear box isn't stressed as much in the torsional resonance dept. even though there's twice the power. If you frequent Paul Lamar's list I'm sure he will be happy to show you the torque curve for the 2rotor. IIRC, the torque curve for a 1rotor looks like a 4cyl piston engine, going negative between each positive torque peak. If the system resonates & you continue to excite it without damping the resonance, no amount of strength will keep it from breaking. The 1st incarnation of Powersport are the guys in the northwest with the rotary powered RV-4 that had such horrendous torsional resonance problems *on a dyno*. Current thinking is that they had a problem with resonance on that particular dyno with that particular engine/dyno coupling (it was built to test V-8's) They also had severe problems getting their P-port engine to idle properly. Others have had no problem at all getting them to idle smoothly. The developers had racing V-8 backgrounds & some of that stuff doesn't transfer well to the rotary. Their internal tooth ring gear, designed to keep the gearbox 'tight', like Rusty mentioned, is very heavy, very expensive, & if it isn't heavy enough will actually loosen up as rpm comes up & the ring gear tries to stretch. Kind of self-defeating. The 'tight' vs 'loose' issue is really an issue of moving resonant frequency above the operating rpm range or moving it below the operating range. 'Tight' moves it up; 'loose' moves it down. Manual transmission cars are 'loose', moving resonance below normal operating rpm. You've probably experienced the automotive version of torsional resonance if you've put a manual trans car in 2nd or 3rd & let the idling engine try to pull the car. If the engine continues to run, the car will move forward in big surges. That's the resonant frequency of the drive train. I don't remember Powersport ever having a problem with broken props or gearboxes; my memory is that they went straight from their dyno problems to the big internal spur gear. They did have a gearbox failure when competing in time-to-climb at SNF because they were using nitrous & over stressed a bearing in the gearbox. I think they were producing somewhere between 350-400hp (13B without turbo) when that happened. Damping torque pulses with belt slippage: inefficient & produces a lot of heat. I think Corky mentioned the nightmare of an intake manifold on RX-7 13B's; fortunately a much simpler & lighter intake works fine for aircraft since low rpm torque isn't needed. Eggenfellner: I believe they've recently had the 1st failure of one of their gearboxes. Charlie (Rusty's 'hangar away from home' for the next hurricane) |
Charlie, Thanks for the insightful post. What exactly is the source of the torsional vibration in the rotary? And how does it compare in severity to a piston engine? Regards, Gordon. The source is the same as in a piston engine. The fuel/air mixture is has to be compressed right before it is ignited. The ignited mixture then only provides power for about 60 degrees of rotation. The negative peek is very small in the two rotor for two reasons. First, the 8 to 10 pound rotor plus very large cranshaft provides a significant flywheel effect. And second, the negative pulse is slightly overlapped by the postive pulse of the other rotor; eg. the pressure graph is actually the result of the overlay of the graph from two independant rotors. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Charlie,
I did get some info from Paul Lamar on the rotary list, including some graphs of torque peaks for the 2-rotor. However, I just looked at some torque graphs of piston engines and even a six-cylinder will go below the zero axis into negative territory -- although the amplitude below zero is less than for a 4-cylinder piston. Only when you get to an 8-cylinder piston does the wave stop going into negative territory. I'm not really clear from Paul's graph whether the 2-rotor goes negative or not. I would think it does, since Paul describes it as similar to a 6-cylinder piston, in terms of torsional excitation. It is clear of course that the torque pulses from the single-rotor will be even more uneven and will go deeper into negative territory. Still, as you pointed out, the cure to torsional excitation is to dampen it, not to build a stronger transmission. It should also be noted that one way to avoid torsional vibration is not to run the engine continuously at the rpm where excitation occurs (as with the non-counterweighted Lycoming). With a single-rotor engine, I would think that if you dampen the harmonics at the offending rpm, you should not need a heavy gearbox designed for the power of the bigger engine. Also as far as poly-v belts are concerned, the perception is that they are not as efficient as cog belts, but this just isn't so. A properly tensioned poly-v belt is as efficient as a cog belt, between 95 and 98 percent. (Goodyear and other belt makers have info on this on their websites). This is as efficient as most gearboxes -- or even slightly better. Also the system should be properly tensioned so there is no slippage at full power. The only time slippage will occur is when torsional excitation causes a big torque pulse. Of course, there is no reason to run the engine at that rpm anyway (whatever it may be on a rotary, but probably below 2000 rpm). As far as heat is concerned, both cog belts and poly-v belts generate similar amounts of heat -- the two or three percent of power that is lost goes to heat. So does a gearbox. The belt manufacturers have made great strides in poly-v technology in recent years. This is definitely not just a bunch of v-belts strung together. Regards, Gordon. "Charlie" wrote in message .. . Gordon Arnaut wrote: Yes, the Egg redrive has no failures yet, from what I know. However, he seems to have taken the "build it strong as hell" approach and doesn't use any kind of damping, such as elastomers, sprag clutch, etc. He is also using a heavy flywheel that helps to smooth out the torque spikes. The result is quite a heavy unit. Still his FWF package is competitive with Lyc on a power-to-weight basis. Not bad at all. Regards, Gordon. "Corky Scott" wrote in message ... On Thu, 28 Jul 2005 22:08:10 -0400, "Gordon Arnaut" wrote: Your story is just another reminder that gearboxes are one of the big bugaboos of any auto engine conversion -- and torsional vibration (or resonance) is always the culprit. I know that in the Subaru community there is not really a box that I would consider completely trustworthy. Really? Not even Eggenfellner's? I haven't heard of any failures of his design yet, but I haven't been actively following Subaru conversions. Corky Scott Sorry for coming in a little late on this; I usually frequent the Flyrotary list & Rusty mentioned that this thread was alive over here. The non-existent email address is there because I got tired of a steady diet of spam. Several things come to mind about the previous few messages in this thread, from the stuff I've read in about 10 years of following Powersport, then Tracy Crook's development trials & tribulations. This is from memory & I never claim to have a good memory. :-) Gearbox strength for 1rotor vs 2rotor: The big deal about a 1rotor is that the torque curve actually reverses (goes negative) with a 1 rotor, like a 4cyl 4stroke piston engine. With a 2 rotor, the torque curve never actually reverses so the gear box isn't stressed as much in the torsional resonance dept. even though there's twice the power. If you frequent Paul Lamar's list I'm sure he will be happy to show you the torque curve for the 2rotor. IIRC, the torque curve for a 1rotor looks like a 4cyl piston engine, going negative between each positive torque peak. If the system resonates & you continue to excite it without damping the resonance, no amount of strength will keep it from breaking. The 1st incarnation of Powersport are the guys in the northwest with the rotary powered RV-4 that had such horrendous torsional resonance problems *on a dyno*. Current thinking is that they had a problem with resonance on that particular dyno with that particular engine/dyno coupling (it was built to test V-8's) They also had severe problems getting their P-port engine to idle properly. Others have had no problem at all getting them to idle smoothly. The developers had racing V-8 backgrounds & some of that stuff doesn't transfer well to the rotary. Their internal tooth ring gear, designed to keep the gearbox 'tight', like Rusty mentioned, is very heavy, very expensive, & if it isn't heavy enough will actually loosen up as rpm comes up & the ring gear tries to stretch. Kind of self-defeating. The 'tight' vs 'loose' issue is really an issue of moving resonant frequency above the operating rpm range or moving it below the operating range. 'Tight' moves it up; 'loose' moves it down. Manual transmission cars are 'loose', moving resonance below normal operating rpm. You've probably experienced the automotive version of torsional resonance if you've put a manual trans car in 2nd or 3rd & let the idling engine try to pull the car. If the engine continues to run, the car will move forward in big surges. That's the resonant frequency of the drive train. I don't remember Powersport ever having a problem with broken props or gearboxes; my memory is that they went straight from their dyno problems to the big internal spur gear. They did have a gearbox failure when competing in time-to-climb at SNF because they were using nitrous & over stressed a bearing in the gearbox. I think they were producing somewhere between 350-400hp (13B without turbo) when that happened. Damping torque pulses with belt slippage: inefficient & produces a lot of heat. I think Corky mentioned the nightmare of an intake manifold on RX-7 13B's; fortunately a much simpler & lighter intake works fine for aircraft since low rpm torque isn't needed. Eggenfellner: I believe they've recently had the 1st failure of one of their gearboxes. Charlie (Rusty's 'hangar away from home' for the next hurricane) |
Still, as you pointed out, the cure to torsional excitation is to dampen it, not to build a stronger transmission. It should also be noted that one way to avoid torsional vibration is not to run the engine continuously at the rpm where excitation occurs (as with the non-counterweighted Lycoming). No. The only cure for torsional excitation is the move the system's harmonic into a range that will only be seen in low power operations and then won't be used for very long. Tracy's PSRU moved the excitation range down to between 500 and 800 rpm (working off the top of my head here, so the numbers may be off). A well tuned rotary will idle in the 900-1000rpm range (prop at about 1/3rd of that). Dampening doesn't exist. Elasticity in the system may shorten the peaks, but you'll be left with a fatter mountain. The energy has to go somewhere. The problem is that you'll still be hitting the shaft at it's resonant frequency, causing a vibration in it. Each hit adds a little to the vibration. If you repeatedly hit anything at it's resonant frequency, each hit will add to the system vibration until it either wears out very quickly or comes apart catastrophically. That applies to reduction units, crankshaft, and control surface skins (yes, flutter is a form of resonant vibration). Adding some elasticity to the shaft may make the gearbox last longer, but you won't be able to do much in those few seconds 8*) Here's someone who says it much better than I: http://rotaryaviation.com/PSRU%20Zen%20Part%202.html -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest,
You are right that springs and elastomers do not technically dampen kinetic energy, they simply store and relase it at a later time (how much later depends on the frequency at which it is tuned). However, both springs and elastomers can achieve our objective of clipping of destructive harmonics if they are tuned to the resonant frequency of the object that we want to protect from resonance. Also, fluid dampers do exist for both engines and propellers which actually do dampen kinetic forces by turning them into heat, just like the shock absorber on your car. Drive belts do this as well, including the synchronous (cog) belts which don't actually slip but which do absorb some energy as heat. In fact, even a propeller can be tuned efectively to do this, because it is kind of like a spring -- it flexes at its tips with the power pulses and then whipsaws back during the lulls. A propeller thus tuned can do the same thing as a harmonic balancer on an engine. Of course the trick is in the tuning. More often we are concerned about the opposite, where they propeller may in fact add to the excitations of the crankshaft at its resonant frequency. We see this in non-counterweighted Lycoming four-cylinder engines, which have operating restrictions in certain rpm ranges. So when we talk about torsional resonance issues, there are two aspects: one is the engine itself, and specifically the crankshaft, which shoulders the torsional forces. The other aspect is what the engine is connected to, whether a propeller, a gearbox, or both. We know of course that each object has a natural frequency at which it resonates -- the point at which external excitations cause harmonics to build. The object's mass, stiffness and damping determine how it will respond to an excitation force. Obviously having smoother excitations -- such as cylinders or rotors firing at more frequent intervals -- will result in less extreme instantaneous torque excursions, and the engine will run smoother. Dow that mean it will be free of torsional vibration? No. Even an electric motor has torsional vibration because the magnets arranged around its circumference which propel the rotor are like firing pulses -- a motor with 12 magnets will be smoother than a motor with two magnets. However the engine can be as smooth as butter, but if the shaft on which it is riding is very thin, it will still flex -- and at some point will reach its resonant frequency, and if left there for the harmonics to build up -- will break. So that's where mass and stiffness comes into play. Look at tuning forks, the smaller ones will vibrate at a higher frequency. Even a small excitation will cause a lot of flex in the thin tuning fork. It's the same with crankshafts or other shafts -- such as those in a gearbox, or a propeller -- which are exposed to torsional forces. For example, most V-8 engines come with a harmonic balancer, even though they have four power pulses for each crankshaft rotation. That's because there is enough flex in the crankshaft that the crank can begin to resonate at some rpm within the operational range. But look at the four-cylinder Subaru opposed engine. It has never needed a harmonic balancer. Why? It's crankshaft is quite massive and very stiff, so its resonant frequency is below the engine's operating range. (It is stiff because it has five main bearings, so each crank throw is supported by two main bearings, one on each side; plus the crank journals are quite massive). Although I'm not yet fully up to speed on the rotary, it is quite clear that it is similar to the Subaru in that it does not need a torsional dampening device. That e-shaft is quite rigid and it's throw is short enough that it will not flex the way a crankshaft will flex. So more stiffness equals a lower resonating frequency. So why be concerned with torsional vibration? It's because we are putting a gearbox and propeller on this engine. Just because the rotary does not resonate itself does not mean it won't set a gear shaft into resonance. That's the point of the damping at the engine-gearbox coupling. When I asked what the source was of torsional issues with the rotary, I did not have a full grasp of the dynamics with the rotary engine -- until I watched some helpful animations. However, as you can see, torsional vibration is not strictly a function of power pulses. It is a function of the many things inside the engine -- including moments of inertia, stiffness of torque shafts, etc -- plus just as many variable in whatever it is the engine may be connected to. Regards, Gordon. "Ernest Christley" wrote in message . com... Gordon Arnaut wrote: Still, as you pointed out, the cure to torsional excitation is to dampen it, not to build a stronger transmission. It should also be noted that one way to avoid torsional vibration is not to run the engine continuously at the rpm where excitation occurs (as with the non-counterweighted Lycoming). No. The only cure for torsional excitation is the move the system's harmonic into a range that will only be seen in low power operations and then won't be used for very long. Tracy's PSRU moved the excitation range down to between 500 and 800 rpm (working off the top of my head here, so the numbers may be off). A well tuned rotary will idle in the 900-1000rpm range (prop at about 1/3rd of that). Dampening doesn't exist. Elasticity in the system may shorten the peaks, but you'll be left with a fatter mountain. The energy has to go somewhere. The problem is that you'll still be hitting the shaft at it's resonant frequency, causing a vibration in it. Each hit adds a little to the vibration. If you repeatedly hit anything at it's resonant frequency, each hit will add to the system vibration until it either wears out very quickly or comes apart catastrophically. That applies to reduction units, crankshaft, and control surface skins (yes, flutter is a form of resonant vibration). Adding some elasticity to the shaft may make the gearbox last longer, but you won't be able to do much in those few seconds 8*) Here's someone who says it much better than I: http://rotaryaviation.com/PSRU%20Zen%20Part%202.html -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Diesel aircraft engines and are the light jets pushing out the twins? | Dude | Owning | 5 | October 7th 04 03:14 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
Light Twins - Again - Why is the insurance so high? | Doodybutch | Owning | 7 | February 11th 04 08:13 PM |
Light Twins. How soft??? | Montblack | Owning | 19 | December 3rd 03 10:38 PM |
Light Twins. How soft??? | Montblack | Piloting | 19 | December 3rd 03 10:38 PM |
