On Thu, 28 Jul 2005 13:21:08 -0700, Mark Hansen
wrote: Actually, that's not quite true. You are required to have an IFR flight plan and ATC clearance before you can fly in IMC within controlled airspace (or within Class A regardless of the weather). If you're outside controlled airspace, this rule doesn't apply. But ... that's a whole 'nuther can-o-worms ;-) So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? |
plan & an ATC clearance? In class G airspace. |
max wrote:
So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. Which there is precious little of that meets the IFR rules for minimum altitudes. |
max wrote:
So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. The FAA has ruled that this is in violation of 91.13. Hilton |
Please be specific. There is lots of G airspace out west that goes over
14K. Granted the weather is not usually IMC in many of those areas, but as another poster stated, you can file IFR and be IMC without any ATC control. "Hilton" wrote in message ink.net... max wrote: So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. The FAA has ruled that this is in violation of 91.13. Hilton |
Paul Lynch wrote:
Please be specific. There is lots of G airspace out west that goes over 14K. Granted the weather is not usually IMC in many of those areas, but as another poster stated, you can file IFR and be IMC without any ATC control. http://www.ntsb.gov/O_n_O/docs/AVIATION/3935.PDF Hilton Hilton wrote: max wrote: So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. The FAA has ruled that this is in violation of 91.13. Hilton |
Hilton wrote:
: Paul Lynch wrote: : Please be specific. There is lots of G airspace out west that goes over : 14K. Granted the weather is not usually IMC in many of those areas, but : as : another poster stated, you can file IFR and be IMC without any ATC : control. : http://www.ntsb.gov/O_n_O/docs/AVIATION/3935.PDF : Hilton I read this, and find it a load of crap. Not that I think it's a good idea to do what he did (depart into IMC without a clearance under VFR since it was uncontrolled airspace), his argument is basically sound. Basically, the FAA agreed that he was legal to do this. They then used the catchall "careless and reckless" to bust him anyway. He made a valid point saying that if it's illegal to do it, then the rule should be changed to make it clear. Here's the response: "With regard to the respondent's assertion that, "[i]f anytime an aircraft enters clouds in uncontrolled airspace it is careless without a clearance then the FAR's should be change," we note that it would be neither wise nor possible for the FAA to attempt to specifically prohibit every form of conduct that it considers careless." So basically, you have to follow all the rules, but they won't tell you what they all are. Bottom line is, if you don't have a problem, there won't be a regulatory problem. But if you have a problem, they'll find a regulator problem. -Cory : Hilton wrote: : max wrote: : So, where/when can you fly in the clouds (IMC) without an IFR flight : plan & an ATC clearance? : : In class G airspace. : : The FAA has ruled that this is in violation of 91.13. : : Hilton -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Cory,
Hilton wrote: : Paul Lynch wrote: : Please be specific. There is lots of G airspace out west that goes over : 14K. Granted the weather is not usually IMC in many of those areas, but : as : another poster stated, you can file IFR and be IMC without any ATC : control. : http://www.ntsb.gov/O_n_O/docs/AVIATION/3935.PDF : Hilton I read this, and find it a load of crap. Not that I think it's a good idea to do what he did (depart into IMC without a clearance under VFR since it was uncontrolled airspace), ... Why is it not a good idea to do what he did? [Warning: Loaded question] Basically, the FAA agreed that he was legal to do this. They then used the catchall "careless and reckless" to bust him anyway. He made a valid point saying that if it's illegal to do it, then the[i] rule should be changed to make it clear. Here's the response: "With regard to the respondent's assertion that, "f anytime an aircraft enters clouds in uncontrolled airspace it is careless without a clearance then the FAR's should be change," we note that it would be neither wise nor possible for the FAA to attempt to specifically prohibit every form of conduct that it considers careless." So basically, you have to follow all the rules, but they won't tell you what they all are. Bottom line is, if you don't have a problem, there won't be a regulatory problem. But if you have a problem, they'll find a regulator problem. There are numerous FARs that are delibrately vague. If you disagree with this, why not start writing up a list of 'reckless' things a pilot could do - I bet you'll shoot right past 100 and keep going. It's impossible to specifically state all the things a pilot may not do. Hilton |
That certainly answers the "specific" part. I agree with another poster the
ruling logic is not sound, although I can understand why the busted him for careless and reckless. He could have easily filed a clearance. Live and painfully learn... "Hilton" wrote in message k.net... Paul Lynch wrote: Please be specific. There is lots of G airspace out west that goes over 14K. Granted the weather is not usually IMC in many of those areas, but as another poster stated, you can file IFR and be IMC without any ATC control. http://www.ntsb.gov/O_n_O/docs/AVIATION/3935.PDF Hilton Hilton wrote: max wrote: So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. The FAA has ruled that this is in violation of 91.13. Hilton |
"max" wrote in news:1122595392.037641.117640
@g49g2000cwa.googlegroups.com: So, where/when can you fly in the clouds (IMC) without an IFR flight plan & an ATC clearance? In class G airspace. I think there is also an exception for within 1/2 mile of the runway, but it may be a "Clear of Clouds" exception, not an "In the Clouds" exception. I'm too tired and lazy to look it up right now, especially because it's more pilot trivia than practical piloting... ![]() |
Frst Solo, Non-stop Round the World Airplane Flight | Larry Dighera | Piloting | 7 | March 4th 05 03:51 PM |
1.4 solo.. | Beav | Rotorcraft | 0 | November 5th 04 12:27 AM |
First Solo In Actual Conditions | David B. Cole | Piloting | 22 | September 3rd 04 11:40 PM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
