I struggled with a problem like this on a Glassair III some friends
built. Had a transistor in an Darlington emitter follower configuration. The dimmer pot drove the base. The lights were from the emitter to ground. Trouble was, the thing was oscillating when at mid brightness positions. Too much capacitance on the output. A known problem with emitter followers. One forgets that they still have gain at a few tens of mhz. When it took off you could hear it in several of the radios. Darlington configurations have worse stability problems. I solved it by puttting about 100 ohms in the base right at the transistor. These circuits are designed by people not very skilled in the art. They also suffer the problem that if a bulb burns out shorted or there's an inadvertent short on the string of lights, the transistor fails. There is nothing to limit the current. That will usually take the pot too, especially if it's near the high end of its range. The 100 ohm resistor will solve that, too. If it's not a darlington, the resistor will have to be smaller. The cool way around all this is to design it with a P-FET power device configured like an op-amp. Bill Hale |
wrote in message ups.com... Trouble was, the thing was oscillating when at mid brightness positions. Too much capacitance on the output. A known problem with emitter followers. Horsefeathers. Emitter followers have less than unity voltage gain and are stable as rocks. And how does a resistive LED load become capacitive? Difficult to imagine. One forgets that they still have gain at a few tens of mhz. When it took off you could hear it in several of the radios. Darlington configurations have worse stability problems. I solved it by puttting about 100 ohms in the base right at the transistor. Tens of millihertz? Try again. And the base of the transistor at mid-gain has more than 100 ohms of resistance in the control pot. These circuits are designed by people not very skilled in the art. They also suffer the problem that if a bulb burns out shorted or there's an inadvertent short on the string of lights, the transistor fails. There is nothing to limit the current. That will usually take the pot too, especially if it's near the high end of its range. The 100 ohm resistor will solve that, too. Unmitigated horsepoop. Bulbs don't burn out shorted. Bulbs burn out open. If the transistor fails ( a million to one odds), the pot is open-circuited and will not be damaged. You have absolutely no experience in the matter, so why waste our time and bandwidth with your ignorance? If it's not a darlington, the resistor will have to be smaller. Don't apply for an engineering job at my company. The cool way around all this is to design it with a P-FET power device configured like an op-amp. Why not an N-FET, or an NPN, or a PNP, all of which will solve the problem elegantly. Jim |
RST Engineering wrote:
wrote in message ups.com... Trouble was, the thing was oscillating when at mid brightness positions. Too much capacitance on the output. A known problem with emitter followers. Horsefeathers. Emitter followers have less than unity voltage gain and are stable as rocks. And how does a resistive LED load become capacitive? Difficult to imagine. True for a real emitter follower, however if you have an N-stage darlington with N=3, it can oscillate. This was the subject of an IEEE Transactions article in the early 80's and a source of great embarrassment for an engineer I worked with that didn't read the article until after putting the design in production. snip -- Jim Pennino Remove .spam.sux to reply. |
Might want to read up.
If emitter followers are driving a load with a capacitive component, it is reflected to the input as a negative resistance. You can prove this with only the simplest hybrid pi model. It's a parasitic oscillation, not a loop oscillation which couldn't happen with gain 1 as you point out. You add enough series base resistance to swamp out the negative resistance, making it stable. There is enough capacitance in the wiring to excite the phenomena. This is why you see resistors in the base circuits of emitter followers all the time. Darlingtons are much worse. You can show that with the hybird pi model as well. The oscillation will be near fT. That's a few mhz for 3055 type devices. Bulbs usually burn out open, true. What about some other short? The circuit has NO short current protection other than the beta of the transisitor. The base current becomes 1/beta of whatever short circuit current flows. If the pot is set very near the max end of it's range, dissapation will destroy the upper part of the resulting divider stick. I have replaced enough of the panel mount edge adjust pots in Bonanzas which have this exact setup to know. Know what those cost? The P-fet works great because you can get the output clear to the rail, not the rail - 1 diode drop as you are limited to with the 3055 approach or 2 drops in the darlington approach. It's inherently current limited by IDss as well. Draw it out: The source goes to +14, the drain to the lamps to ground. The control pot goes with the hot end to +14, the wiper to the gate, and the other end to the bulbs. So it also has a small amount of loop gain-- makes the adjustment very smooth. The huge gate-drain capacitance of the v-fet structure miller multiplied by the gain of the FET ensures stability under all conditions. Maybe you should write it up for kit planes. I won't be applying to RST anytime soon, but I did think you were better than this. Bill Hale |
wrote in message oups.com... Might want to read up. Have. Lots. If emitter followers are driving a load with a capacitive component, it is reflected to the input as a negative resistance. This is why you see resistors in the base circuits of emitter followers all the time. I really don't want to get into the whys and wherefores of parasitic oscillation in this ng. Hell, the guy only wants his dimmer fixed. And yes, a 100 ohm base decoupling resistor has been standard for me for the last 40 years, mostly because I really can't control how well the collector is bypassed for DC, audio, and RF simultaneously. It is difficult (not impossible) to get parasitic oscillation where the collector is bypassed from DC to daylight (or at least out to Ft). The only place I *won't* use a base decoupling resistor is in a VHF power amplifier where the input impedance is an order of magnitude lower than the decoupling resistor. Bulbs usually burn out open, true. What about some other short? The circuit has NO short current protection other than the beta of the transisitor. The base current becomes 1/beta of whatever short circuit current flows. If the pot is set very near the max end of it's range, dissapation will destroy the upper part of the resulting divider stick. How do we know that there is no short circuit current protection? Did you take it apart or do you have a schematic of this particular dimmer? We sure could have saved a lot of wild ass guessing about the problem. He MIGHT have it overloaded, but without knowing the particulars of this installation, we are doing rectorandom guesses at the problem. I have replaced enough of the panel mount edge adjust pots in Bonanzas which have this exact setup to know. Know what those cost? No, and I have a hard time believing that Beech, the overdesigner of the industry, put something out without short circuit protection of some sort. However, if you have replaced them, then you are one up on me. No, I don't know what they cost, but a simple current shutdown (with or without foldback) is less than half a buck's worth of parts at the front end. The P-fet works great because you can get the output clear to the rail, not the rail - 1 diode drop as you are limited to with the 3055 approach Maybe you should write it up for kit planes. You probably want to look at January, April, May, June, July 2001 Kitplanes where I used N-channel, P-channel, NPN, and PNP transistors as the output devices, explaining exactly what the tradeoffs were between each of the devices. All in all, about ten designs. I won't be applying to RST anytime soon, And I thank you kindly. but I did think you were better than this. When I'm in sci.electronics.design, I'm really quite careful about the nuances of design. When I'm trying to get some poor guy's lamp dimmer to work on RAH, RAO, or RAP, I'm a little less careful about being precisely technically correct. For a dimmer that apparently worked correctly once upon a time, poor design is about the last place I try and look. I'm not above reengineering a crappy design, but if it really does have a parasitic oscillation at the top end of the range, you'd have thought that in my last 45 years in this biz I'd have come across one, no? Now, let's get back to fixing this sucker with what we DO know. Did the fact that he can't key his radio transmitter or hear his radio receiver when the unit was acting up mean anything to you? I doubt parasitic oscillation keeps the transmitter key line from kicking the transmitter on. Use ALL the clues, not just the one you are most comfortable with. Jim |
"RST Engineering" writes:
Unmitigated horsepoop. Bulbs don't burn out shorted. Bulbs burn out open. I wish.... I had some hard experience with shorted ?317's I think they were -- the 14v version of 327's. And lots of owners of early-generation X10 modules discovered they would fail into full-on when their 120vac lamp failed into full-off. The clear solution for the OP was what the NASA LeRC 10x10 Supersonic Wind Tunnel used for ""dimmers"" for the seven 40KHP drive motors -- large glass tanks of salt water. The electrodes were cranked in deeper to speed things up.... Oh, if you go that route, be sure and stick to positive G maneuvers or you'll have a mess.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Describe the failure mode that lets a bulb short out.
Jim "David Lesher" wrote in message ... "RST Engineering" writes: Unmitigated horsepoop. Bulbs don't burn out shorted. Bulbs burn out open. I wish.... I had some hard experience with shorted ?317's I think they were -- the 14v version of 327's. And lots of owners of early-generation X10 modules discovered they would fail into full-on when their 120vac lamp failed into full-off. |
Describe the failure mode that lets a bulb short out. I'm not an expert on same; just a victim. But from conversations with someone at GE Nela Park decades ago; the filament breaks, and can fall down from both gravity and err "sprong"ing when it lets go... If the shortened filament end touches the OTHER post, it will draw lots more current since it is shorter. It very soon burns out, but in the meantime.... Or a length comes loose at both ends; it falls across the posts at the bottom and..... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
We must not have been talking to the same people at GE, because one of the
things I did in my former life was do reliability studies on some of the stuff we threw up into orbit -- like annunciator light bulbs (WAY, WAY before LEDs could remotely be considered reliable enough for space flight). If you look closely at an incandescent light bulb (especially the aviation versions like the 327-28 volt and 330-14 volt) you will see that the internals of the bulb start with a little dot of ceramic called the "bead". The wires that come out of this bead are called "spreaders" or "stringers"; there is an optional electrically inert third wire called a "support" that we can talk about later. The spreaders are angled out at a fairly precise angle to keep a broken filament from coming into contact with the other spreader and causing exactly the failure mode you describe. It is geometrically impossible for a dangling filament to come in contact with the other spreader. THe support does exactly the same thing for a long-filament bulb -- holds up the filament while it is still a lamp and keeps the broken filament from touching the other spreader when the lamp burns out. The only possible failure mode would be for the filament to break at both ends simultaneously and drop down onto the bead in such a manner that the slightest vibration would not cause the filament to drop harmlessly into the bottom of the lamp base. While there is a mathematical probability that this could happen, there is also a mathematical probability that the lamp could disassemble itself and reassemble itself in a far corner of the universe. I'm not sure which one is more probable. Anyway, it seems the OP has found the "ground wire that ain't a ground wire" and solved the problem, which is a good thing. Jim "David Lesher" wrote in message ... "RST Engineering" writes: Describe the failure mode that lets a bulb short out. I'm not an expert on same; just a victim. But from conversations with someone at GE Nela Park decades ago; the filament breaks, and can fall down from both gravity and err "sprong"ing when it lets go... If the shortened filament end touches the OTHER post, it will draw lots more current since it is shorter. It very soon burns out, but in the meantime.... Or a length comes loose at both ends; it falls across the posts at the bottom and..... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
If you look closely at an incandescent light bulb (especially the aviation versions like the 327-28 volt and 330-14 volt) you will see that the internals of the bulb start with a little dot of ceramic called the "bead". Well, I was not aware we were talking exclusively about aviation/space rated lamps, but as it turns out while working for LeRC; I almost emptied Building 142 with those unshortable lamps. I was driving them with NE555's which turned out to be effective, if somewhat smoky, fuses. The technician and I just looked at each other while the cloud rose toward the smoke detector....the one going to the sprinkler system and Evac alarms. The NE555 fuse has an audible annunciator as well; at least when the charred pieces fall down into the vent fans that spit them out with a clatter... In one of those "I'm not making this up.." aspects, my then-boss is now a participant in this newsgroup, and I'm sure he remembers the design/assembly in question. {But I ..cough... don't think I ever bothered him with this particular FUBAR at the time...} As for the X10/120v lamp aspects, also circa 1980, I'd looked into it when my BiL wanted to know why his kept failing. I suspect triac/et.al designs have progressed since then and maybe it's no long an issue. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
| Thread Tools | |
| Display Modes | |
| Audio Panel Suggestions | Jay Honeck | Owning | 5 | May 9th 05 03:00 PM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 09:11 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 10:10 PM |
