What are the relative advantages and disadvantages of "normal" modern
fabric coverings (doped and painted polyfiber) vs. the stitched, zippered sailcloth coverings (dacron, others?) on many ultralights and new LSA airplanes? How are the sailcloth coverings attached? The Aventura 2-place homebuilt I saw at Oshkosh had dacron wing covering that looked for all the world like it was held on largely by tension. |
All dope and fabric systems use aluminum powder mixed with the finish to
block UV, which causes all fabric and dope to deteriorate. Dacron "sails" as used on ultralights don't have UV protection, so they must be changed every few years. The advantage of undoped dacron sails is simplicity and weight savings. Their are two main differences in dope and fabric systems: Flammability of the finished covering system and toxicity and flammability of the components. Polyfiber is fireproof. I've tried it, dacron fabric finished with Polytone won't burn unless you hold a flame to it. Polyfiber dopes and solvents are highly toxic and flammable however and must be shipped as hazardous material at extra expense. Other covering systems are non-toxic and non-hazardous, I don't know how flammable the finished job is for them. The traditional butyrate and nitrate dope systems are highly flammable, and nitrate dope as used in the early Ceconite system is explosively flammable when cured. Most of this information I got from the Ray Stitts polyfiber video and manual, A&P school, and what I've tried out in the shop. Adam Aulick wrote: What are the relative advantages and disadvantages of "normal" modern fabric coverings (doped and painted polyfiber) vs. the stitched, zippered sailcloth coverings (dacron, others?) on many ultralights and new LSA airplanes? How are the sailcloth coverings attached? The Aventura 2-place homebuilt I saw at Oshkosh had dacron wing covering that looked for all the world like it was held on largely by tension. -- John Kimmel "To announce that there must be no criticism of the President, or that we are to stand by the President, right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public." Theodore Roosevelt |
guynoir wrote:
All dope and fabric systems use aluminum powder mixed with the finish to block UV, which causes all fabric and dope to deteriorate. Dacron "sails" as used on ultralights don't have UV protection, so they must be changed every few years. The advantage of undoped dacron sails is simplicity and weight savings. ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Dacron will last for twenty years or so if the plane is hangared when not flying. Outside, two years would be expected for sure. There are also protectants that slow the effects of the sun on the fibers. -- Mark Smith Tri-State Kite Sales 1121 N Locust St Mt Vernon, IN 47620 1-812-838-6351 http://www.trikite.com |
![]() Mark Smith wrote: guynoir wrote: All dope and fabric systems use aluminum powder mixed with the finish to block UV, which causes all fabric and dope to deteriorate. Dacron "sails" as used on ultralights don't have UV protection, so they must be changed every few years. The advantage of undoped dacron sails is simplicity and weight savings. ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Dacron will last for twenty years or so if the plane is hangared when not flying. Outside, two years would be expected for sure. There are also protectants that slow the effects of the sun on the fibers. Interesting because balloon envelopes are typically guaranteed for only 500 hrs. Sun and heat cause them to become porous and a yearly annual inspection will eventually declare your envelope unfit. It's been a few years but there was not way to renew an envelope although several things were tried. BTW: that's one of the things that make ballooning soooooo expensive. Figure $30K for 500 hrs -- that's $60/hr right there! |
Stubby wrote:
Interesting because balloon envelopes are typically guaranteed for only 500 hrs. Sun and heat cause them to become porous and a yearly annual inspection will eventually declare your envelope unfit. Perhaps the heat reduces the life of the fabric? George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
![]() George Patterson wrote: Stubby wrote: Interesting because balloon envelopes are typically guaranteed for only 500 hrs. Sun and heat cause them to become porous and a yearly annual inspection will eventually declare your envelope unfit. Perhaps the heat reduces the life of the fabric? George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. Dacron and Stitts polyfiber are both polyester. Although plastic formulations can differ in the filler and plasticizer, the main differance would have to be the weave, fiber size, and fiber density. I suspect ballons have a short life span because they must hold hot air, and the fabric is unpainted. |
Uh, Please, Sirs | jls | Home Built | 12 | October 11th 04 02:41 AM |
Dacron | Jimmy Galvin | Home Built | 1 | January 4th 04 11:56 PM |
Fabric -- Polyfiber vs Air-Tech Coatings | Tom | Owning | 0 | September 2nd 03 02:41 AM |
