single pilot ifr trip tonight
Old November 4th 03, 02:32 PM
David Megginson
(Nathan Young) writes:
1. Vacuum failure -- no immediate, direct benefit from the handheld
GPS.
I disagree for several reasons. Many GPS models have the ability to
partition the main display and show an 'HSI' and groundspeed in
addition to the moving map.
That could be a nice indirect benefit, but the danger is ending up
with yet another distraction. The GPS pseudo-HSI display is much
easier to interpret but lags dangerously, while the TC and ASI are
harder to interpret but have minimal lag. I'd be nervous that in an
emergency my eyes would be drawn too much to the false security of the
GPS pseudo-HSI display instead of where they should be, on the TC and
ASI.
This information is very valuable as a cross-check to the flight
instruments.
Agreed, but I don't think I'm a good enough pilot to use it safely in
a partial-panel situation, where I'm already under a great deal of
stress. I'd probably keep the GPS just on a basic navigation display,
and even then, only if I wasn't able to talk to ATC. My preference
(of course) would be vectors with nice shallow no-gryo turns, so all I
had to worry about was basic flying.
In IMC - I'll take any clue available that indicates something is
wrong with the gryo instruments. I'm confident I can fly partial
panel, but detecting the failure mode is the difficult part...
My only vacuum failure so far was in night VMC, but it was impossible
to miss the big orange annuciator light right above the altimeter --
even my passenger saw it immediately. I never thought of the
importance of having altimeter/oil/vacuum annunciators inside my main
scan when I was shopping for planes, but I'm certainly glad now that I
have it in my Warrior.
Of course, the best insurance is just keeping all the primary
instruments in your scan. Annunciator bulbs can burn out (though I
test them in every preflight).
I have flown approaches under the hood with reference to only the GPS
(this is in a PA28 which is a reasonably stable aircraft). While not
easy it is do-able as long as the plane is trimmed before the approach
and control inputs are kept minimal.
How rough was the air? I wouldn't mind trying it in nice, smooth
stratus or even in light chop, but I wouldn't have wanted to count on
it in some of the cumulus I was flying through this weekend.
Regarding the distraction of setting up a GPS upon the failure. I
think it is significant. I've had a similar situation - an electrical
failure at night (fortunately in MVFR conditions). This was in class
D airspace. Tower called and let me know they lost the transponder.
When I keyed the mic to transmit, the panel went black. This happened
directly over the field. By the time I got the flashlights setup,
grabbed the handheld radio (backseat), plugged in the headset, turned
on, tuned in, and let tower know what was going on - I was 5-6 miles
North (about 3 minutes in the Cherokee).
If or when I'm ever in an emergency, I won't appreciate being
second-guessed afterwards, so I'll try not to do that now, but I do
like to learn from people who have been in real emergency situations.
At the time, what was your motivation for plugging in the handheld,
etc., rather than just landing NORDO? Would you make the same
decision again?
The workload during these few minutes was relatively high.
Significant enough that I revamped how I approach IFR flying. I do
not fly hard IFR at night, and I always keep the handheld charged and
ready to go in the side pocket.
I'm starting to wonder if my handheld was worth the money, since its
transmission range is so small without an external antenna. I'm
thinking of getting a pass-through cell-phone headset adapter instead,
since I'll be able to reach help much quickly (and can keep ATC and
FSS emergency numbers on the speed-dial).
All the best,
David
Old November 4th 03, 03:21 PM
Dan Luke
"David Megginson" wrote:
I'd be nervous that in an emergency my eyes would be drawn too
much to the false security of the GPS pseudo-HSI display instead
of where they should be, on the TC and ASI.
May I suggest that you try it under the hood? I've found that it makes
flying my airplane no-gyro very easy. That may not be true of higher
performance airplanes, I haven't tried it in one.
instruments.
stress.
Try it. I think you'll find it reduces the stress.
Dan
C172RG at BFM
Old November 4th 03, 04:00 PM
David Megginson
"Dan Luke" writes:
Personally, the only time I've found flying under the hood or foggles
useful was on cloudy nights over relatively unpopulated terrain --
otherwise, the light and shadows in the airplane make the hood even
less effective at simulating IMC flight than a flight simulator on my
home computer. I recognize that other pilots may have different
experiences, of course, but that's one of the reasons I took my IFR
flight test in IMC, so that I would know if the examiner thought I was
safe in the real thing.
in a partial-panel situation, where I'm already under a great deal
of stress.
I'm worried that it might reduce the stress a little too much, causing
me to fixate on it and ignore the TC and ASI, but I will try it some
time with an instructor or safety pilot anyway.
Thanks, and all the best,
David
Old November 4th 03, 08:04 PM
Jeremy Lew
I think the point of Dan's question was to inquire whether you have tested
your theory that a GPS-derived HSI's lag is 'dangerous' or not. Everything
I've read suggests that it's perfectly possible to keep the plane upright
using this, although you'll tend to oscillate around your intended attitude
a bit because of the lag. I have a Garmin 196 which has this kind of setup,
but I have not really tried to use it as my primary instrument. I'm going to
do that test soon.
"David Megginson" wrote in message
"Dan Luke" writes:
of stress.
David
Old November 5th 03, 01:56 AM
Snowbird
"Jeremy Lew" wrote in message ...
do that test soon.
I've heard good things about it, but IMO a simple
GPS moving map is very helpful partial panel,
especially if a 'direct to' button has set up
a courseline. It is not a primary instrument,
and I would not want to depend upon it to keep
the plane upright, but in any kind of rough air
where the compass and TC are bobbing a mad dance
it is very helpful in assessing how well I am
doing at holding heading (ie, at keeping the
wings level).
Obviously other people's milage can vary, and does
Sydney
Old November 7th 03, 06:50 PM
Andrew Gideon
David Megginson wrote:
The reason I'm skeptical is that the mag compass also works fine for
holding heading in smooth air with very shallow turns: it doesn't go
to hell in a handbasket until the air gets rough, precisely the same
time the update lag in a handheld GPS could potentially also make it
difficult to use. That's why I'm interested in hearing from people
who've used it successfully in rough air, preferably at night (where
there are fewer visual cues like shadows moving over the panel).
And that's why I'm looking for a device that acts - effectively - as a
backup AI.
I saw a couple of devices at the Expo. Both were "boxes" that plugged into
different "computers". One was a large box that plugged into what I think
was and Ipaq, and one was a small box that plugged into a "Cheeta" portable
MFD device.
I really liked the Cheeta, but I think it was the most expensive of the
solutions I saw.
Anyone have other thoughts about this?
What was the price of a panel-mounted electric AI? 4K? I wonder if I could
get the club to consider such an investment on our aircraft.
- Andrew
I wonder if Chris Thomas is a real pilot? Anybody know? Badwater Bill Home Built 116 September 3rd 04 05:43 PM
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 04:05 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
