"Peter R." wrote in message
... What is this, a test? ![]() Nope, just sincerely trying to understand the basis of your question. Seriously, my uncertainty has to do with the "if A equals B and B equals C, then A must equal C" logic used in the AIM. You're uncertain that if A=B and B=C, then A=C? In other words, one reads in the AIM chapter that you posted earlier that an urgent situation equals an emergency, but then one has to go to the glossary to discover that PAN-PAN equals an urgent situation. Actually, the P/CG is just one place you can discover that "pan-pan" declares an urgency condition. As I later posted, it's also in AIM 6-3-2 ("Obtaining Emergency Assistance"), clause a3a. But even if it were only stated in the P/CG, it's still clearly stated, so I don't see where any uncertainty arises. Why not simply state in the chapter you referenced that "announcing PAN-PAN" will be treated as an emergency by ATC? That's essentially what 6-3-2a3a says, although 6-1-2a in conjunction with the P/CG makes it clear too. Perhaps the real problem is that I am over-analyzing this. Seems to me that the problem is your reluctance to accept the transitivity of 'equals'. That kind of puts a crimp in any attempted analysis. ![]() --Gary |
Gary Drescher wrote:
That's essentially what 6-3-2a3a says, although 6-1-2a in conjunction with the P/CG makes it clear too. Essentially? Makes it clear? Sorry, but the fact that ATC treats a PAN-PAN as an emergency is *still* not as black and white to me as it is to you, at least in terms of the AIM. Once again I will have to agree to disagree with you, for I don't want to beat this horse any more. If any good has come out of this discussion, it is that I am reminded of the power of PAN-PAN, something I should have used but didn't last year when one of my mags failed during flight. -- Peter |
Peter R. wrote:
If any good has come out of this discussion, it is that I am reminded of the power of PAN-PAN, something I should have used but didn't last year when one of my mags failed during flight. That's not necessarily an appropriate use either. I would probably keep that information to myself, as you did. You use "PAN" when one mag is out and the other is getting shaky. You use "Mayday" when the second one packs it in. Of course, shortly before you issue "Mayday" you issue an "Oh, ****! G -- Mortimer Schnerd, RN VE |
"Mortimer Schnerd, RN" wrote:
That's not necessarily an appropriate use either. I would probably keep that information to myself, as you did. You use "PAN" when one mag is out and the other is getting shaky. You use "Mayday" when the second one packs it in. Of course, shortly before you issue "Mayday" you issue an "Oh, ****! G That is your opinion, duly noted and filed. ![]() experience to this group last October, I received a few comments from experienced pilots that I should have indeed declared an emergency over the failure of one mag. Such is Usenet. At the time, the lost mag was an urgent situation to me because I honestly did not know how the engine, an over-TBO, turbo-normalized IO-520, would react at low RPMs on only one mag, as in a descent out of cruise or while being vectored behind other aircraft on approach. Other than needing rich of peak operations to keep temperatures in a comfortable operating range, the engine was otherwise running without hiccups at full throttle, 2500 RPMs. While I did not use the term PAN-PAN, I did communicate to ATC that I had an urgent situation that required direct to the airport with no delaying vectors, as well as the need to remain at cruise altitude until I decided to bring it down to the airport. ATC was very accommodating, but I don't think they declared an emergency for me given the absence of the rescue trucks at the runway. Since this experience last year, I would now probably err on the side of caution and declare an emergency. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
... ATC was very accommodating, but I don't think they declared an emergency for me given the absence of the rescue trucks at the runway. I'm not aware of any principle that says an emergency necessarily requires rescue trucks--especially if it was just an urgency-level emergency, rather than a distress-level emergency. --Gary |
![]() "Mortimer Schnerd, RN" wrote in message . com... Peter R. wrote: If any good has come out of this discussion, it is that I am reminded of the power of PAN-PAN, something I should have used but didn't last year when one of my mags failed during flight. That's not necessarily an appropriate use either. I would probably keep that information to myself, as you did. You use "PAN" when one mag is out and the other is getting shaky. You use "Mayday" when the second one packs it in. Of course, shortly before you issue "Mayday" you issue an "Oh, ****! G Followed by a "What the f*&%k ??". |
... Gary Drescher wrote: "Peter R." wrote in message ... Why not simply state in the chapter you referenced that "announcing PAN-PAN" will be treated as an emergency by ATC? That's essentially what 6-3-2a3a says, although 6-1-2a in conjunction with the P/CG makes it clear too. Essentially? Makes it clear? Well yes. AIM subsection 6-3-2 is called "Obtaining EMERGENCY Assistance". To request that assistance from ATC, the subsection says you should "transmit a distress or urgency message consisting of... if distress, MAYDAY... if urgency, PAN-PAN...". How much clearer could it possibly be that ATC treats "pan-pan" calls as emergencies? (And *in addition*, AIM 6-1-2a already explained that distress and urgency conditions are the two kinds of emergencies.) Sorry, but the fact that ATC treats a PAN-PAN as an emergency is *still* not as black and white to me as it is to you, at least in terms of the AIM. Ok, but you still haven't articulated *any* objection to my conclusion, other than your completely-unexplained reluctance to accept the reasoning that if 1) "pan-pan" declares an urgency condition, and 2) an urgency condition is one of the two kinds of emergency, then 3) "pan-pan" declares one of the two kinds of emergency. (This is, by the way, the *same* reasoning that tells us that ATC treats "mayday" calls as emergencies. You don't doubt the reasoning in *that* case, do you?) It would perhaps be helpful if you were to briefly clarify the following. Do you think then that "pan-pan" does *not* declare an urgency condition (contrary to what the P/CG and AIM 6-3-2a3a say)? Or do you think that "pan-pan" declares an urgency condition that is somehow not an emergency (contrary to what AIM 6-1-2a says)? Sorry to persist on this point, but I think it's pretty crucial for pilots to be clear on the basics of emergency communications. --Gary |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
F15E's trounced by Eurofighters | John Cook | Military Aviation | 193 | April 11th 04 03:33 AM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
