NAVMAN 3450 question
Old August 3rd 05, 05:29 PM
basils27
Utility is on the Winpilot power flying software site. Once you have reset
the sleeve ditch the Smart ST road nav software and you will never have to
run it again.
http://www.winpilot.com/VFR/Default.htm
Basil
"Pete S" wrote in message
The Navman will transmit altitude, as long as you didn't run the crappy
road nav program which was supplied with the unit. If you did, then you
need to reset the gps, using a simple utility. I occasionally use the
NAMVAN 3450 with an IPAQ 3835 when I flying club gliders, and it works
just fine.
I use PocketMap Navigator for road navigation. It will accept Lat/Long.
This is a real nice program with many features.
Snip
Where do you get the utility from?
Peter.
Navman 3450 Doug Snyder Soaring 7 May 10th 05 02:20 PM
Navman PiN Pocket PC for glider usage [email protected] Soaring 1 February 8th 05 12:17 AM
